Question about HP PhotoSmart 7760 InkJet Printer
Not coming on
I left my printer on, forgot it overnite, and the next day it was off and refused to come back on
  • 1 more comment
  • KiwiTrader Apr 15, 2008
    We had a similar problem, in that we turned the printer off and the next timw we went to use it it's a no-go. I'm not sure if it's a lead problem or a printer problem but it seems as though there may be no power getting to the printer, no lights come on or anything.
  • tigrefire Apr 22, 2008
    Our 7760 printer similarly will not turn on. I had checked one of the cartrigdes and did not get the lid snapped down and it got caught on the left side. I was able to get it unstuck but now it will not come on. It almost as if it has blow a fuse. I have disconnected the power line for 15 minutes or so hoping that would reset on reconnect. Unfortunately, no luck??
  • tjohnson1800 May 12, 2008
    We lost power and the printer and computer went down. When power returned, I restarted the computer but cannot get the printer to power up.
    Problem Solver:
  • 6 Answers
Try replaceing the fuse in the plug of the power lead , if not then unless it was pluged into a surge protector then it may have blown the power pack :-(
Posted on Jun 21, 2008
It won't turn on
Verify the power supply unit fuses.
Feb 21, 2013 | Canon PIXMA MX330 Multifunction InkJet...
I turned off d7360 printer. Next day it refused to
unplugged printer and discounected the usb cable from computer. Waited 2 minutes and replugged. Turned on PC and the printer responded. Thank you for the info.
Jan 20, 2010 | HP Photosmart D7160 InkJet Printer
Refuses to recognize ink cartridges
Apologies for not responding earlier, forgot all about it. Solved problem by switching printer on and off many times. It eventually recognized cartridges. Now leave it switched on.
Jan 07, 2010 | Epson Office Equipment & Supplies
1999 Series2 Discovery rear suspension stays up when static and set to hi level. At normal level sometimes drops in 1 hour sometimes overnite, stopped to collect luggage dropped immediately didnt raise,...
Probably an air leak in one of the bags (£100 or so), should replace it as your compressor will be working harder than it should be, and will eventually also fail!
Could also be the height sensor (£35) but that is less likely.
Nov 14, 2009 | 2001 Land Rover Discovery Series II
Sansa E700kepts re-setting
You can try to reset the device by pressing the power button for about 15 to 20 seconds..if that doesnt work I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Dec 21, 2008 | SanDisk Sansa e200 MP3 Player
I have an electrical, problem the battery is being drained overnight and i can't seem to find out what is causing the problem ,any ideas?
start with battery. sometimes older batt. won't hold a charge overnite. disconnect battery and reconnect next day and check. if batt is ok disconnect alternator overnite and connect next day to see if it was problem.
Aug 12, 2008 | 1997 Dodge Stratus
Akai tv wont come back on
Nothing......bad capacitors in power supply need replacing.....T.
Jul 16, 2008 | Akai LCT2716 27 in. LCD Television
Help!Phone does nothing!
Ok you need to replace that charger cos thats the one that is doing all the damage. Check your battery voltage if its below 3v then you need to rejuvenate it back to its original capacity. It will be ok good luck.
Jul 02, 2006 | Samsung VM-A680
HP PhotoSmart 7760 InkJet Printer Logo
48 people viewed this question
Ben Johnson
