Question about Samsung HP-R5052 50 in. Plasma HDTV
I have a 42" samsung SP S 4243 plasma tv, i only get a black screen no sound and no picture, the fuse's are good what else would i need to check?
  • ziongigi Apr 23, 2008
    VERY DISAPPOINTED MY SAMSUNG 42 INCH HAD HALF BLACK SCREEN AND THEN FULL BLACK SCREEN WILL THIS BE EXPENSIVE TO FIX? SHOULD I JUNK THE $3,300 PIECE OF JUNK I BOUGHT OR SHOULD I HAVE IT REPAIRED. IT IS 2 1/2 YEARS OLD. I'M HAVING A NEW T.V.DELIVERED TODAY AND NOT SURE IF I SHOULD SAVE IT AND HAVE IT FIXED FOR MY GUEST BEDROOM.
Do you have any idea what this would cost aproximately?
Posted on Apr 23, 2008
  • 579 Answers
The power supply is having difficulty. The typical cause is underated electrolytic capacitors. I would examine all the caps (round cylindrical cans) in the power supply and see if any of them are bulged. Not a bad idea to just replace all of them with better rated parts.
These type of caps have all kinds of specs. Not just voltage and capacity, but also temperature, case size, and obtuse stuff like dissipation factor. Most all power supplies use switching type designs that run at serious frequencies (not the old 60 hz - more like 25,000hz) that stress out these electrolytic caps and many circuit designers (or their cheap bosses) don't specify the better parts. Replace them with the same capacitance, but higher voltage, and higher temp parts (hopefully they will not be too big physically).
Ya, I know you paid $$$ for this TV and they scrimped on cheap parts. Yup, the more expensive a product is, the more pressure the bean counters put on keeping the price down.
Hope Ya Fix It.
Posted on Mar 05, 2008
My samsung plasma becames black with sound but no screen after 1 min after turned on. we turn off the tv and turn on again and do it again.
Black screen on the PLasma TV can be caused by failed sustain boards and or power supply. I would inspect the caps on the sustain boards and the power supply boards first.
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Dec 08, 2010 | Samsung SP-R4232 42 in. Plasma HDTV
Can I replace a broken Samsung 42" plasma PN42B450B1D screen with a Samsung 42" plasma SP-S4243 screen? Are the screens interchangeable?
No, you cant. I have 2 tvs just like yours but the LN model is newer than the SP model tv. I have the same problem, my LN tv has a cracked screen and the other SP model is good
Sep 13, 2010 | Samsung SP-S4243 Television
No picture has sound samsung 42" plasma ed
check all your connection going to the tv,if good you probably have a power supply problem and need to replace defective capacitors in the power supply or the entire power pcb itself. you have to be a technicain to do this. make sure all power is off to the tv when removing the back of the set.
Apr 21, 2010 | Samsung SP-R4212 42 in. Plasma EDTV
Samsung plasma HPR4272 that had a 4" black vertical line on
There are at least two issues here. First you have bad buffer boards. Second Very possibly a bad X-Main bd and P-Logic bds. Have a trained Samsung tech troubleshoot the set.
Jul 03, 2009 | Samsung SP-R4232 42 in. Plasma HDTV
Samsung 42" Plasma -Black vertical line when turned on.
It sounds like an Intergrated Circuit (IC) has fried. Even on a good day, this is not something you can attack at home. As a tech (and as an owner of that model samsung), I'd need a map & tools to know what's going on. Your best bet in this situation is to contact Samsung and let them recommend an authorized service center in your area. Sorry I can't be of more help, but this is a rather serious problem.
May 25, 2009 | Samsung SP-R4232 42 in. Plasma HDTV
No picture or sound
This type of repair might not be a DIY since requires the use of a multimeter to check all the voltages from the power supply to all the circuitry in your plasma.
First step should be to measure all the voltages to the Y and X sustainer boards and since you do not have audio as well to check the 12 volts source as well.
If your plasma is less then a year old, still cover under manufacturers warranty.
Oct 20, 2008 | Samsung SP-S4223 42 in. Plasma EDTV
Audio but no video
If the screen is not illuminated this can be from the screen power supply, the main screen driver board, or the screen itself has failed. The service rep will change boards to service this, and adjust as necessary.
The set will require factory level service.
Jerry G.
Aug 20, 2007 | Samsung SP-R4232 42 in. Plasma HDTV
Electricity went out in town, tv won't turn back on.
On this type of problem, the first thing I check is the AC line fuse on the power supply. Follow the Ac plug wire to the power supply board and where it plugs in, you will find the fuse. If: Then: It checks bad. Replace it. It goes out again. Call a Servicer. It is good. Check for the five volts that goes to the Main PCB. No five volts, change the power suppy (SMPS) Five volts is there, more than likely the Main needs replaced and SMPS. For a Samsung Servicer in your area: 1-800-SAMSUNG
Aug 18, 2007 | Samsung SP-R4232 42 in. Plasma HDTV
Samsung HP-R5052 50 in. Plasma HDTV Logo
475 people viewed this question
Jerry Greenberg
Jerry Greenberg
