Question about Intellinet Active Networking Intellinet Wireless Router with 4 Port Switch (521246)
Configure with utorrent
My router is Intellinet 4port normal broadband router.
tel me how to solve these problems....
1)First i have to make a static IP ? (isp givin me dynamic ips)
2)In my router i have three type of methods to pass a port behind NAT. so how to do port forwading thing.
* port forwading
* virtual servers
*special applications (tigger port )
my default gateway is 192.168.2.1
DHCP 192.168.2.100 - 192.168.2.200
    Sergeant:
  • 221 Answers
1.) To set up a static Ip address on your computer, click start, control panel, network and internet connections, network connections, right-click on local area network, click properties. In the window select tcp/ip, then click on the properties button.
Since your default gateway address is 192.168.2.1. Click on the selection titled 'Use the following ip address' Your Ip address should be 192.168.2.2, subnet mask 255.255.255.0, default gateway 192.168.2.1. Then in the next section click on the selection titled 'Use the following DNS server addresses' Preferred DNS would be 192.168.2.100 and alternate would be 192.168.2.200. click ok and you are done.
2.) As for the second problem, refer to the following link from the intellinet website. http://portforward.com/help/pfprogression.htm
Posted on May 31, 2008
I NEED AWEP NOR AWPA FOR MY INTELLINET WIRELESS G
Get into the configuration mode of the router by using your browser and type 192.168.1.1.
Give your username & pwd(usually ...admin/admin) and then go to wireles security tab and select WEP or WPA.
Oct 19, 2009 | Intellinet Active Networking Intellinet...
Wireless side of 4port linksys router not working hard wired switch ports working unable to ping router using dhcp if i configure a static ip on my pc i can then ping 192.168.1.1
try a factury reset on the switch by holding the reset button and pluging in the power at the same time and holding for 5 seconds- reconfigure router as required.
Sep 30, 2009 | Linksys Wireless-G WRT54G Router
I am trying to do a setup for intellinet wireless but cannot get to the login in page
May I suggest you go to Cisco and get the evaluation version of Network Magic. Google Network Magic. They have a utility in that software, free download and free unlimited use for a week followed bu a most features enabled free for life use license.
That will take you right into the device and you can do what you want from there on.
Sep 06, 2009 | Intellinet Active Networking Intellinet...
Can't get my netgear PCI Adapter connected to my 2wire 1800hw broadband
You will need to modify the router configuration rather than the adapter to setup port forwarding. Normally Network Address Translation (NAT) will allow most of your services to connect without issue.
Nov 06, 2008 | 2wire HomePortal® 1800HW Router...
Cant find my routers Gateway Site..?
First you must make sure that the Ip address 192.168.2.1 is your routers ip address.
Click on Start, Run, type cmd, then click OK. Type ipconfig /all and hit the enter key. You are looking for the Default Gateway address. Use that address in your web browser. When you set up your static Ip address on your computer, use the first three numbers of your default gateway's address, then for the fourth number, add one. For example. If your default gateway address is 192.168.2.1, then your static ip address should be 192.168.2.2.
Try this and let me know what happens.
May 31, 2008 | Intellinet Active Networking Intellinet...
Intellinet Active Networking Intellinet Wireless Router with 4 Port Switch (521246) Logo
372 people viewed this question
Top Intellinet Active Networking Computers & Internet Experts
Prashant M
Prashant M
John Hong
John Hong
Are you an Intellinet Active Networking Computer and Internet Expert? Answer questions, earn points and help others
