Question about HP LaserJet 3030 All-In-One Printer
Scanner error message
When I turn it on, it reads "scanner error turn off turn on" when I turn it off and on....it reads the same message??
Any suggestions??
  • 5 more comments
  • leesalouski Mar 05, 2008
    How do I check this
    I have it plugged into the wall. It's not hooked to a computer. I've just been using it for a copier.
    Is there something I can do with the scanner, to check it? Is there a diagram I can follow or something I can do?
    OK I did as you said and reset the machine..it restarted and gave the "bulb warming" display...as I waited it was making a funny sound...the best I can describe it is a deep creeking...like it was trying to move something that wouldn't move. Then the same error message came up again " scanner error turn off turn on"
    tried this, no spots or breakage on the scanner bulb, when I turn it on and open the lid to watch the bulb it seems to be fine, just the sound of when it's moving that doesn't sound right
    I'm not sure how to do a filmware upgrade??
    yes the bulb seems to work fine, no spots, good and white all the way across...just the funny sound ( like a mechanical grunt??) right before the error message comes on...I tried to pull it apart and pull the scanner clear over to the left and then restart...it just slowly works it's way to the right, fully lit, and when it goes clear to the right it makes the grunting sound and the scanner error message shows up
    Master:
  • 788 Answers
To try to bring the scanner carriage back to its home position try this:
Unplug the power from the unit, plug the power back in, wait until the unit reads " Scanner Bulb Warming Up" Unplug the power. Repeat this cycle 5 times (or more).
This will hopefully bring the scanner assembly back to its home position.
Also make sure the power comming from the wall is good. Try a different outlet in another room. Try a reset too, unplug for 20 seconds. Press and hold the power button while to reinsert the power cord. Release the power button when the unit comes on. Otherwise either the carriage is stuck or the bulb is burnt. You could try to open the scanner and look for broken pieces or a stuck carriage, also look for black or brown spots on the bulb.
Good Luck!
Posted on Mar 05, 2008
  • 4 more comments
  • Dean Joly
    Dean Joly Mar 05, 2008
    HP has a trade up program, you may be able to get a discount on a new machine if you're willing to send this one to them and but the new one directly from HP.
  • Dean Joly
    Then it would seem as if the scanner carriage is stuck. Is there a moving lock on this machine??? If it's locked the carriage will not be able to move. Otherwise, you may want to open up the scanner and examine the motor, belt, and guides for blockages/broken pieces.
    Your next option is to purchase a scanner assembly from the hp parts store.
  • Dean Joly
    I did some more reading and sometimes a firmware upgrade will fix this issue. The firmware is available here: http://h20000.www2.hp.com/bizsupport/Tec...
  • Dean Joly
    Dean Joly Mar 06, 2008
    Sounds like the scanner doesn't know where to stop. Can you see a switch or sensor on the right side that would be activated by the scanner carriage when it reaches the end? Or is there an encoder strip like there is in the printer compartment? Could be the trailling cable connected to the carriage. Check to make sure these parts look OK.
    From searching HP Partsurfer they only sell the scanner assembly as a whole and not the individual parts. The part number is Q2665-60116, I've seen it refurbished for under $100 and new for about $300. How much is this printer worth to you? Should be fairly straight forward to replace the entire assembly if you've already checked it out.
  • Dean Joly
    Also sounds like it might be the motor, but again HP doesn't seem to sell it seperately.
  • Dean Joly
    Upgrading the firmware is really easy. Just download and run it. It will as which printer to upgrade, pick it in the list. Then click send firmware. Couldn't be easier!
  • 818 Answers
Ry this
suggest you to perform a restore factory default settings on the printer.
To restore the factory-set defaults
On the all-in-one control panel, press Menu.
Use the < or the > button to select Service, and then press .
Use the < or the > button to select Restore defaults, and then press .
The all-in-one automatically restarts.
