Question about Tao XM2go Satellite Radio Receiver
XM2Go Tao Display Problem
I have the XM2Go Tao and it has been working great. I turned on the other day and the display is not working. I see the backlight go on but the display is blank. I can get sound out of it but I can not see anything. HELP!!! I have the exactly the same problem. I turned off the XM2GO with the remote and noticed the display go blank when it always said XM2GO before shutting off. The backlight works but their is nothing displayed. I tried moving the radio from my indoor mount to my car and still nothing displayed even though I am receiving music.
    Master:
  • 788 Answers
Here's some disassembly instructions. Open it up and verify the screen's connection. Also look for burnt or broken components. If all looks fine then either the screen is faulty or the board is. You may be able to find parts on ebay.
xm411.com is a great rescource as well as xmfan.com
Posted on Mar 05, 2008
  • 796 Answers
Have you tried resetting it??
No sound comes out of radio?
Turn up the volume by pressing the top of the center cluster of buttons. Does it work in the home dock or car dock without headphones?
Nov 23, 2012 | Tao XM2go Satellite Radio Receiver
My tao xm2go unit is transmitting a very weak fm signal to my car radio. I can barely hear the audio.
You likely need to directly connect. In most cases the FM transmitter is too week to broadcast through FM stations, and a direct connection will clear up your issue. It could be as simple as connecting via an Auxiliary cable or Cassette Adapter. If you don't have the ability to use one of those, you can get an Auxiliary Input Adapter. Another solution would be an external FM Transmitter, with a larger range.
Jun 26, 2012 | Tao XM2go Satellite Radio Receiver
My Tao xm2go quit working. I've tried re-setting it. I've replaced the battery, I double checked that the charger is putting out the correct voltage with a multi-meter. it won't turn on, either with the...
Try plugging the power adapter directly into the bottom of the radio without using either base/cradle - wait a minute - then see if you get a battery indication.
Jan 18, 2010 | Tao XM2go Satellite Radio Receiver
My Tao won't turn on and when I put it in the craddle all it does is blink
Probably bad battery. XM actually recalled original batteries and supplied new replacements.
Oct 25, 2009 | Tao XM2go Satellite Radio Receiver
On/off switch doesn't work. Can't get XM2Go to turn on
if you have an extended warranty on it i would send it back and have them take a look at it
Feb 27, 2009 | Tao XM2go Satellite Radio Receiver
My tao xm2go will not turn on
Dear Glen,
My Tao solution is to buy the Delphi MyFi which appears to have an identical interface. See page 10 here: http://file.xm411.com/manuals/MyFiUserGuide411.pdf . This is expensive but service in not available.
digitally,
(/\/\<erwin
Nov 21, 2008 | Tao XM2go Satellite Radio Receiver
Atenna connection when using Altec Speaker or Car Kit
Dear xm2go,
I could not find any service options for my own Tao XM2go unit. The only option appears to be the Delphi MyFi unit which appears to be identical (see page 10 here: http://file.xm411.com/manuals/MyFiUserGuide411.pdf )
digitally,
(/\/\<erwin
Oct 07, 2008 | Tao XM2go Satellite Radio Receiver
Will not play all channels
It was just a simple refresh via the internet. thanks
Jun 16, 2008 | Tao XM2go Satellite Radio Receiver
Display of recorded programs does not match the program playing
There is a very small reset button under the back cover. You will need a small paper clip to reach the button. It is located in the upper left hand corner. The button is not under the batt., it is about 2" above the screw on the side. I don't know if this will solve your problem, but it should reset your radio to its default settings. Good Luck!
Apr 29, 2007 | Tao XM2go Satellite Radio Receiver
Tao XM2go shuts off for no reason
You could try taking the batteries out and cleaning the contacts, replacing the batteries and/or using sellotape to hold the batteries in place. They could be loose and disconnect when you move it in a certain way. If not the batteries, you could try further dismantling and cleaning, but you may just end up with a clean ball of sellotape that still has problems...! worth a try. stoodleysnow
Aug 30, 2006 | Tao XM2go Satellite Radio Receiver
Tao XM2go Satellite Radio Receiver Logo
213 people viewed this question
Top Tao Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Tao Audio Player and Recorder Expert? Answer questions, earn points and help others
