Question about InstallShield Update Service Version 3
Feature Transfer Error
I am trying to install a program called F9, which is a Microsoft Excel add-in for pulling financial data from a SQL database. In the installation process, I am getting a Feature Transfer Error and the message is Error: -2 Transform Package. I have been told this is a problem with InstallShield from the program vendor, but I have not been able to find a solution. Any suggestions?
  • Anonymous Dec 05, 2008
    I have the same issue. When attempting to do an update I
Conficio
  • 9 Answers
SOURCE: Running SQL queries on Excel
Yes, there is if you have Access as well. You can declare your Excel spreadsheet a data source in Access and then query using SQL. To do that, create a new DB and select Insert --> Table --> Link Table. Change "File of type" to show all files and select your Excel spreadsheet. Follow the wizard and you'll have a link to the sheet and can query it as if it were a table in access. However I doubt you really need that. Excel's functions should be a match for most queries. Can you give a sample of what you try to query (or why you want the SQL queries?
Posted on Aug 14, 2007
  • 17 Answers
SOURCE: SQL Server 2000
An easy way to transfer objects (tables, user defined functions, stored procedures, etc.) is to use Enterprise Manager's "Generate SQL" feature. Use this process at your own risk. Doing it wrong could mess up your existing database.
1. In Enterprise Manager, right-click on the old database and choose "All Tasks" then "Generate SQL Script".
2. In the dialog that comes up, click "Show All" then select the checkboxes for "all stored procedures" and "all user defined functions". (You might also want to check some other boxes, depending on your exact situation.)
3. Click the "generate" button and save the script that it creates.
4. Run the script in the NEW database.
If you run the script in your OLD database, it may destroy your objects, and that would be very bad. Make sure you run the script in your NEW database. (While we're on this subject, it's a good time to mention that you should back up your database before you start this process, and you should make changes to a test system before migrating it to production.)
That should move your stored procedures and user defined functions over.
You can use a similar process to move tables, views, users, and other objects over as well.
Posted on Jan 17, 2008
  • 17 Answers
SOURCE: Error while trying to login to database - Error establishing sokcet.
this page says you need service pack 3:
http://www.myeclipseide.com/PNphpBB2+file-viewtopic-t-7813.html
and here is Microsoft's information
http://support.microsoft.com/kb/313178
Posted on Jan 22, 2008
Bubbabear64
  • 2794 Answers
SOURCE: SQL 401: cannot open database
Sounds like a security issue with SQL server.
Check your SQL database connections. You will probably have to recreate them so that PC can have access to them.
Posted on Jun 10, 2008
SOURCE: Installshield 3 Help (maybe)
I didn't get a solution but the project was dropped. I don't have to do this install.
Posted on Sep 21, 2008
How do I recover data from .mdf file
Detach you database. Overwrite the mdf and ldf files you've restored from your backup with your files from the D: drive. Reattach the database.
There is no guarantee that this will work or if it works, that your database is in a state where you can continue to work with.
If that doesn't work then there is an option to try to restore database using SQL Server Recovery Toolbox. It is a powerful tool for data recovery. They have a demo version. So you can check it works in your situation or not.
http://www.oemailrecovery.com/sql_repair.html
Jan 19, 2016 | Microsoft SQL Server 2008 Enterprise Full...
Repair a corrupt SQL database in SQL 2005
Known as the leading solution provider in the field of data recovery and data conversions, the company has created a niche for another efficient tool known as SQL Server Repair Toolbox. The MS SQL repair tool reads *.mdf and *.ndf files and saves data, structure, links, etc. as SQL scripts or exports directly to Microsoft SQL Server through direct connect. read more details SQL Server Repair Toolbox
Jun 13, 2015 | Microsoft SQL Server 2005 Enterprise...
Creating a new database using an MDF file
An MDF file isn't a backup file isn't the main data file (or master data file depending on who you ask) hence the file extension MDF. You can attach the MDF to the database by right clicking on the databases folder in Enterprise Manager (SQL 2000) or Management Studio (SQL 2005) then selecting all tasks and then Attach Database.
When you do this you will get an error about the log file missing. This shouldn't matter as SQL Server will simply create a new log file for you.
This will only work if the SQL Server was stopped when you copied the MDF file from the old SQL Server. If you copied the file while the SQL Server was running this file probably will not attach either and you will need to get a valid backup of the database.
Download help tool for sql database - SQL Server Restore Toolbox.
http://www.sqlserver.restoretools.com/
You can read up more on SQL Server here.
http://www.filerepairforum.com/forum/microsoft/microsoft-aa/sql-server/498-creating-a-new-database-using-an-mdf-file?_=1416149856104/
Nov 16, 2014 | Microsoft SQL Server 2000 Standard Edition...
How to Fix Connection Issues in Microsoft SQL Server?
RecoveryFix for MS SQL database recovery software tool is an easy-to-use, more interactive and self-descriptive software for users who are looking to repair and retrieve .mdf files. You can try this software: http://www.recoveryfix.com/sqldatabaserecovery.html or download this software: http://www.recoveryfix.com/download-sql-recovery.html
May 12, 2014 | Microsoft Database Software A5K-02817 SQL...
How to Repair Corrupted MS SQL Database (MDF) File?
To choose a reliable and 100% safe and secure, a Microsoft SQL server database recovery program guarantee the zero loss of quality. You can see this page: http://www.en.repairsqlserver.net
See demo: http://www.youtube.com/watch?v=Q0aW1vT5nxA
How can I repair a corrupted MDF files and SQL server?
Similar question has been answered here: http://www.fixya.com/support/t24364927-sql_repair_recovery_process_very
Before asking any question in the forum, first you need to search your problem.
Im not able to instalthe primavera p6 on my new hp lap windows 7
Before installing primavera p6, check whether any SQL databases with the same name exists. Uninstall the SQL if the databases created during the previous failure installation of primavera p6(go to add or remove programs to uninstall). After uninstallation of SQL express, try to run installation files for primavera p6 will solve your problem.
Revert back for more assistance.
Dec 26, 2009 | Computers & Internet
Need Help to backup SQL database in safe mode
kindly choose the option safe mode with networking and then try.
Sep 10, 2009 | Microsoft Computers & Internet
Steps in saving file in excel to database
severals solution :
- save file as text separated by comma and use sqloader from oracle
- use function in excel to concatenate insert order : "insert into TABLE_NAME (field1,...,fieldn) values (A1,B1,...,??n);". Save file as text with sql extension. Connect against roacle db and execute file previously saved.
- use ODBC from MicroSoft
Dec 11, 2008 | Microsoft Computers & Internet
Another way to do it is to use the SQL Drill freeware Excel addin (http://www.sqldrill.com)
hth
Aug 14, 2007 | Microsoft Office 2003 Basic Edition...
InstallShield Update Service Version 3 Logo
482 people viewed this question
Top InstallShield Computers & Internet Experts
Robin Hill
Robin Hill
Alex Krenvalk
Alex Krenvalk
Jon Slaton
Jon Slaton
Are you an InstallShield Computer and Internet Expert? Answer questions, earn points and help others
