Question about HHP Hand Held Products IT3800LR-12 Barcode Scanner
I can't programmed my IT3800LR
When I read any setup code in the manual, this is read whith characters not whith a setup barcode.
  • 4 Answers
Jaquino, there is a programming bar code to reset the device to factory settings in the user guide. I know you said that it is reading other bar codes like they are not programming bar codes, but have you tried this bar code? Usually it works, even when the device is totally hosed, unless there is some kind of hardware failure.
Here's the link to the Quick Start from the company website:
http://www.handheld.com/download.aspx?download=/data/f9e7f996-9ecc-4f49-b604-32fbd754085d.pdf&filename=3800+Linear+Series+Quick+Start
The factory reset bar code is on printed page 4 of the PDF document.
Posted on Mar 06, 2008
How do I disregard the last character on a UPC bar code?
In general you can create an Advanced Data Programming Rule which will say: If you scan an UPC barcode, please send only the first 11 characters of the barcode.
There are programming barcodes in the manual for the scanner or you can use the 123Scan2 application provided at support.symbol.com to create the rule and print out an config sheet.
Aug 26, 2010 | Symbol LS2208 Handheld
We have the barcodes to scan to emulate the keyboardwe are trying to scan units of blood that are for example 35 S 13048 the scanner reads 1313048..the first part is always messed up any ideas
Without knowing your application or scanner programming I can't be certain but it sounds like the scanner may be reading information on the code that you want parsed out. Check with whomever labels the units to find out exactly what is in the barcode (it's possible the "35 S " is not encoded) and then determine what you need to send to the program you are scanning the information in to. The scanner can be programed to pass along only specific characters that were scanned (i.e. the 13048) and to pre-pend or append additional characters as well (i.e. 35 S ). You'll need the scanner's programming manual to do that. Here's a link to the scanner's programming manual. Choose the first User's Guide on the list:
http://www.honeywellaidc.com/Site.aspx/na/en/product_center/product_support/?category=5&product=297
Good Luck!
May 19, 2010 | Metrologic Instruments 9520 Voyager
I have a new LS4278. I need to congigure it to read fedex barcode
All you have to do is create a rule to transmit only the 12 digits you want.
You can create a rule with the Programming manual or the 123scan software.
Both of these are available online at support.symbol.com. Here is a short cut:
http://tiny.cc/d400s
if you need additional assistance please let me know - Thank you, Kim Ganoe 800.933.2839 x251
Mar 05, 2010 | Zebra LS4278 Cordless Bar Code Reader...
Bought new cords for scanners and when plugged in the light comes on but will not read anything
have you tried using another code, sometimes new cord can still be faulty. if you try another cord the same problem comes up then the scanner port might have develop fault
Mar 03, 2010 | HHP Hand Held Products IT3800LR-12 Barcode...
HHP Handheld IT3800lr-12 - i can't configure it to USB
If you have the manual, try to cofigure it to USB Keyboard and/or to LAPTOP DIRECT CONNECT. This last option is on page 1-7 in the manual I have with me. Please let me know if it works... Good luck!
Dec 15, 2008 | HHP Hand Held Products IT3800LR-12 Barcode...
Extra zero
The default setting for this scanner is EAN13 enabled. This means that all 12 character barcodes will be changed to 13 characters by adding a zero in front.
How to Disable:
Open the manual that came with the scanner (it's available to download on the Cipherlab web page if you don't have it).
Find the UPCA Parameters barcodes (currently page 29). The next heading down is Convert to EAN13. You will see the disable and enable barcodes.
1) Scan Enter Setup Barcode (on practically every page of the manual at the bottom). The scanner will beep 6 times.
2) Scan the Convert to EAN13 Disable barcode. The scanner will beep once.
3) Scan the Update barcode at the bottom of the same page.
Your scanner should now read both 12 and 13 character barcodes correctly.
Hope this helps:)
Nov 26, 2008 | CIPHERLAB 1000 Handheld Barcode Scanner
Ean 13 problem
you are probably reading to a inteligent software package like Excell, which sees the inputted data as a number (so ignores leading zeros) you need to specify to the sytem that the incoming numbers are TEXT not numbers.
Sep 30, 2008 | Symbol LS2208 Handheld
How can I restore factry default?
open your programming manual,or setup manual and read the codes return to factory
Jan 31, 2008 | Symbol LS2208 Handheld
Double beeping
Usually Barcode devices come with a code book to program them, This is usually contained in the user manual, and will be several pages of barcodes, using these barcodes you can set the options of your handheld device, including what types of barcodes it can read and other options like output formats and seperator characters, you should also be able to change whether it beeps or not,
Jul 05, 2007 | Metrologic Instruments MS9535 VoyagerBT...
Bar code reader problem
In the user manual for this device there should be a code book (or code pages), These are a selection of barcodes which you use to configure the device. One of the settings is to omit the barcode header (which indicates a type of barcode for instance a PART number might begin with P or a Serial number might begin with an S) This barcode system may have been initially programmed to omit these code letters Gareth
Jul 04, 2007 | HHP IT3800 Handheld
HHP Hand Held Products IT3800LR-12 Barcode Scanner Logo
733 people viewed this question
Top HHP Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a HHP Computer and Internet Expert? Answer questions, earn points and help others
