Question about Microwave Ovens
Broken microwave door latches
Where do I buy replacement latches and how do I separate the door panels. It looks like I need to pry the tabs open, but I am worried about snapping them off trying to bend them back.
  • 2 more comments
  • C-1408 Mar 05, 2008
    Johnychel,
    It's a Kenmore 63673 stainless.
    I have already answered you once, it is a Kenmore 63673 stainless
    Kenmore
    363-63673201
    This is a repost my request,
    How do I replace my door latches on my Kenmore 363-63673201?
    all Johnychel(your expert keeps asking me is what is the make and model of my microwave. I have answered him/her/it three times. Is it possibe there is a language barrier?
  • 552 Answers
Go to www.repairclinic.com and enter 363-63673201 in the search box for your model.
You will see a hinge repair kit.
Usually the kit will come with instructions.
Posted on Mar 05, 2008
  • 407 Answers
Hiiii
Microwaves are cheap. If it's got any age on it, get another one. Don't risk getting radiated.if Risk then remember
This is actually an easy fix. The hard part is getting the part. You might be able to get the part on line. Get the make,model and serial#. See if the manufacturer will sell you the latch. Usually there is about 6 screws on the out side edge of the door. Also 4 screws in the door. assemble the same way it came apart. If you can't get the part trash it.
  • krishna Singh
    krishna Singh Mar 06, 2008
    RepairClinic.com Provides Consumer Tips for Microwave Ovens
    Many exterior broken parts of a microwave oven can be replaced. ... door handle, latches, hinges or the frame that surrounds the microwave oven are ...
    www.marketwire.com/mw/release.do?id=731163&k=
    Many exterior broken parts of a microwave oven can be replaced. Only experienced technicians should repair internal parts.
    workers have all seen it: the neglected microwave oven that contains the remnants of many lunch explosions. Microwave ovens cook fast, are convenient and are relatively inexpensive -- which means they're often taken for granted and not treated as well as other appliances. Can they be repaired if they fail? What about replacing broken parts?
    If a microwave oven stops working, Chris Hall, president of RepairClinic.com, recommends that consumers not dismantle them: "There are some high-voltage components inside the unit so we don't advise the average consumer to attempt internal repairs. But years of fielding consumer questions about microwave ovens means that we can offer some important use and safety tips, as well as provide those appliance parts that can be replaced."
  • krishna Singh
    http://www.repairclinic.com/referral.asp...
  • 796 Answers
What is the company make and model of your owen??
  • isaac johny
    isaac johny Mar 05, 2008
    look at this link,,,,,this will provide you pictorial guide for you request....
    thankyou
  • isaac johny
    The mounts hold the door switches and grab the door hooks when it the door is closed.
    The solution is to realign and tighten the mount screws inside.
    It's less liekly, but it could be a weak or worn door open lever inside.
How do you replace the handle
follow this steps and fix it. see the pictures attached. God bless you2f4dab72-f574-4367-8631-e2d40f813792.gif
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Jun 18, 2013 | KitchenAid KHMS147 Microwave Oven
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
I have a frigidaire model fmv156dbf and the door latch will no longer operate. when i opened up the door i saw that the spring that is supposed to operate the latch was no longer attached. where the spring...
We have the service manual and have uploaded it to our site here to help you.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
You can order parts here if needed.
We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer
May 26, 2010 | Frigidaire Microwave Microwave Oven
Sharp Microwave model R-1850A door won't open
buy a boddle of WD-40 and try spray some in the raded spots.Im not a big specialist in microwaves.hope it helps
May 10, 2009 | Sharp R-930AK Convection/Microwave Oven
Door of microwave wont shut
If you gently push up on the door latches (hook-like devices on the door) there should be spring tension. If they just flop right up, the spring is off.
We have critical safety & disassembly info at our site, linked here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
If you need to order parts, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here.
After you look into this, if you still need help, please write back with your model number and more details.
Oct 08, 2008 | LG Microwave Ovens
Microwave broken door latch
The door latch head (hook) is pretty easy to replace or repair if that's the issue.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Sep 24, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Need door assembly diagram to replace door latch & spring on Panasonic microwave model nn-t964sf
While I don't have that model's diagram, normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
You can order Panasonic parts here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 23, 2008 | Microwave Ovens
Door Latch Spring
You can usually find helpful exploded view diagrams and order parts by entering your full model number (RVM1425BA03) here: http://tinyurl.com/gv383
We have *critical* safety & disassembly info at our site, linked here: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Apr 02, 2008 | Hotpoint RVM1425 Microwave Oven
MIcrowave
check the door latches inside the oven, open the housing and spray some lubricants on the latches.
Feb 21, 2008 | Frigidaire FMV145K Microwave Oven
Directions to remove and open door panel to repair safety door latch.
You don't have to remove door to remove panel. Panel is held in by an outer plastic retainer which can be removed by carefully prying with a small screwdriver. I can be replaced by pushing it back in place after repair is completed. If you cannot open door from the outside, remove cover and you can see latches. Pry up on latch which will let door open.
Jul 28, 2007 | Sharp R-1610 Microwave Oven
Microwave Ovens Logo
897 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
