Question about Brother MFC-7820N Printer
Drum Hi, I have an error code that says CHANGE DRUM SOON. How do you do that ? Is it something you can buy and change or do you need a serviceman to come out?
  • jruffino Mar 05, 2008
    Still need a solution for this problem?
You can buy a new drum online, or from your office supplier, or you could reset it if you want to take your chances with an old drum, it is very expensive to replace, I don't replace mine, but replace the entire printer when it stops working.
1. Open the front cover.
2. Press the Options key on the control panel.
The display will show "REPLACE DRUM - 1.YES 2.NO".
3. Press 1 to reset the drum count.
4. Close the front cover.
Posted on Apr 12, 2008
    Sergeant:
  • 406 Answers
This is the costliest and a precise part of your machine. Kindly do the needful to visit nearest service center they will assist you in the best way.
Posted on Mar 05, 2008
Error code "change drum soon
This is NOT an error code...the machine is simply telling you that it has run/printed a certain number of pages and it will soon be time to replace the drum.
Oct 27, 2010 | Brother IntelliFAX 2800 Laser Fax
CHANGED DRUMAND THE CHANGE DRUM SOON ERROR IS
you need to open the front cover (where drum and toner is installed) and press the options button, it will ask replace drum? Press 1 for yes and close the front cover.
Apr 15, 2010 | Brother IntelliFax-2820 Laser Fax
CHANGE DRUM SOON
You will need to replace the drum soon. Once the drum life ends you will no longer be able to print.
The model drum you need is DR-510, It goes for anywhere between 175-250 dollars, depending where you buy.
Apr 08, 2010 | Brother DCP-8040 Copier
Hae brother MFC-8500 and just replaced
This is an easy one. With the power on, open the front door, where you installed the drum. Press the CLEAR button. The display will ask something like, "Change Drum? Press 1 for yes. Press 2 for no."
Press 1.
Close the front door.
Feb 10, 2010 | Brother MFC 8500 All-In-One Laser Printer
Error code: change drum soon
open front door, press "options" and follow prompts. once it says "accepted", close front door.
razors
Jan 19, 2009 | Brother DCP-7020 All-In-One Laser Printer
THe light below the ink lights is on is this the drum that needs
I think your drum is faulty change it with new one.
Because the issue comes up again if the serviceman use local parts so it will happen again and again.
contact your previous printer serviceman.
Or
If you want to leave out your tension purchase a new hp toner.
Best of luck.
Dec 08, 2008 | HP LaserJet 2550L Printer
CHANGE DRUM SOON
You need to change the drum on your printer. Part # DR-350.
Thanks and please take a moment to rate as fixya.
Nov 06, 2008 | Brother MFC-7220 All-In-One Laser Printer
Error code E004
the error has nthing to do with the drum!!!!!!!!!!!!!!!!!
I can tell you how to change it,but it will still have the code.
You have either a blown fuser lamp or thermofuse, you should change that before the drum since you still won't be able to use it?
Oct 28, 2008 | Canon NP 6050 Copier
"Please change PC Drum" message appear on printers LCD
If your print job prints ok, ignore it. Just bear in mind you'll need a new drum soon. The drum is a light sensative roller that ink from the toner cartridge adheres to where the laser hits it. When it is no longer magnatized enough to hold the toner you'll see your print jobs start to lose that toner color. Just pull the drum out, buy a new one and put it in. Just don't expose the drum to light very long.
Oct 24, 2008 | Minolta Di2510 All-In-One Laser Printer
"Change Drum Soon" Message; not change when we changed the drum.
Description:
This message would continue to appear if the drum counter was not reset when you replaced the drum. To reset the drum counter, follow the instructions listed below.
Aug 07, 2008 | Brother MFC-7820N Laser Printer
Brother MFC-7820N Printer Logo
261 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
