Try replacing the high limit switches if the element is fine. The limit switches will not allow power to the heat strips if they are blown. They are the little silver buttons on the heat strip. There are usually two wires connected to them one coming from the controls and one from the heat strip itself
Dave
Dryer wont element good also limit sw good
SOURCE: not drying no heat.
be element are thermo fuse on element no easy to change remove 2 screws on door hinge 2 screws on the ather side frount comes off there the element
SOURCE: blowing cold air-no heat to dry clothing-how do i know it is the heating element that is bad?
you have to see if you see any broken wire on it,also there should be a fuse on the top left side of the heater box at might be bad,let me know what you find-mike
SOURCE: LG Dryer won't dry, no heat.
The heating coil is not too big of a problem to replace if you are mechanically inclined and have tools to do the job.
If you plan to try to repair the problem yourself, then the first thing you want to do is unplug the dryer from the electric.
Remove the back of the machine and try to locate the air tube going from the blower to the drum. Normally inside the air tube you will find the heating coil and the thermostats/thermistor.
Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the saftey of overheat from the machine.
Good Luck,
Hope this helps
