Question about HP 12c Calculator
Where can I get instructions for the HP 12C
I have a HP 12 C and I need the instructions to show how to operate. Can I get this online? I can't clear an entry that was entered previously.
Get rid of comma in numbers
Posted on Jun 05, 2008
How do you clear RNP for an HP 12C
I take it you mean a 12C Platinum.
Press f ALG. ALG is the f-shifted function of the EEX key, just above the double-size ENTER key. This will switch the 12C Platinum from RPN mode to Algebraic mode, and ALG indicator will light up instead of the RPN indicator.
To switch back to RPN, press f RPN. RPN is the f-shifted function of the CHS key just above the EEX key.
Apr 23, 2014 | HP 12c Calculator
My HP 12c is showing 0,00 on the display...if I add 2 plus 2 it shows 4,00. Not sure how to reset? It also has a blinking * which I understand is a low battery indicator...are these two things relat
No, they're not related.
To switch the radix mark, turn the calculator off, press and hold the decimal point key, press the ON key, then release both keys.
Feb 18, 2013 | HP 12c Calculator
My HP-12C calculator shows 0.000000, how do I clear this display?
Press "f" then the digit representing the number of digits you want after the decimal point.
Aug 22, 2012 | HP 12c Calculator
Do you have advice in calculator choice between HP 12 c and the TI BA II Plus Professional Financial Calculator? Assuming that I get proficient with RPN (which I'm learning now); is one faster than the...
The 12C is more expensive and more powerful than the BAII+Pro. The HP is also programmable, which the TI isn't. Starting from scratch (assuming you've never used a calculator before---a somewhat unreasonable assumption) the TI might be easier to learn, at least initially. But after a certain point, the HP will leave the TI behind. The HP is faster and more capable.
There are at least three different versions of the 12C available. There's the original 12C, the 12C Platinum, and the current 12C. The only way to tell the difference between the two non-Platinums is to look at the battery compartment---the original uses three button cells while the newer uses two coin cells. The newer one is MUCH faster. The Platinum, however, can use RPN or algebraic.
Unless your choice is limited to the 12C or the BAII (by the requirement of an exam, perhaps), you might want to look at the HP 20B and the HP 30B. Programmability aside, they're even more powerful and easier to use and faster than the 12C, and the 30B is also programmable.
There are other considerations, of course. Factors such as the feel of the keyboard, the 12C's landscape orientation as opposed to the others' portrait orientation, etc, are all matters of personal preference.
Disclaimer: I own multiple HP and multiple TI calculators. I tend to use HP calculators for calculating, while I use TI calculators to answer questions here at FixYa.
Mar 23, 2011 | HP 12c Calculator
The calculator is not showing any display after replacing the battery of HP 12C
Try verifying Proper Operation (Self-Tests)
If it appears that the calculator will not turn on or otherwise is not operating properly, use one of the following procedures.
1. With the calculator off, hold down the [ON] key and press [X] (the multiply key)..
2. Release the [ON] key, then release the [X] key. This initiates a complete test of the calculator’s electronic circuitry. If everything is working correctly, within about 25 seconds (during which the word RUNNING the display should show –8,8,8,8,8,8,8,8,8,8, and all of the status indicators (except the * battery power indicator) should turn on. If the display shows Error 9, goes blank, or otherwise does not show the proper result, the calculator requires service.
Tests of the calculator’s electronics are also performed if the [+] key or the [divide] key is held down when [ON] is released. These tests are included in the calculator to be used in verifying that it is operating properly during manufacturing and service.
If it needs repairs, contact FixThatcal.org
Feb 21, 2010 | HP 12c Calculator
I have an HP 12C calculator and I cannot find the user manual and I cannot remember how to change the no. of decimal places?
Check this HP FAQ:
Setting a Fixed Decimal Place You can download the manual and user guides for your calculator from here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=81575&lang=en&
For more information, Faqs & how-Tosgo the HP support homepage for your calculator:
http://h10025.www1.hp.com/ewfrf/wc/product?lc=en&dlc=en&cc=us&lang=en&product=81575&
Introduction This document describes how to set the desired number of decimal places on the HP 12c calculator in standard format. It also covers how to enter a number in scientific notation. Instructions for standard format
  1. Press and release c01774993.jpg .
  2. Press the number key for the desired number of decimal places to be displayed to the right of the decimal point (0 through 9). The calculator displays a maximum of 10 digits.
The display will show the specified number of decimal places. The answer will be rounded to the number of digits selected. Example (standard format) If the number in the display is 14.87456320, the display will be changed as follows: Keystroke Display c01774994.jpg 14.8746 c01774995.jpg 14.9 c01774996.jpg 15 c01774997.jpg 14.87456320 Instructions for scientific notation Use scientific notation for very large or very small numbers. Type in the mantissa. After pressing, c01774998.jpg the next numbers keyed in are exponents of 10. Press c01774569.jpg . If during an operation a result has more than 10 digits, the calculator automatically displays the number in scientific notation
Aug 24, 2009 | HP 12c Calculator
0.000000 00 ???
I received lots of help online regarding the problem I was having with my HP-12C. Thankyou so much.
Apr 05, 2009 | HP 12c Calculator
How to reset my HP 12 C calculator ? it's doesn operate right
I just follow the paper clip trick (took the batteries out, connect the + and - with th epaper clip, then turn it off). After clearing all the program memory and turned it on & off, it worked fine.
Thanks.
Jan 06, 2009 | HP 12c Calculator
HP 12c cALCULATOR
It is not calculating because your decimal point and the digit separator (that's the comma which automatically displays for every group of 3 digits) got messed up. To clear, turn the calculator OFF, then press and hold down the dot (that is the decimal point symbol) key while you press the ON key..
t
Sep 04, 2008 | HP 12c Calculator
HP 12c Calculator Logo
181 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
