Question about Hotpoint FFA60 Bottom Freezer Refrigerator
UPRIGHT FREEZER HOW CAN I STOP CONDENSATION DEVELOPING ON THE UNDERNEATH OF TMY FREEZER ? Tim. Tim@MsnSport.com
    Sergeant:
  • 288 Answers
Some units have a selector switch that says; reduce moisture/save energy. If you have this its obvious what to do. If you don't have one or are getting condensation anyway, check the door gasket. Make sure its getting a proper seal. The outside air has water in, aka, humidity. If the unit sucks air from outside, as it cools it will condense and make dropletts accumulate on the top. The drainage from the defrost may also be seeping in and cause the water too. Especially if its on the bottom. It may have a clogged drain line.
Posted on Mar 05, 2008
My Haier Chest Freezer started releasing water from underneath. It´s 2 years old
A Freezer usually has a condensor drain coming out of the compressor, that empties into a condensation dish underneeth, where condensation water is picked up and Re-evaporated.
It is most likely that your Drain is clogged.
Happened to me.
Have someone check your Drain, and if needed unclog it with a small prying tool into the tube.
Sep 21, 2016 | Haier Freezers
It's leaking water from underneath the unit
Hi there, I know that most units have a drip tray at the back or under the unit itself. well the older ones anyway, not sure with really new ones, but they shoukd. these trays hod water condensation and any drainage from the fridge itself. These trays sometimes have a coil in them which heats and help to evaporate the waterso that it does not overfill and spill out. these trays can become overfilled, the heating elemet can stopworking or
Jun 01, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Purchased ColdTechCommercial Freezer CFD-3F from private seller. Freezer was used for 9 months then sat in a garage for almost two years. Freezer turns on and runs, but doesn't cool at all- in fact,...
Hose underneath is probably for condensation and defrost water. If the compressor is not coming on, there is a good chance it is the thermostat. There is always the possibility that there is a refrigerant leak and it leaked down over the 2 year period. This is where I would start.
Jul 08, 2017 | Coldtech 72 cu. ft. / 2039 liter Upright...
My freezer is still running and the inner walls are still cold but all the food is thawing out. The compressor is extremely hot and the little plastic container underneath by the compressor is full of hot...
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Aug 13, 2010 | GE FUF14SVRWW Upright Freezer
Making alarming buzzing sound. Still freezing fine
putting unfrozen food in a freezer can raise the temp to cause it to go off allow 24 hours for it to stop if it dont replace the buzzer
May 23, 2010 | Whirlpool Upright Freezer EV161NZRQ
Freezer has lost its suction & no longer freezing!
Depending on the age of the unit it does take a 134a freon charge or 12 or 22. when fully charged unit should cool properly. need to check door seal for suction issue. the unit does need a good charge to cool. it could also be a restricted sealed system issue.
Jun 21, 2009 | GE 17.1 cu. ft. / 484 liter Upright...
Upright freezer door inside developing ice
The door seal is at fault. Regardless of the small tear it is not sealing well.
Take a dollar bill and close it in the door. Then pull on the bill to feel resistance.
You will find it pulls easily in some place. That is where your air leak is that is causing the condensation.
Do this about every 6 inches all the way around the seal.
Mar 27, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Got another question about a freezer
I have seen freezer stop working because the owner pulled it out to clean behind it and pushed it back into place too far. This "Chocked" the air flow around the condenser and caused the failure. Be sure condenser is clean and air can circulate. Older units have coils up the back and newer ones have them underneath and utilize a fan. You can use a vacuum on the the underneath ones. Be sure fan runs under there.
Jan 07, 2009 | Freezers
Hotpoint FFA60 Bottom Freezer Refrigerator Logo
225 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
