Question about Dryers
Indiset is 60 belt
Indesit is60 belt replacement, I've fitted the belt to the motor shart and around the drum but the drum is now out of line I cant figure out what supports the drum to keep it square?
  • Anonymous Dec 01, 2008
    cant get the drum back rite
  • 52 Answers
Back supports and the front upper door screws. Open door and look up for screws, which you should have had to take out to get to the drum. You are getting very close to a repair. Keep looking and you will see what has to be done. Do not give up. You are too close to give up now. You can do this. keever
Posted on Mar 06, 2008
How to fit belt on Creda Reversair 37643 Tumble dryer
New belt is very tight, so you have to use more strength. Put it on motor and all other on "drum". Spin it easily and slowly but with strength until its done.
Be carefully, use gloves.
Apr 13, 2013 | Indesit Hotpoint Creda Tumble Dryer Belt...
How to replace belt on washing machine
hi take the back and lid off the washer usually on the top part of washer you should see the motor there should be 3 bolts 2 keeping it to the drum and another for ajustments losen this one untill the motor goes limp put new belt around the big wheel on the drum and on the small cog on the motor get a log heavy screw driver put it on the motor as a lever and take up the slack dont tighten the belt to much as it will end up snaped again just so you can poke the belt and it moves in and out slightley then tighten up the nut on the motor and thats it hope this helps ivan
Sep 25, 2012 | Indesit Washing Machines
get fire extinguisher and through it out side lol
Aug 14, 2012 | Dryers
Fitted a new belt to indesit is60v tumble dryer, worked for a few seconds and now does'nt work at all, just makes a buzing sound?
Check that the belt has not fallen off ...does the drum turn by hand easy if so then its fallen off .Motor could also have jammed....
Feb 10, 2011 | Dryers
How do i replace the belt which has broken on my tumble dryer
Pop the top (spring clips) ... remove the front (screws) ... pull the drum out ... clean everything! ... find the belt tensioner which clips into the floor ... get a new belt ... put it around the drum ... through the tensioner ... around the motor pulley ... reassemble,
Jun 21, 2010 | Indesit IS70C Electric Dryer
How do i fit new belt to my indesit tumble dryer
its easy, firstly wrap the belt round the motor spindle, feed the belt around the drum drive as much as you can, then turn the drum by hand and it ease the belt on as you turn it, be careful not to pinch your finger.
Mar 25, 2010 | Dryers
How to fit a belt for a indesit dryer ISL70c
Thanks for using FixYa. Please follow the step-by-step procedure---
1. Remove the front panel.
2. Reach underneath drum and behind motor to locate idler pulley. Push idler pulley to left to release drum belt tension. Remove the belt from the motor pulley.
3. Remove the drum and belt from the cabinet.
1-- Prepare for replacing the dryer belt by lifting the lint-screen cover on the top of the dryer. Then remove the lint screen. Skip this step if your lint screen is inside the door. Remove the 2 Phillips screws inside the door instead.
2-- After removing the lint screen, lift the cover and remove the screws that hold the lint-screen housing to the dryer top.
3-- Slide a putty knife between the front panel and the top near a corner. Lift the corner and repeat on the other side.
4-- To remove the lower panel, insert the putty knife between the panel and each side. Then twist to release clip.
5-- Place a few wood blocks under the drum. These support the drum when the front panel is moved away from the sides.
6-- Loosen the screws that secure the bottom of the front panel to the dryer sides. Do not completely remove the screws.
7-- Remove the screws that secure the front panel to the dryer sides at the top. These are accessed from the inside of the cabinet.
8-- Lean the front panel away from the sides and slip the new dryer belt over the drum. Then re-secure the front panel.
9-- Check that the lip on the back of the dryer drum fits properly against the seal on the rear bulkhead of the dryer.
10-- Locate the original position of the old belt, and slip the new belt in place. Keep the grooved side of the belt down.
11-- Push the idler pulley toward the motor and loop the doubled-up belt around the idler pulley. Slip belt around motor pulley.
12-- Rotate the drum counterclockwise a few turns to check belt tracking. Then replace remaining components and test run.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Feb 20, 2010 | Washing Machines
Drum dose not turn belt is ok no smell or dust
Fit new motor brush kit if well worn cost about £25 ...
Nov 13, 2009 | Washing Machines
How to fit a belt on a tumble dryer
unplug the dryer,
220v is not fun
dryers are generic inside, regardless of maker
while you got it apart to replace the belt is a good time to clean out exhaust vent pipes and the squirrel cage fan, no lint, better air flow, less $$ to run
3cd9043.jpg the tensioner may push Up on the lower run.
  • open case, most front panels are removed including door, remember to disconnect door switch wires, set panel aside
  • pull drum out
  • check drum support rollers
  • check drum felts, bushes guides
  • locate tensioner pulley, belts have been known to pull them out of the mounting when it breaks, check , reinstall if out
  • pick up broken belt off floor of case
  • take belt to parts store and match it, despite the huge number of dryer models there are very few belts.
  • If any felts or rollers are worn,stuck,damaged take them too to the parts store, and replace in pairs, despite the huge number of dryer models there are very few rollers or felts
  • after ensuring rollers anf felts and bearings are serviceable, loop new belt around drum at the wear mark from prior installation, reinsert drum
  • loop new belt around motor pulley.
  • pull tensioner pulley against spring to end of motion
  • loop belt around tensioner pulley
  • allow tensioner to slowly move back by spring tension till the belt is taut
put front panel back on, plugging in door switch
plug in mains
dry clothes
takes longer to type than to do
Aug 29, 2008 | Dryers
Dryers Logo
110 people viewed this question
Top Dryers Experts
