Question about Panasonic Panafax UF-490 Plain Paper Laser Fax
Clicking noise from toner drum
The uf-490 is clicking away, and the service person said it would stop once the new toner cartridge was in place. Well, still clicking! Help!
  • J M May 11, 2010
    have you used genuine panasonic toner/drum unit
  • 31 Answers
Yes. i also recommend to change your drum cartridge. the spring coil inside the drum unit maybe damage already. and there is no solutions for that except you call for help for panasonic technicians
contact us at 3633636 if you are in the vicinity of manila philippines.
thanks
Posted on Mar 11, 2008
  • 682 Answers
Get the toner cartidge out click in the top many times and then check it many times in horizontal leve (move it quickly from right to left many times)this will mix the toner.- reinstall it again.l
Posted on Mar 07, 2008
Having a clicking noise problem when installing a new toner cartridge into the fax machine. Reusing the old cartridge makes the noise go away. There is nothing wrong with the new toner (we have 2 and both...
You state that you have 2 new toners and both make a noise, but the old one does not. If both the two new toners came from the same source then it is possible that the vendor has a quality control problem and manufactured several defective cartridges. It does happen. If these are not genuine Muratec toners, that makes it all the more likely because often they are remanufactured and attention was not paid to details. Is the old cartridge from the same vendor and does it bear the same brand name if it is not a genuine Muratec item? 15 years in this business tells me that if the old one is quiet and the new ones are noisy, something is wrong with the cartridges, not your machine.
May 05, 2011 | Muratec F320 Plain Paper LED Fax
HOW TO REMOVE TONER CARTRIDGE TO REPLACE WITH NEW ONE
1. Grasp the front cover of the printer and pull it toward you to open the toner door. Reach into the printer and grab the combined toner cartridge/drum assembly. Lift up slightly and pull it out of the front of the printer.
2. Place the cartridge and drum on a paper towel, spare sheet of paper, rag or other surface that can get dirty. Loose toner particles may spill from the cartridge.
3. Press the blue locking lever on the cartridge/drum unit to unlock the toner cartridge from the drum. Lift the toner cartridge up and away from the drum unit. Dispose of the old toner cartridge in accordance with your local regulations. Seal it in a plastic bag to keep loose toner from spilling.
4. Gently shake your new toner cartridge back and forth a few times to distribute the toner evenly across the width of the cartridge. Remove the plastic protective cover from the bottom of the cartridge.
5. Place the new toner cartridge onto the drum unit and press it down gently until it locks into place. The blue locking lever will automatically click into place. Verify that the toner cartridge is securely connected to the drum.
6. Locate the corona wire cleaner tab at the front of the drum unit. Slide it back and forth several times to improve the print quality of the drum. Set the tab back in the home position when finished.
7. Slide the combined toner cartridge/drum unit back into the printer and close the front cover.
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Feb 09, 2011 | Brother HL-2040 Laser Printer
How do i change the toner on m my HL 2040 brother printer
How to Change a Toner Cart in a Brother HL 2040
The Brother HL 2040 laser printer has a toner cartridge that supplies toner to the drum assembly so that the printer can print properly. When the LED on the front of the printer indicates you are low on toner, you will need to replace the toner cartridge to maintain good print quality. Fortunately, the toner cartridge can be replaced without any special tools.
Instructions
Things You'll Need:
* Replacement toner cartridge (part number TN350 or TN360)
* Paper towel or scrap paper
Hope it helps...
Dec 02, 2010 | Brother HL-2040 Laser Printer
Our fax machine has been saying replace drum for a while and faxes have been getting darker and darker we cleaned it but now we can send but not receive what is the drum?
the drum is green roller in housing with toner, you should order the drum cartridge for your fax. With new drum you get the how to manual also. Follow the procedure.
NOTE THAT THE DRUM UNIT IS SEPARATE FROM TONER UNIT.
Hope that helps!
Oct 19, 2010 | Panasonic Panafax UF-490 Plain Paper Laser...
Panafax UF-490 fax problem
your lsu unit must be dirty or check your drum unit
Feb 25, 2010 | Panasonic Panafax UF-490 Plain Paper Laser...
Panasonic UF-490 Fax machine is sending more than one fax
You might have a job stuck in memory. Message window should say 00%. Try this press Function key press 7 key press monitor key slowly 4 times press * key press 6 key scroll down to ALL JOB CLEAR press SET wait for reboot Good Luck
Jun 05, 2009 | Panasonic Panafax UF-490 Plain Paper Laser...
Setting to Receive to Memory
The easiest way is to remove the toner / drum assy and lock away.
Mar 02, 2009 | Panasonic Panafax UF-490 Plain Paper Laser...
Loud Clicking Noise
CHECK ON EBAY FOR REPLACEMENT DRUMS OR LOOK FOR A NEW MACHINE,
Feb 09, 2009 | Panasonic PanaFax UF-490 All-In-One Laser...
Replace Drum - 044 Error
from control panel did the following:
function, maintenance, drum, clear
Dec 01, 2008 | Panasonic PanaFax UF-490 All-In-One Laser...
Panasonic Panafax UF-490 Plain Paper Laser Fax Logo
114 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
