Question about Dryers
MAGIC CHEF DRYER CYE2000AYW
THE THERMAL FUSES WENT OUT ON MY DRYER. I BOUGHT A THERMAL FUSE KIT AND HAD IT PUT IN. AFTER THE KIT WAS PUT IN, EVERYTHING WORKED. I DRIED A LOAD OF TOWELS WITHOUT ANY PROBLEMS. THE NEXT LOAD I PUT IN NEVER DRIED AND THE DRIER NEVER COUNTED DOWN FROM MORE DRY TO OFF. IT JUST KEPT RUNNING AND THE DIAL NEVER MOVED AND NO HEAT AT ALL. IT'S A MAGIC CHEF DRYER MODEL NUMBER CYE2000AYW. ANY SUGGESTIONS ON WHAT MIGHT BE WRONG AND HOW TO FIX IT WOULD BE SO APPRECIATED!
  • 156 Answers
Eather the element went out are the thrmal fuse 2nd time timer will not move if not heating
Posted on Mar 06, 2008
How do you install a thermal fuse kit on a Magic Chef CYE4000AYW. Unlike other models it doesn't look like you can just take the back panel off; do you really have to take the top and back off?
The thermal fuse kit is accessible from the top of the dryer. Disconnect power and using a putty knife, release the two spring clips holding the top cover to the cabinet. Insert the putty knife in the seam between the top cover and the cabinet at about 4 inches from the sides. Lift the top cover when the first spring clip is released while releasing the second clip then lift the top cover to the rear of the dryer.
The high-limit thermostat is located on top of the heater housing at the rear of the dyer. Remove the screw that secures the high-limit thermostat bracket and replace the thermostat.
The thermal fuse is located on the right hand side of the heater housing and is mounted on a bracket. There's a 1/4" hex-head screw that holds both the heating element and thermal fuse brackets. Remove the screw and the thermal fuse bracket can be lifted off.
The thermal fuse bracket has two locating tabs, one at the bottom and the other is half-way up. Lift the bracket to clear the tabs then remove it and replace the thermal fuse. Reinstall the thermal fuse and high-limit thermostat brackets in reverse order of the removal steps. Press down on the top cover against the cabinet to reengage the spring clips.
Apr 05, 2011 | Magic Chef Dryers
Magic chef dryer quit working
There is a thermal fuse inside the dryer usually located behind the back cover on the upper part of the combustion chamber. When this fuse "blows" it turns off power to the whole dryer. This keeps your house from burning to the grown, and you from dying. The fuse "blows" for a reason, most likely to is lint build-up in the dryer and/or dryer vent system. The good new it only cost a few dollars to get a new one. The bad news is you need to find out why it "blew", the dryer got to hot for a reason.
Mar 04, 2010 | Magic Chef CYE2000 Electric Commercial...
Magic chef cye2000ayw will not turn on
Aside from checking the breaker panel, it is likely the lid switch. Only other item that will cause this is the thermal fuse located on the vent after the element.
I’m happy to help further over the phone at https://www.6ya.com/expert/josh_87ce33216d7b2148
Aug 29, 2009 | Magic Chef Dryers
Dryer won't shut off. Heats fine. Timer advances on air dry only. Vent is not clogged. Can't find moisture sensor replacement part.
https://www.repairclinic.com/Shop-For-Parts/a8b104d87061/Model-CYE2000AYW-Magic-Chef-Dryer-Parts
The dryer requires cycling of the heat to advance thhe timer on auto dry cycle. see ,link provided parts and repair guidance. Always remove from power supply first.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Sep 30, 2017 | Magic Chef CYE2000 Electric Commercial...
Magic chef dyer
dryers have a 'thermal fuse' that will cause the whole thing to turn off. it seems like yours has burned out. it may be caused by a restriction in airflow, so when you replace the thermal fuse make sure you clean the exhaust or the fuse may go out again.
Aug 08, 2008 | Magic Chef CYE4000AWW Electric Dryer
Magic Chef Dryer model # CYE2000AYW
ck the thermo fuze and clean out the vent going out side ck the breakers to dryer
Mar 05, 2008 | Dryers
Dryer quit working
I have a Magic Chef Clothes dryer. Model #YE224LV. Was drying clothes, went back to ckeck and dryer wasn't running. Push botton and nothing. Check circuit breaker everything ok. What do I need to check and how. Just won't start.
Thank you!!!
Nov 11, 2007 | Magic Chef CYE4000AWW Electric Dryer
Dryers Logo
499 people viewed this question
Top Dryers Experts
Marvin
Marvin