  • 2 more comments
  • Sergio Scalfaro
    Sergio Scalfaro Mar 05, 2008
    Sounds like the Scanner Bulb is not getting to the aligment area. It is either stuck or teh glass getting dirty. if you cant restore the default problem, it is the scanner module to replace.
    Sergio
  • Sergio Scalfaro
    open the page of firware that i have sent,
    This utility is for use on Windows 98SE, ME, NT4, 2000, XP, and Server 2003
    Depending on the speed of your PC, the firmware update process may
    complete on the printer, before the progress bar on the screen
    completes. Once the update process has started, do not use your PC for
    other activity until the process is complete.
    • Download the file to the desktop.
    • Save all work and close any open applications.
    • Turn the printer off and then back on to clear main printer memory.
    • Double click on the flash update utility file
    • Use the "Select the Printer to Update" dropdown control to
      choose the printer you are updating. Note: Don't select the fax driver.
    • Click on the "Start" button to begin updating the firmware.
    • The progress bar will begin to move to the right indicating information being transferred.
    • DO NOT power cycle the printer or the PC during this process
      or the printer may become unstable and or unusable without further
      attention from HP . The firmware update can take up to 5 minutes to complete. Please be patient.
    • During the printer firmware update, the liquid crystal display
      (LCD) on the printer control panel will display "Printing Document" and
      will change to "Erasing". After a short while, the LCD display will
      change to "Programming". After a short while, the LCD will display
      "complete : )" and the "Ready" LED on the printer will be flashing. The
      printer will automatically power cycle to reboot and will make noises
      similar to power on.
    • In the "LaserJet AiO Flash" window on the PC, a smiling face
      will appear when the firmware update is complete and successful. Click
      OK to close the "LaserJet AiO Flash" window.
  • Sergio Scalfaro
    if not to work, contact the hp support for change the scanner.
    Sergio
  • Sergio Scalfaro
    the scan module of your hp
    Sergio
  • 4,102 Answers
Hi try this for me ok
1 press menu/enter
2 press left arrow key
3 then menu button twice or untill it says restore defaults
4 then press menu/enter key again
this should reset the printer for you ok
  • 2 more comments
  • paul proctor Mar 05, 2008
    Hi it sounds like the motor that moves the light under the glass is up the shoot how long have you had the printer
    The problem is as you have been only using it as a copier then the chances are the motor needs repalcing they are not really made to be used as copiers as such they are made to do the ocasional copy if its had alot of use as a copier then the problem will be either the motor or the runners jammed as its telling you scanner error that means that the scanner part of the printer has a fault usually the motor or even the runner has been over used causing the motor to jam.
    This can be repaired but can be expensive probably as much as a new printer so its not really financially worth getting repaired.
    Have you had the unit from new if so how old is it
    Hi does the bulb light up when its swithced on after factory reset
  • paul proctor Mar 12, 2008
    Hi sorry have been offline for a while the chances are the problem is now something mechanical and more than likely out of your control the cost of getting repaired would be more than the printer as its probably the running gear and motor that needs replacing so i would be replacing it instead of repairing.
  • 796 Answers
Is your printer is detected in the device manager settings??
  • isaac johny
    isaac johny Mar 05, 2008
    have you tried reinstalling the driver??
3 Suggested Answers
  • 17 Answers
SOURCE: HP Officejet g85 All-in-One error
Power on the printer, wait around 15 seconds until the bulb assembly moves a bit to the left and the light goes on, then immediately power off.
Repeat the process around 15 times (or more) until the assembly has moved all the way to the left of the glass, and is located directly beneath the small glass on the left.
Remove the single screw that holds down the small glass.
Carefully remove the grey frame around the small glass.
Carefully remove the small glass.
Using a dry Q-tip, carefully insert it into the slot (to the left of the bulb) and clean the mirror. I found mine was coated with a layer of film, as if grease had accumulated over time.
Put everything back together.
Turn on the printer.
Posted on Feb 04, 2008
SOURCE: error message
disconnect power from printer for 30 seconds. Hold down # and 6 at same time when you plug it back in.
