Question about RCA 25202RE3 Corded Phone
Line 2 stays lit even though I don't have a second line
I've had the phone a year. I bought this two-line phone even though I have only one line. The problem is that sometimes line 2 stays lit and I can't get a dial tone. I've tried another phone in the outlet and it works fine. Am I doing something wrong? Thanks for your help
I would like to add a fax machine to my unused 2nd line. What is the proper way to hook it up so it does not interfer with my regular phone line #1? Please advise
Posted on Mar 17, 2008
I have two lines lit up that will not disconnect
when you press the line button it may say "in use" and the have a extension #. That will tell you which phone or port has seized it.
May 08, 2012 | Nortel T7316E 2-Line Corded Phone
Redial Button on IBM-412CID stays lit
Try unplugging power, and see if this simple reset can help.
Oct 08, 2008 | IBM Corded Phone IBM412CID
Avaya Partner line always lit
If the line button is lit then something within the system has picked it up. If the phone is a multiline set, the line 1 light on the set that is using the line will show green. The line could also be held by either a cordless phone on the system or the voicemail system. The easiest way to clear the line (if the held set isn't apparent) would be to cycle down the power to the phone system for a moment. That will clear the line if its held by the voicemail
Jun 02, 2010 | Avaya Corded Phone avaparp18d
So much static I can not hear properly
The line that stays lit for line 2 is just the way it is.. not a problem. If you only have one phone line and a two line phone you will always have the one (non working line 2 ) lit.
Have you replaced the cord to the handset? Many times it is a bad cord that causes static.
May 11, 2010 | RCA ViSYS 2-Line Speakerphone
Line 2 stays lit with red light
I think that just means that you do not have a 2-line connection to the phone. Either your cord is a 1-line cord or your 2-line cord is plugged into the wrong jack on the back of the phone,
Apr 14, 2009 | RCA 25202RE3 Corded Phone
We have the AT&T 2 line digital answering system #1872.
Unfortunately, there is no way to turn that light off. I had the same situation and researched, called help lines and even had the phone company out to check. The light will stay on. but there is no service to it.
Feb 20, 2009 | Lucent 1872 Corded Phone
Suddenly line 2 only works on wired phones
Here are a couple of things to try. First is to disconnect the base and install a regular two line phone to verify that line 2 is ok at that jack. Also on Panasonics website, when you unboxed and installed that unit, there was a cord that had green plugs on it. That was a 4 conductor cord. If somebody changed that out to a 2 conductor, it could cause this. Also it could be a defective cord. If you have another 4 conducter cord from the wired phones, swap it out. Make sure on the base, on the back, that it is plugged in to the correct plug, marked line 1/2. Basically if a regular 2 line phone works, it is possible that the unit is defective. Also maybe unplugging the base from power and resetting that may fix it also.
If that does not help here is Panasonics number.
1-800-211-PANA(7262)
Jan 05, 2009 | Panasonic KX-TG2740 Cordless Phone
RCA executive series
No ringer could well be a setting and light on 2nd line means their is No 2nd line and most 2 to 4 lines phones at least require 2 active lines for the system to work correctly
Mar 30, 2008 | RCA 25202RE3 Corded Phone
No Dial Tone
If you are sure that both cords are good (use another phone to test), make sure the Speaker button light is off. If both lines stay lit up when the phone is on the hook, your phones has problems. Can't help you there.
Hope this helps, and please rate my advice.
Nov 24, 2007 | RCA 25202RE3 Corded Phone
Line 1 stays lit
do you have your phone plug, inserted into line 2?
Aug 31, 2007 | RCA 25202RE3 Corded Phone
RCA 25202RE3 Corded Phone Logo
235 people viewed this question
Top RCA Lands Phones Experts
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
