Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
Won't put out water to clean
Everything is working on this machine except that it won't put out any water. All lines are clear.
    President:
  • 1,673 Answers
Check at the bottom of the tank and make sure that the seal is on the vale at the bottom of the tank and not sitting in the hole it sits in. Does water squirt out of the hose? If it does, then the heater in the handle is probably clogged. If it doesn't, then you could have a bad belt, pump or a line that got pinched, you have to take off the top cover for that. Speaking of top cover, check the back edge, is it together and tight, or is there a gap and the top cover is rised up some. If it is, then the back screw holes have broke loose.
Posted on Mar 06, 2008
Won't pick up water from the clean water side
I couldn't view u'r clip but it seems if the pipe is blocked try to remove the blockage by using a hose where you spray hot water and normal dishwashing liquid, through the pipe, to unblock it. Just do not immerse the whole machine in water! Because I do not know what machine you have. Good luck my friend!
Mar 23, 2013 | Vacuums
Rug doctor won't spray water
I had the same thing happen to mine. I looked at the hose in the water tank and the screen at the end if the hose was slimy and clogged. I took the screen off and cleaned it up, put everything back together and it works like new again. Only 2 screws and a screen.
Oct 17, 2012 | Rug Doctor Mighty Pro X-3 Ready Pack...
I have a bissell pro heat 2x +and the water is not coming out of the hand tool or the carpet cleanerr
We are sorry about the issues you've run into.
This link gives detailed troubleshooting instructions for you: http://www.bissell.com/FAQDetail.aspx?id=1122&icid=ccrr
And this video shows easy maintenance items: http://www.bissell.com/how-to-videos/proheat-2x-machine/care/?icid=ccrr
If your machine continues to not spray, please take it to a BISSELL Authorized Service Center for warranty repairs. If you are experiencing difficulties other than no spray, the technician will let you know the cost for those repairs if your machine is outside of the one year warranty timeframe. You can locate a BISSELL Authorized Service Center at this link: http://www.bissell.com/service-centers/?zip=Enter%20your%20zip%20code&distance=50&icid=ccrr
One pointer that can help between uses is running water through the lines. First, put clean water in both tanks and set your unit to the heavy traffic setting for one pass. This will flush out any cleaning formula in the lines so your spray tips won't get build-up between uses, which can lead to a lack of dispensing the cleaning formula.
Jun 27, 2012 | Bissell 9500 ProHeat 2X CleanShot Upright...
I have a hoover steam vac F5915-900 I bought at walmart about 4 months ago. I used it about 5 times in differnet rooms. Today when I went to use it It won;t pick up the dirty water. I cleaned the filter...
Make sure the suction area of the face plate is clear of all debris. If anything else, call the number on the machine, it's still under warrantee if the machine doesn't work from normal use.
Sep 05, 2011 | Hoover Vacuums
Bissell ProHeat Rug and Floor cleaner. Won't
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
sf
Oct 20, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
I THINK THE SMART MIX PISTON IS INSTALLEDS WRONG
it has the rubber seal and the container releases fluid when it depressed.... bipolar lol..
fill it with hot water and prime the machine.. don't use soap just try lear the lines.. always run hot water through your machine to clear the lines before storage.. and to maintain prime
Oct 16, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
My steam vac won"t **** up the water
Check the hose and make sure it is clear of debre and there are no kinks in the hose.
Aug 28, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover Floormate H3000
buy a new solution tank. the problem might be that your not rinsing the tank with clear water after use and the soap hardens on the release button of the tank.
Feb 09, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