Posted on Feb 23, 2008
Show error 52.00
Note this a not something users can repair themselves. It is a fault with scanning motor. may need motor or whole scanning assembly to be replaced. Only service centre can perform this.
HP LaserJet 4200 and 4300 Series Printers - Numerical Error Messages 52.XY PRINTER ERROR For help press? alternates with 52.XY PRINTER ERROR To continue turn off then on
Description
A temporary printer error has occurred.
X Description 0- Scanner error
1- Scanner startup error
2- Scanner rotation error
Action
  1. Press the (Select) button to continue.
  2. Turn the printer off and then turn the printer power on.
  3. If the message persists, contact HP Customer Support.
The laser scanner speed is incorrect. X description: 1 = Scanner startup error 2 = Scanner rotation error.
1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner. HP LaserJet 4200 and 4300 Series Printers Numerical Error Messages
Apr 16, 2016 | HP LaserJet 4350n Printer
How do I solve the "scanner failure power off and on again" message for an h.p. 6110 officjet all-in-one printer/scanner/fax?
Hi Paul,
Scanner Failure usually results in Hardware Failure. However there is one step you can try. Try connecting the printer directly to wall outlet or any other power outlet and the issue should be resolved.
Regards,
Sean
Apr 19, 2013 | HP OfficeJet 6110 All-In-One InkJet...
My cx3200's control panel reads scanner error. I unlocked the transportation lock, turned off, turned on. It stayed off for about 2 minutes then came right back on. While the error light was off tried to...
The only things that can cause a scanner error on this unit is a complete scanner harware failure or the scanner lock. With the unit on lock the transport lock and unlock it a few times quite forcibly. Then leave it in the unlocked position and power off and on again. If the light returns then at his point I think a new printer will be needed.
Jan 18, 2010 | Epson Stylus CX3200 All-In-One InkJet...
The error message reads: "Scanner failure. Turn power off the on again." When I do that, it just gives the same error message again.
You have a bad scanner unit. Getting it repaired will cost as much as buying a new machine.
Oct 16, 2009 | HP 190 Copier
Error Message Reads: Check Scanner Unit E01-31
try checking the scanner cable . look through the glass back right . you will see a usb cable.. check both ends.. if there connected properly and you still get the error.. you need to replace the whole scanner unit
Oct 14, 2009 | Panasonic Panafax UF-9000 All-In-One Laser...
Scanner twain driver will not install
Dear sir,I am sory for your problem.Please format your oparating system i mean you install new windows.some times optical driver did not read properly data cab file,So hardware driver is not support properly.Windows xp SP3 is not complite version some messing.
Thanks You are success
Tareq
Aug 27, 2009 | Epson Perfection V300 Film Flatbed Scanner
Aficio 551 - error code SC124
Definition- [B]
No encoder signal from the scanner motor
-Possible cause-
• Scanner motor connector defective
• Scanner motor defective
• MCU defective
• Scanner wire, timing belt, pulley out of position
• PSU defective
The screws of the pulley usually are cut that moves the scanner this causes that the car is crossed and that the sensor does not detect the home position. check and corect this defect.
Mar 03, 2009 | Ricoh Aficio 450 Copier
CANON PIXMA MP830 Error Msg: Scanner not working correctly.
the error message: "Scanner is not operating correctly." The scanner is definitely unlocked.
Nov 07, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Error message
Unfortunately, if an HP scanner quits functioning, the whole unit is dead. You may want to unplug the printer from its power source and USB cable for about 5 minutes, plug them all back in and then retry. Sometimes, a scanner job can get stuck in the spooler and cause the whole thing to stop working until the job is done (even though there isn't a job to do). I had this issue once and this worked.
Jan 20, 2008 | HP OfficeJet 7110 All-In-One Thermal...
Error message
Scanner sensor is defective,,,you need a new scanner.
Dec 02, 2007 | Canon CanoScan 8400F Flatbed Scanner
HP LaserJet 3030 All-In-One Printer Logo
419 people viewed this question
Ben Johnson
