Television will not power on?
When I try to turn my panasonic telivision on,the green power indicator light illuminates,then blinks,then instead of the screen powering on it makes a buzzing noise for about 3 seconds then stops,and still no visual and no sound. My T.V. was built in june 2006 and is 52 inches with a multi-media projection display;model#PT-52LCX16
Could you please tell me the possible malfunction and how to fix/replace? Thank You!!!
  • 579 Answers
TV's use high voltage to generate the stream of electrons traveling across the picture tube hitting the screen and lighting it up (thus the name Cathode Ray Tube). It takes about 25,000 volts to do this. In normal air, it takes about 1000 volts to jump an inch of air, so the high voltage transformer needs to have good insulation. It generates the voltage through a technique of charging the transformer's magnetic field with a low voltage of about 140 volts then letting it go where upon it flys back out the high voltage side at much high levels (Thus the common name flyback). A most common failure in a CRT type TV is for the insulation to crack in this transformer which is a unique component for each model of TV and leak out the current overstressing the circuit driving it. You can liken it to a little bolt of lightning getting loose in the circuit and has the same sound on a smaller scale.
It would be well to replace your flyback transformer before it gets worse and blows up something else as well. Best done by a professional used to handling high voltage. The picture tube can retain voltage even when the TV is unplugged for some time, and replacing the anode lead (the big red one) can be dangerous.
Hope Ya Fix It!
Posted on Mar 05, 2008
Turned itself off. I turned it back on and the green power light blinks for awhile then blinks red for awhile.no picture or sound
Get rid of this TV. Had one and replaced the bulb and light engine many times. Just buy a Samsung or Vizio 50+ inch instead and be very happy. Those Panasonic projection TV's were terrible. You will find a 50 inch Vizio for around $500 bucks and it will blow your mind how great the picture looks.
Oct 16, 2014 | Panasonic PT-50LC14 50" Rear Projection...
TV won't power on
Sounds like the bulb is not firing. I have the 44 inch model. Like it too. It is normal for the power indicator to blink for a minute or two AFTER the set has been turned off from running. get a phillips or panasonic TY-LA1000 bulb or a P22H 120 watt one if you can remove the old one from the housing (not very hard to do).
Mar 31, 2014 | Panasonic PT-52LCX65 44" HDTV
Panasonic pt-43lc14 won't turn on
Try checking your lamp door. I have seen a few of these that you need to really wrench that screw down. Let us know.
Mar 22, 2010 | Panasonic PT-43LC14 43" Rear Projection...
Panasonic PT-51HX41 51 inch
the blinking power indicator is actually a error code. How many times does it blink as I can assist you if you let me know how many times the led blinks
May 28, 2009 | Panasonic PT-51HX41 51" Rear Projection...
The Power Light is Red
yeah, should stay red when unit is turned off, indicating there's power but it's doing nothing.
Per user manual:
Solid red - power off (standby mode)
blinking red - power off (now cooling)
blinking green - power on (preparing to light lamp)
solid green - power on
Mar 08, 2009 | Panasonic PT-40LC12 40" Rear Projection...
Can you post how many blinks the power indicator is blinking as that is an error code such as 3 blinks means Convergence circuits.
Mar 02, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Power on
Depends on how many times it flashes RED.
On the units with fans (usually the HD models) a 6 blink flash code indicates improper fan rotation and the unit will shut down.
These blinks are counted as they go DARK, not as they light up.
Remove the rear panel but do not clean out the dust from the fans until you see which has the improper rotation.
Cleaning may help once you find the baddie, if not they will need to be replaced.
T Wiz
Jan 11, 2008 | Panasonic TH-42PWD7UY 42 in. EDTV-Ready...
Televison & Video Logo
271 people viewed this question
Top Televison & Video Experts
