Question about JVC KD-NX5000 Car Video Player
Screen goes blank intermittently
When the unit is working it is great. however, intermittently the display goes completely blank. the audio still plays but the display is dead. the only way to fix it is to detach/reattach the faceplate. only problem is that all memory functions are now reset (ie station presets, eq presets etc). total pain in the ass.
  • cjbdvm04 Mar 07, 2008
    i think that there may be a short btw the head unit and the face plate b/c if i wiggle the face plate, i can cause the problem to happen.
    Champion:
  • 227 Answers
Check to see if your constant(yellow) wire get a constant 12 to 14 volts. Goodluck.
Posted on Mar 07, 2008
  • hogan doan
    hogan doan Mar 07, 2008
    You could also have loose contact points between faceplate and unit. Try to tighten it up with screwdriver, and lift the contact points on the unit with a toothpicker to add more spring actions. But don't over do it because they are flimsy and break easy, and don't use a tweezer or something metal to do it or it will short out and fry your unit. Let me know if it help. Goodluck.
Tip
Sony Brava Blinking Code and their meaning
Hello,<br /><br />Below are some blinking code interpretations for your Sony Brava TV;<br /><br />ONE Blink--- not used for the self-diagnosis<br /><br />TWO Blinks---B+ over current protection (OCP) , unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.<br /><br />THREE Blinks---B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.<br /><br />FOUR Blinks---No Vert. Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505<br /><br />FIVE Blinks---AKB circuit (AKB), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking, try turning up screen slightly.<br /><br />SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.<br /><br />SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.<br /><br />EIGHT Blinks---Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401 and 402.<br /><br />NINE blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negative).<br /><br />TEN blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.<br /><br />Intermittent problems ?? This is a great feature. You can also bring up these fault codes ON-SCREEN to see a list of the problem numbers with the abbreviation of the problem and the number of times this problem has occurred. This is slightly different than entering the service mode. To see the diagnostic screen, Press the following buttons:<br /><br />Display, Channel, 5, Vol Minus, ( Not plus ) then Power. This brings up a screen with a list of the problems and number of times they have occurred. Each of the problem names is abbreviated as, "OCP", "OVP", "V STOP", ETC. We have repeated them in parentheses in the text for the "Blinks" described above so you can correlate between the diagnostic screen and the blink codes.<br /><br />So, now that you know about these self-diagnostics, how do you use them? Say that you have a set with a black screen. You see that the LED is blinking 4 times....This would tell you that you have no vertical and that is why the video is muted. If it was blinking 6 times, you would know that you have a horizontal fault.<br /><br />I hope I have helped someone.<br /><br />Regards.<br />
on May 17, 2011 | Televison & Video
Sony kv-13fs100 keeps on blinking four times when power button is pressed, no picture. have no cable.
Hi, below are Sony blinking codes are thier solutions...Hope it helped...
Jul 09, 2011 | Sony FD Trinitron WEGA KV-13FS100 13" TV
Acer Aspire blank screen
yes its a virus that's blocking explorer
a complete clean xp installation is needed to fix this problem.
rate plz
Mar 09, 2009 | Acer Aspire 5315 Notebook
Problems with Sansui VRDVD4005 DVD Player / VCR Combo.
the only problem i have is the remote reciever works only part time. I bought aa new remote control but didn't help.what do you think the problem is.
Mar 02, 2009 | Sansui VRDVD4005 DVD Player/VCR
Display Problems
your gpu has failed - thats graphics processing unit. new m/board required
Jul 12, 2008 | HP OmniBook XE3 Notebook
The base unit goes blank no display
I had this same problem. It turned out to be a bad power adapter for the base unit. If you have another handset that has its own charger than the power adapters are interchangable. try swapping them and see if this fixes your problem.
Mar 08, 2008 | Panasonic KX-TH111S 2.4 GHz Cordless Phone
Intermittent tuner operation
have you tried to move the switch to channel 4 on the back of the vcr ( you will have to watch the vcr on channel 4)
Jan 28, 2008 | Sony SLV-998HF VHS VCR
WS-65807 picture goes black when using HiDef Signal
Tank, If the unit operates correctly on DVD then we can assume that the signal chain and display is operational. Can you substitute the Directv receiver to rule the box out as part of the problem? I know they came out and checked but how exhausting was the testing? Have you checked signal strength on the directv on screen setup? Low or marginal signal strength could cause intermittent blanking. When the screen goes dark does the audio continue? please let us know..
Jun 11, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Display stopped working
My Alpine CDA-7842 works fine from a functional point of view but the display (readout) had stopped working. All the lights on the display work but the actual readout is blank. At first the readout would intermittently work now it's completely dead. Any assistance would be greatly appreciated.
thanks
Oct 26, 2006 | Alpine CDA-7842
JVC KD-NX5000 Car Video Player Logo
254 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
