Have compaq presario v2000 notbeook. was beeping twice upon boot up, replaced the memory as that was the error code I found online, now it gives off one long consistent beep right after the compaq screen comes up but before the windows xp screen comes up. It does boot but then you can do nothing as everything you try hangs. Any clues? Thanks
  • 2 more comments
  • pekala13 Mar 05, 2008
    There was a 256mb memory chip in the system when I got the initial 2 beeps. I replaced it with a 512mb chip (both are 200 pin, 333mhz) and now it went from two beeps to an extremely long beep. There is no built in ram that i could find from the specs. I did diags from the BIOS and the system sees the 512mb of memory. I will have to remove the battery when I get home from work and see if that works. Can I reply tonight once I try to unplug everything?
    sorry
    specs for the laptop are up to 2gb of memory, there are two slots. I replaced a 256mb with a 512mb, which is a supported config.
  • pekala13 Mar 06, 2008
    I unplugged everything and had the same result. Put in another memory chip, same thing. Put memory in both banks thinking one bank was iffy, same result. I can bypass the beeping by holding down the esc key at boot up but still cannot really do anything when the system comes up. The system doens't initally beep, it goes to the compaq screen, beeps when the screen fades then a black screen with a blinking line appears (still beeping) and then the beeping stops as the windows screen appears. When you say main board, do you mean the motherboard of the system? or is it possible to just replace the memory portion of the board?
  • pekala13 Mar 25, 2008
    It ended up being a defective keyboard. One of the keys caused the never ending beep. Replace the keyboard and all is well.
    Master:
  • 788 Answers
Does this also happen without the battery inserted. Unplug everthing possible including DVD drive and external devices.
According to this site: http://www.bioscentral.com/beepcodes/compaqbeep.htm one long neverending beep is also bad RAM. If you've replaced the ram then the only other explanation is the memory controller on the main board, looks like you'll have to replace that too. First check that the RAM is inserted properly. Try a single RAM module if possible. Does this unit have built in RAM? If so then the main board needs to be replaced. Also make certain that your new RAM is the proper type and speed.
Good Luck!
Posted on Mar 05, 2008
  • 2 more comments
  • Dean Joly
    Dean Joly Mar 05, 2008
    That would indicate that either your new RAM is also faulty or that the main board is faulty. Try some more RAM, try to borrow some, if same problem replace the main board. Otherwise buy more RAM. Lookup MEMTEST86, it's a great memory diagnostics program that you burn to CD, use it to test your RAM.
  • Dean Joly
    Dean Joly Mar 06, 2008
    Motherboard is correct, and no the memory slots and memory controller are part of the motherboard unfortunately. Ebay should have some motherboards for this model for sale, if it's a few years old you may be in for about $200~$250.
  • Dean Joly
    Dean Joly Mar 26, 2008
    That makes a lot of sense now!!! You always think the worst when you hear beeps it thru me off, especially since the beep codes site I found had an entry for a long neverending beep. It didn't occur to me that you were describing neverending short beeps. Good on you for finding it out.
  • Dean Joly
    Please make sure to rate my solution as you see fit. Thanks.
  • 796 Answers
What is the RAM specification of the notebook??
  • isaac johny
    isaac johny Mar 05, 2008
    the ram position may be slightly wavered from the slot or the ram may not be performing well..
What is wrong when my compaq v2000 beeps 2 times loud when I turn it on but no boot
Beep codes are unique to each brand of computer:
Compaq v2000
1 short with 1 long beep = bad bios. Must reload bios from disc.
2 short beeps = general bios failure
for more - do a google search for "v2000 Beep Codes" and go to the link for "bioscentral" - all are listed.
Jul 02, 2014 | HP Compaq Presario V2000 Notebook
Compaq V2000 "Press <F1> to resume, <F10> to Setup
re install the operating system.insert the recovery disk and follow the instructions.
Feb 20, 2010 | HP Compaq Presario V2000 Notebook
My Compaq V2000 beeps twice & freezes
It sounds like the RAM is either not compatable or is bad. Put the old RAM back in and try again. Also the V2000 and HP DV2000 is in recall for mother board problems.
Nov 12, 2009 | HP Compaq Presario V2000 Notebook
Upon turning on my comouter i hear two beeps and then it goes to a gray/black screen that gives me two options "press F1 to resume , F2 to setup. I have pressed both and nothing happens
This a memory parity error.
It is telling you your memory is bad. Try replacing the first stick of RAM and try to boot again.
If your computer has built-in memory, it means a new motheboard.
Sep 25, 2009 | HP Compaq Presario V2000 Notebook
MY LAPTOP(hp compaq presario v2000)BEEPS
hi roman razumo,
these are common infos you can see on beep codes.
if you have AMI, your computer has memory problems. First check video. If video is working, you'll see an error message. If not, you have a parity error in your first 64K of memory. First check your SIMM's. Reseat them and reboot. If this doesn't do it, the memory chips may be bad. You can try switching the first and second banks memory chips. First banks are the memory banks that your CPU finds its first 64K of base memory in. You'll need to consult your manual to see which bank is first. If all your memory tests good, you probably need to buy another motherboard. (more info on this click here)
for physical troubleshooting tips for laptop issues, please click this link.
http://www.laptoprepair101.com/
hope this helps.
regards,
voodoo
Apr 12, 2009 | Computers & Internet
Compaq Presario V2000 laptop wont boot
hi it seems that ur mother board has been damaged.. and immediately u should go for replacement....
thank u!!!
Apr 09, 2009 | HP Compaq Presario V2000 Notebook
Installed more memory into Compaq V2000
The new ram you have installed, is it the same speed/type as what is already in the system?
Take out the new ram and leave the old in. Try and boot. If all ok, swap out the old ram for the new and see if you can boot. If the system does not boot when trying one of the above, you know it's bad ram. If the system boots with the old ram and the new ram installed seperately, i'ts likely that you have two different types of ram. Check your old ram and see what spec it is. Your new ram should be the same. Compaq do not list a four beep error on boot, but my guess is conflicting ram.
Jan 17, 2009 | HP Compaq Presario V2000 Notebook
Compaq Presario V2000 fails to boot up
3 beeps is the Beep code for "Base 64KB RAM Failure". Lets hope that you are lucky and the problem is your memory. If you have two memory sticks in the computer, then try to take one of them out. Try different combinations such as swapping between the memory slots that are available. If you still getting the same error code, then your motherboard is shot.
Aug 16, 2007 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
54 people viewed this question
Alun Cox
David Payne
David Payne
