Question about Nintendo 64 Console
N 64 hooked up system but screen is black on tv
  • 1 more comment
  • mr_m_pohl Mar 16, 2008
    Same thing. light is on on the system but no picture or sound.
  • corthew Apr 22, 2008
    Solution for Black Screen and No Sound:
    I was having a problem with the N64 having a black screen when started
    up with a game in. Any game tried did the same thing. I cleaning kit
    and used it to clean off the terminals on the games and the game slot
    and it now works fine.
  • crash25 May 11, 2010
    is the red light on at the front of the 64?
    President:
  • 894 Answers
Well I think that its broken then like it sounds like a power supply issue or and a laser assembly failure so you will just have to buy a new one then.
Posted on Aug 24, 2011
My sons Nintendo 64 stop working for no reason, it turns on but is just a black screen on the TV. What can I do? Please help.
Posted on Apr 22, 2008
    Problem Solver:
  • 10 Answers
Check analog/digital
rca or antenna in
Posted on Mar 29, 2008
When turning on my N64, the power light turns on and I have a standard AV cable hooked up, but the video will not come through on the TV.
Step 1:
So you've eliminated the possibility of bad cables. Now you need to eliminate the TV and the Nintendo 64 itself.
Step 2:
For the TV, you can try another TV or make sure that you have the TV set on the right input.
Step 3:
If you can't make it work on an additional TV and you have made absolutely sure that the TV is setup correctly, then you may be looking at a broken Nintendo 64.
Jan 23, 2013 | Nintendo 64 Console
Cant get nintendo 64 hooked up to flat screen
Wow, the classic Nintendo 64. That was my first gaming system. I do know that the 64 has default RCA cords (Red, Yellow, White). They are required to be inputed into your TV. Make sure the 64 is plugged into a power source and that it turns on. Make sure that your game actually works. Clean out your 64 by using a can of compressed air, do the same to your game.
Finally try to start it up.
If I helped in any way please rate me and help me out.
Thanks,
Brandonmxb
Dec 11, 2009 | Video Game Consoles & Games
What cord do I need to attach tv to super nintendo game system
Here is a tutorial to hooking up a super nintendo
http://www.youtube.com/watch?v=9O4kjcXyZKI
Oct 09, 2009 | Video Game Consoles & Games
Nintendo 64 to jvc hdtv
Check all of your plugs, make sure they are clean. Make sure the game that you have inside the system is clean and free of dust as well as the game connector port on the system. Make sure you are on your A/V channel. If all else fails, you ma have to gt a new A/V plug. When I got my Nintendo 64, I tried to plug it in to my TV using the plug that came with it, but it did not work. I soon found that the Playstation 2 A/V cable that I have also has two additional cables to it, and one of them works in the N64 system. So, I tried to play the system with that cable plugged in, and it worked, so I would suggest buying a new A/V cable that works in the N64 system.
Hope this helps!!!!!
Please Rate
Jun 28, 2009 | Nintendo 64 Console
N64 isn't working with Vizio HDTV...
Do this, hook it up to another tv just to make sure that the N64 is workig properly. If it works on another tv then you know the system is fine. If it doesn't work on another tv then it could be that you have dirty games and you need to clean the contacts and then reinsert them into the system and get them to work.
Keep the system on a known good working tv until you can get your games to work and display properly. You can clean the games by using a damp q-tip and wiping the contacts on the bottom of the game back and forth a bunch of times, there will probably be all kinds of black that comes off.
keep on trying games untill you get one to work and display properly, then go ahead and move the tv to the one you want it to work on and test it out and it just might work then.
Jun 26, 2009 | Nintendo 64 Console
My nintendo 64 wont come on, ON the tv.
You need a switch (transformer) to connect it to the incoming signal antenna screws. You will probably need to adapt it to a cable tv plug. The wires you connected are for the sound.
Mar 17, 2009 | Nintendo 64 Console
Says unusable signal when trying to hookup my Nintendo 64.
Here are a couple of things to try. Go into the menu and make sure that you have the "ANTENNA" selected instead of "CABLE". Also make sure that the channel that you are using (3 or 4) is programmed into the memory of the tv. If not, use "auto program" in the menu to program the channels.
These newer tv's are not the same as older tv's. If none of that works, put a antenna amp on the output of the nintendo and then plug it into the tv. This should fix it.
Nov 17, 2008 | Televison & Video
My nintendo light comes on but the screen stays blank
Clean the control deck and the cartridges. Check the input cable to the TV.
Hope this helped :)
Oct 26, 2008 | Nintendo 64 Console
Screen problems
cuse old style output not made for new tv 480 i made for tube tv only
Feb 05, 2008 | Nintendo 64 Console
Nintendo 64 Console Logo
230 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
