Question about HP DeskJet 930c InkJet Printer
Printer not printing
I recently replaced a deskjet cartidge and printer automatically set up the new cartridge. Now although the cartridges moves back and forth as if it is printing nothing comes out
  • 407 Answers
Hope you are not properly setup your cartridges
  1. turn off your printer
  2. open your cartridges
  3. setup properly
  4. go to printer properties then if your printer ink show press
  5. test print okkkkk
Posted on Mar 05, 2008
My hp deskjet 895cxi has worked so well for years
probably clogged nozzles. Clean the print head. If that doesnt work, replace the cartridge with a new one
Jul 23, 2010 | HP DeskJet 895cxi InkJet Printer
I put in a new black ink cartridge now it doesnt want to print says ink cartidge is low, its not then just feed paper all the way through
Find out if you have not bought an expired cartridge.Service the printer and replace the cartridges with good quality cartridge.
Jun 02, 2010 | HP DeskJet 9800 InkJet Printer
Printer only prints magenta from the tri colour cartridge, have tried different new cartridges, same problem.
Stop buying cartidges. You already know they're not the problem. The problem is in the circuit to the cartidge. Gently wipe the circuit ends then retry. If not, buy another printer that accepts the same cartidges. Don't waste the ones you buyed.
Nov 29, 2009 | HP DeskJet 840c InkJet Printer
HP Deskjet 5740 I have not used my printer in some time and both cartridges are half full. It printed with the black but came out with gaps in the printing so i took the cartridge out and put it back...
it is better to change the black cartige becaue there is the jam of the ink in black cartidge. or pick out the black cartidge and clean with soft paper in the place from where color is pour. then reinstall the cartidge. i hope it will ok. otherwise, change the cartidge.
byee
May 09, 2009 | Office Equipment & Supplies
I need step by step instructions as far as how to change cartridges in hp deskjet 5440 printer
[This is from HP.com]
Introduction This document explains the basics of installing or replacing the print cartridges. It is for a 5940 which is the same printer design, yours may look a bit different but I copied this from HP at the section for your printer so follow the instructions and you should be okay.
Insert the print cartridges
NOTE: The printer shown below is the HP Deskjet 5940 series printer. Your printer might look slightly different.
  1. Turn the printer on. The cartridge cradle will not move if the power is not on.
  2. Open the printer cover. Figure 1: Open the cover c00393707.gif
  3. Wait until the print cartridge cradle moves to the right side of the printer and is idle and quiet.
  4. If you are replacing a print cartridge, press down on the print cartridge to be replaced, and then slide it out of the print cartridge cradle. If you are installing print cartridges for the first time, go to the next step.
  5. Remove the new print cartridge from its packaging and carefully remove the plastic tape. Hold the print cartridge so that the copper strips are on the bottom and facing toward the printer. Figure 2: Remove tape c00393708.gif 1 - Protective tape CAUTION: Do not touch the print cartridge ink nozzles or copper contacts. Touching these parts will result in clogs, ink failure, and bad electrical connections. Do not remove the copper strips. They are required electrical contacts.
  6. Slide the print cartridge at a slight upward angle into the cradle until the cartridge snaps into place. Figure 3: Install the print cartridge c00393709.gif
  7. Repeat steps 3-4 for the remaining print cartridge.
  8. Close the printer cover. The printer automatically prints a calibration page.
Original Page here:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00411520&lc=en&dlc=en&cc=us&product=445441&os=228&rule=27868&lang=en
Regards,
Worldvet
Dec 01, 2008 | HP Deskjet 5440 InkJet Photo Printer
Only one colour is printed
try to check the level of ink..
do this step:
The print cartridge contacts may not be cleaned. Clean the print cartridge contacts as described below or, if necessary, replace the cartridges:
  1. Open the printer top access door. The printer carriage will move to the center.
  2. Remove the USB cable from the back of the printer.
  3. Remove the print cartridges from the printer.
  4. Unplug the power cord. (Do not press the Power button to turn off the printer).
  5. Verify that the cartridge reference meets the specifications for the printer. Cartridge reference can be found in the User Guide.
  6. Verify that the protective plastic tape has been removed from the print cartridge
  7. Locate the copper circuit strip on the back of the cartridge.
  8. Clean the copper circuit strip with a dry foam-rubber swab or a lint-free cloth. Do not wipe the nozzle end of the cartridge or touch the nozzle plate. note: do not used any glass cleaner coz it will cause the damage of the print cartidge
  9. Reconnect the power cord to the printer.
  10. Turn on the printer if it does not turn on automatically.
  11. Insert the print cartridge into the cradle at a slight upward angle until a resistance is fallen.
  12. Close the top access door. The printer carriage should move to the left.
  13. If the printer light is on steady, perform a self test report as follows:
    1. Press and hold the Power button, and then open and close the top cover four times.
    2. Release the Power button.
  14. If the printer light continues to blink, replace the print cartridge or cartridges one at a time.
Try this steps and give me feedback.....
Aug 31, 2008 | HP DeskJet 3745 Printer
Printing problem
You have either a clogged colour print head or a non-functioning print cartridge (only one colour working). If the printer has separate cartridges for different colours (and black) you can do a partial swap, replacing the ones that have failed, but start by running the command CLEAN PRINT HEADS from the printer options or controller panel, and watch for the quality to improve. You may have to clean the heads two or three times. If no change in the quality after two flushes, replace the cartridges with new ones.
Good luck...
Nov 16, 2007 | HP DeskJet 610c InkJet Printer
Cartridges not moving
Sounds like a corrupt driver, uninstall your printer (Start> Printers and Faxes on right column), select your printer icon, right click>Delete. Disconnect your printer and re install drivers first, then reconnect printer when prompted. If still not performing correctly suspect printer head carrier fault.
Oct 25, 2006 | Apple HP DeskJet 3820 InkJet Printer
HP DeskJet 930c InkJet Printer Logo
130 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
