Question about Akai PDP-5016H 50 in. HD-Ready Plasma Television
Power but no picture
I have three Akai PDP-5016H 50" Plasma TV's and two of them have failed with the same problem. The screens are just grey. When powered on, the screen goes from black to grey and the fans work, but I cannot get anything on the screen. Not even the menu or the Input source. Power light goes to green like normal, just no picture.
I have looked at the caps on the board, but nothing looks bad.
Thank you for any help?
  • 2 more comments
  • dc02112 Mar 09, 2008
    I have the same Akai model plasma and we are having the same problem? Any answers as to what to do to repair it?
  • bruce_k Mar 10, 2008
    I just got done taking the Power Supply board off of it and looking for cracks or cold solder joints, but found nothing wrong. I do not know exactly how to test the boards, so I am just checking them all for physical problems. Any ideas or suggestions would be great.
  • Anonymous Apr 27, 2008
    i get sound but no picture.
    yes same problem the remote won't even control the power
    Scholar:
  • 52 Answers
This unit stumped me.. The reason being is that the power supply normally has 2 parts, a primary control line and then the main power supply. The purpose of the primary control line is to talk to the main control board, make sure there are no errors upon power up and then startup the set with high voltage. The problem is that the primary control portion is not working.. With that being said, it has no way to control the set for startup and initalize the processor for the video/menu. What is supposed to happen is when this is dead, the set should do nothing and the relays should be tripped going into protection fault mode. A very backwords design for failure on this unit. Anyways, replace caps c502, c503 and c521 on the main power supply unit. Replace the existing 50v .47 uf with a 1uf @ 50v to prevent the failure again. The other 2 are 47yu at 35v, I would jump the volts to 50 on that again to make sure it dosent happen. Becareful of the ps removal, the 15+ fets are screwed to the chasis and locked down do to heat, do not remove the protective coating or risk ps failure. Enjoy your tv.
Posted on Aug 06, 2008
Check for blown capacitor on the power supply board. I was lucky to have an electronic store to find the part for me. Cost me < $5.00. I'm watching TV on my plasma again.
Posted on May 20, 2008
  • 871 Answers
Check for short on 130Volt line. With the set unplugged clip the negative lead of your DMM to TP3 (Hot Gnd.) located on the Power Supply Panel. Connect the positive lead to TP7 (130 Volt source). Reading should be >100k. If a short is shown--and with test leads still connected--unplug P108. If still shorted, problem is on power supply panel. Check Q10, Q11 and D13. If unplugging P108 removes short, check for shorted Q10 and D14 on the deflection panel. Important!! Replacing either panel without following this procedure will short out the new panel installed. Often, both panels must be replaced at the same time to avoid one shorting out the other. This is the most common problem to tv that has sound but no picture.
Posted on Apr 02, 2008
Tv background noise
Try by resetting the picture settings. Brightness, contrast etc. Do a factory reset. Refer its user manual for details.
Mar 22, 2013 | Akai PDP-5016H 50 in. HD-Ready Plasma...
Only get the bottom half of screen with good picture, top is color lines.
Its a Plasma so it likely has 2 sustain boards--one for top half of screen and another for the bottom. Some brands use different names but this is likely the issue here.
Apr 23, 2012 | Akai PDP-5016H 50 in. HD-Ready Plasma...
I have an AKAI 50"
Maybe the plasma controllers are gone.
Oct 18, 2017 | Akai PDP-5016H 50 in. HD-Ready Plasma...
Tv comes ON but no picture
the light source is out. the new lamp will cost around 250 easy fix.
Jun 04, 2009 | Akai PDP-5016H 50 in. HD-Ready Plasma...
PDP5016H Akai Plasma TV
is the control board the one with the rca jacks on it,for sound and video input?if so email me at mesa1965@yahoo.com,i need one.
Oct 28, 2008 | Akai PDP-5016H 50 in. HD-Ready Plasma...
what's your email address? i need some parts.
Oct 10, 2008 | Akai PDP-5016H 50 in. HD-Ready Plasma...
Cable/ribbons
Which cable do you need, the one that goes from the video board to the main control board? Also the power cable clip can be found anywhere, its one of the most common clips.
If you just pulled the wire out of the plastic shroud, you can lift the leg that holds the wire in with a pin and shove it back in. If the wires broke, you can solder it back together or I probably have a replacement here.
Sep 05, 2008 | Akai PDP-5016H 50 in. HD-Ready Plasma...
Fill the screen
Depending on what source you are using, this is possible. Most digital sources are set and cant be changed by the tv leaving black bars. Though video, svideo and component should allow multiple masking and cropping modes to strech the picture.
Nov 01, 2007 | Akai PDP-5016H 50 in. HD-Ready Plasma...
Open Questions:
See all Akai PDP-5016H 50 in. HD-Ready Plasma Television Questions
Akai PDP-5016H 50 in. HD-Ready Plasma Television Logo
255 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
