Question about HP LaserJet 3030 All-In-One Printer
Scanner error message hp laserjet 3030
When I turn it on I get "scanner error turn off turn on" message. I've turned it off and on..I've unplugged it from the wall and plugged it back in. I currently do not have it hooked to a computer, I just use it as a copier.
  • 5 more comments
  • leesalouski Mar 11, 2008
    the Laser/Scanner Assembly cable wasn't securely connected. Cleaned it with an eraser and plugged it back in...works great!!!
  • Anonymous Mar 25, 2008
    when I turn it on I get "scanner error turn off turn on" message.
  • Anonymous May 03, 2008
    WHEN I TURN ON THE PRINTER IT SHOWS SCANNER WARMING UP AND IT HOLDS FOR SOME TIME AND THEN IT SHOWS THE SAME ERROR SCANNER TURN OFF AND TURN ON
  • wilthifra May 05, 2008
    When trying to copy from glass, I get error message "document feeder mispick reload".
  • sammy1101 May 12, 2008
    Scanner ERROR ON & OFF
  • sanju suryav May 16, 2008
    WHEN I TURN ON PRINTER IT GIVES SCANNER POWRE ON OR OFF ERROR, SAME PROBLEM OCCUR WHEN I AM DOING ANY COPY OR FAX.
  • arun ji Sep 09, 2008
    hi i am having problem in scanning when i try to print its working so there is no fault with the usb cable but the issue is that scanning shows error to unplug and do again i did but still the same ;arunjipersonal@gmail.com
    Problem Solver:
My hp 3030 printers shows warning up bulb and make noise how can i solve it ?
Posted on Oct 13, 2009
Posted on Jun 10, 2010
Posted on Jun 03, 2010
This really has nothing to do with the scanning or ADF. It is the Laser/Scanner that needs to be fixed. Either the cable is broken or it needs a new Laser/Scanner Assembly. I believe the part number is RM1-0171. You should be able to find it on google.
Posted on Mar 05, 2008
Posted on May 16, 2008
My have a printer hp 3030. But problem is that it takes toomany to send fax around 10-15 min.please help me to solve this problem.
Posted on Dec 18, 2009
  • rsbhind Nov 18, 2010
    SIR,
    MY HP3030 IS NOT RECEIVING
2 Suggested Answers
SOURCE: scanner error message hp laserjet 3030
This problem has to do with the scanner mirror. You may hear a grinding sound, also. The reason it does this is because the scanner bulb cannot find 'home', so it keeps trying to find it. Well, it uses the mirrors to reflect on another object inside the scanner to tell it when to stop. The mirror on top of the right next to the scanner bulb may need to be cleaned. This works every time for me, except the same problem always comes back sooner or later.
how to clean-
1.unplug your scanner
2.notice the glass covering on the left side, it can be removed with a Phillips screwdriver. Unscrew the plastic surrounding the glass and then remove the glass covering.
3.Plug the scanner back in and wait for the scanner to move left and then unplug it before it starts moving to the right. Repeat this until scanner bulb is all the way on the left of the machine.
-an alternative method-
with the glass covering removed, use a pair of pliers to move the small belt that moves the scanner bulb. keep moving it until the scanner bulb is all the way on the left of the machine.
4.With the scanner bulb assembly in reach, grab a Q-tip and gently clean the mirror that is just to the right of the bulb. You might want a flashlight to see the dirt and dust.
5. Put the glass covering back on.
6. Plug in the scanner.
At first to me it seemed like it wouldn't work, but it does.
Hope it helps. Reply back if it does.
Posted on Jul 23, 2008
Printer error Code 6000.
Fix your printer
Another site says you can clear the error message by turning off the printer, unplug it from the wall, wait 25 minutes, plug it back into the wall, turn it on. This is in reference to a Canon printer. If both the Fix your printer and my typed tip fails, you can contact cannon:
http://www.usa.canon.com/cusa/consumer/standard_display/contact_us_consumer
Jun 02, 2017 | The Office Equipment & Supplies
is your printer is detected in the device manager settings??
Mar 05, 2008 | HP LaserJet 3030 All-In-One Printer
Setup/configuration issue, error message, scanner error 0x10. How do I fix this?
unplug power at the wall outlet
wait 5 minutes
press and hold the power/on button for 60+ seconds
keep holding while plugging back in, and for another 60 seconds after, then release if that doesnt work it is an internal fault which would require repairs or exchange in your case
Jul 19, 2015 | Epson Expression Home XP-420 Wireless...
Microtek Scanner thinks it's busy when it isn't
Check using a new USB cable. Unplug everything else plug into USB except for mouse and keyboard. If not work. Un-install driver and software. Download driver and latest software. Reinstall printer using driver only. Then use Paint to test it.
May 05, 2017 | Microtek MRS-1200X6U ScanMaker X6 Flatbed...
HP LaserJet 3030 showing "Upgrade Error - Call HP
This is very good & rugged printer better repair it, another five years service it will gives you. Just replace formatter assm P/No: Q2664-60001.
Sep 23, 2011 | HP LaserJet 3030 All-In-One Printer
HPLJ 3030 "Scanner Error -
Hi, unplugged its data cables for two hours. It exists inside the printer right or left hand depends on model. After two hours replug and you will see that your problem will have been fixed.
Best of Luck
Aug 28, 2011 | HP LaserJet 3030 All-In-One Printer
When I use the scanner I get a error of Scanner Failure Turn Power Off Then On. Window xp and is only when I use the scanner
hello
first you have to check if the it is software problem try to tr install the software first and if the message is still showing try to unplug the power from the wall outlet also at the back of the scanner after 5 minutes plug it again. if the message is still showing then is problem with the lamp of the scanner it is mechanical problem.
thank you
Mar 07, 2011 | HP PSC 2355 All-In-One InkJet Printer
Scanner error power on power off message come
the scanner under the glass has a problem. turn the machine on with the top cover open and see if you notice the scanner moving either to the left or right.
Mar 05, 2011 | HP LaserJet 3030 All-In-One Printer
Will not print. Message says
Your scanner bulb is not warming up. It would cost more to repair it than buying a new printer.
Nov 29, 2009 | HP LaserJet 3030 All-In-One Printer
HP Laser Jet 3030 not work
remove scanner glass and use compressed air to blow out the scanner
Sep 23, 2009 | HP LaserJet 3030 All-In-One Printer
HP LaserJet 3030 All-In-One Printer Logo
5,435 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
