Question about Intel Motherboard
Scanning bios image in floppy diskette
Hello mr.
how can I make bios image in floppy diskette ,
please tell me
zaw zaw
    President:
  • 2,351 Answers
You go to Gigabyte's web site. http://www.giga-byte.com/Products/Barebone/Default.aspx
Fill in number 1 & 2. Or No# 3.
Search for bios. Everything you need to know will be listed on that web site. If you post your Model # & or board No# with reversion no# . I can post the direct Gigabyte web site.
Posted on Mar 05, 2008
Floppy diskette seek failure during start-up
You can disable that by changing the boot sequence of your computer.
Turn on or restart your computer and watch for a message while your computer is restarting about a particular key, usually Del or F2, that you'll need to press to ...enter SETUP. Press this key as soon as you see the message.
You will a screen where it says BIOS Setup. Use the arrow keys to navigate to it and look for the option that says Boot Sequence or Change Boot Sequence. Each computer differs so I can't tell you the exact appearance of your computer's Bios Setup.
You can find the instructions on how to navigate in Bios by looking at the bottom part of the screen.
Change the boot order from there. Make your main hard drive as number one and the floppy drive in the last. You can see the instructions on how to do that in the screen in BIOS setup.
After changing the order. Save and Exit. It will restart automatically and observe if you still see the issue.
I hope this helps!
Please let me know if you need more assistance.
Carlo
Jan 26, 2013 | Dell Computers & Internet
Scanning bios image in floppy diskette !!! what can i do now? my pc can't open... please help
If there was a failure during a BIOS flash, you will have to contact Gigabyte and request a replacement BIOS.
It may be an easier alternative, albeit more expensive, to replace the whole motherboard.
Best wishes,
Graemevm
Aug 06, 2011 | Intel Motherboard
Hi, When I try to start my Dimemsion 5150C in Windows XP computer, I received one of the following error messages "Floppy diskette seek failure Strike the F1 key to continue, F2 to run the setup...
The "floppy" disk-drive (3.5-inch diskette) on your computer is broken.
Press F1 to ignore the error, and to boot from your C: drive.
Or, press F2 to enter BIOS SETUP, and then navigate through those "setup" screens to tell the computer to "disable floppy seek", or change the setting from "3.5 1.44Mb drive" to "none".
Or, take the computer to a technician, and buy a replacement disk-drive, and get it installed.
Sep 12, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
ACCESS A BIOS
I'm not quite sure what it is you exactly want here but if you need to get into the BIOS utility then as the computer is starting up repeatedly tap the Del key or the Esc key.
Regards.
Sep 28, 2009 | Gigabyte GA-945GZM-S2 Motherboard
When i turn on my computer all it says phonix rom bios plus version 1.10 A06 copyright 1985-988 phoenix technologies ltd. copyright 1900-2001 DELL computer corporation ALL right reseved dell system...
If there is a diskette in the diskette drive remove it. It's a bad diskette.
If no diskette in the drive the drive may be bad. Till you can replace it disable the diskette drive in BIOS.
access bios by F2 at boot up and disable the Diskette drive (Floppy drive)
Aug 02, 2009 | Dell Computers & Internet
Keyboard/floppy diskette error
try to unplug the power chord from the tower, press and hold the power button for 10 seconds. now try to turn the system on. still if u have the keyboard error try to reset the keyboard . still if have the same error get into the bios and load the bios default. For the floppy diskette drive seek failure, u have to get into the bios to disable the floppy diskette drive.
Jun 11, 2009 | Dell Dimension 4600 PC Desktop
try to go to bios set up..then change the boot order..in the boot tab,,change the "first boot" label with hard disk..then it wont seek for floppy again..
Jan 03, 2009 | Dell Dimension E310 PC Desktop
Diskette drive 0 seek failure
Does the PC have a floppy drive? If it doesn't It appears that your BIOS (Basic PC setup) thinks that there is one! I think that pressing f2 on boot will bring you into the BIOS setup.
In there, see can you locate any reference to 3.5 inch floppy and amend it to the setting which suits the config of your PC.
Please take care as to what other settings you change in the BIOS
If you find this sugestion helps please take time to rate it
Aug 30, 2008 | Computers & Internet
1 TB HD of Samsng is not recognized
some motherboards and processors are compatiable with certain hd's only. Here is a list:
Pentium: 2GB through 5GB
Pentium 2:5GB through 20GB
Pentium 3: 20GB through 40GB
Pentium 4: 40GB through 500GB
Pentium D: 40GB through 1TB
Celeron: 2GB through 500GB
All AMD's: 300MB to whatever.
so, that's probably your problem. I suggest
Jun 05, 2008 | Asrock K7VT4A-Pro Motherboard
Intel Motherboard Logo
340 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
