Question about Visonik V103BP Car Subwoofer
There is no where to plug my input cables into my stereo on the back
Do i need a y adaptor and what kind?
  • Tygh Duval
    Tygh Duval May 11, 2010
    Please provide more details on your system setup, including head unit, amps, speakers, etc.
    Sergeant:
  • 300 Answers
Please see my info request.
Posted on Mar 27, 2008
HOW DO I HOOK UP TO MY HOME STEREO RECEVIER
You can connect it to your stereo system using the "audio out" jack on the back of the unit. It takes a 1/4" phono plug. You can get a 1/8" to RCA cable and connect the RCA end to an input on your stereo. You would need to use an adaptor (1/8" to 1/4") to connect the 1/8" end of the cable to the microphone unit.
Mar 11, 2014 | Gem Sound GMW61 Dual Wireless Microphone...
How can I transfer recordings from S725 to my pc. I have windows XP
You will need to get a 2.5mm mono to 3.5mm stereo adaptor from somebody like Maplin.
The 2.5mm end of this needs to plug into your earphone jack (mono) on your S725.
Get a ready made cable with a 3.5mm stereo plug on both ends.
Put one of these plugs into your 2.5mm mono to 3.5mm stereo adaptor.
Put the other plug of this cable into the AUX input of your PC.
If you do not see an AUX 3.5mm input, look in or around the area where you would normally
plug your headset. Try checking the manual that came with your PC. Some PCs do not have "AUX" marked on the 3.5mm socket.
Be careful not to have the volume level of the S725 too high as you are testing your setup.
You might damage the Mic input of your PC if you blast too high a level at it.
Next you will need some software like Audacity (Free) to record your tapes.
Have fun but be careful if you are not sure about the connections.
Hope this helps.
Sep 12, 2011 | Olympus Pearlcorder S725 Handheld Cassette...
I have a bose radio which is 8 yrs old..what i am trying to do is connect my mini I Pod to my bose...I have audio in and outon back of my bose...I tryed a cable which just has to male ends 91.CM AUDIO...
hi,
You need a STEREO to RCA cable for connecting you I pod to the audio input of you boss. you Can connect the stereo jack in the one end of the cable to the I pod and the RCA end to the boss's audio input L/R.
i have added the picture of the cable for you reference.
ok
Apr 04, 2011 | Bose & Wave& Music System
What Auxillary cord model will fit in my alpine cda-9853 stereo model?
Peripheral stereo mini plug cable (3 foot cable, male to male miniplug). around $20
Monster portable music player cable (stereo mini-to-RCA adaptor) around $20
Arista stereo mini-to-RCA adaptor (6 foot cable with mini and dual RCA plugs) around $5
Hope that helps.
Mar 30, 2011 | Alpine CDA-9853 CD Player
I can only hear one side of my headphone with the Samson S-Amp! wheni pull the headphone cable out i can hear on both ears. what kind of connection do i need to listen in stereo?
Are you using a STEREO input cable? Is the source of the audio stereo? The stereo cable will have three connections on the plug... the sleeve, the ring and the tip.
If you only have mono source or using a mono cable you will only get sound in the left headset. Pulling the plug part way out will sometimes contact both connection so you will hear both.
If your source is mon, you will need a special cable that connects the mono signal to both sides of the input plug, that is the ring AND the tip.
Mar 29, 2011 | Samson Samp Headphone Amplifier
We want to know can we put an mp3 player or the like through the original audio gear . if not can you advise us on what we can do . we have the tape deck which is not good now thanks
Does you sound system have an input plug (RCA) of audio?
If does you could buy a cable adaptor that have an output of stereo rca. Plug the stereo jack on your mp3 earphone socket and your ready to play!
If your sound system have no audio input. You should buy a 12 volt amplifier, with an out put of 50 watts( Depends upon your clarity and bass boost) or higher! Use your existing speakers and make sure you buy that audio adaptor cable for your mp3 to connect to your brand new amplifier.
Thanks for using Fixya as a problem solver!
Dec 07, 2010 | 2000 Harley Davidson FLHTCUI Electra Glide...
I bought a ac adaptor to my super nintendo, because the adaptor that I'd is a fuckin' fail, so when I bought a new super nintendo adaptor, but I can't see anything on my tv. The conexion is ok. What's up!?
Note: pictured above is the redesigned Super NES. The original Super NES uses the same hookup steps listed below.
Installation Steps:
Locate the Audio/Video inputs on the back of the TV.
Place the yellow end of the Stereo AV cable into the Video "in" on the back of the TV. Connect the red end of the cable to Audio "in" Right. Connect the white end of the cable to the Audio "in" Left. Use a slight twisting motion when inserting each cable and ensure the cables are firmly pressed into the input.
Note: If you have a mono television with only one Audio input, click here for a diagram of how the hook-up will look. The Y-adapter pictured is optional; you can also simply leave the white cable disconnected instead.
Connect the rectangular (gray) plug of the Stereo AV cable into the "multi out" connector on the back of the Control Deck.
After the system is connected to the TV:
Insert the Game Pak firmly into the Control Deck.
Plug the Controller(s) into the front of the system. Use the far left port for player one.
Plug the AC Adapter into the back of the system . Plug the other end into a wall outlet.
Slide the Power Switch on (toward Game Pak).
Turn on the TV and locate the input select. It is often called: input select, AUX (auxiliary), Line, Line In, Input, Source, Select, In, or EXT (external). Switch the input select to show the Nintendo game.
The game image should now be displayed on the screen. You are ready to play!
If after following these directions you are not able to view the game, try our Troubleshooting Tips.
Oct 10, 2010 | Nintendo Super NES Console
Good morning! I wish to plug our television into the LBT-ZX6 stereo, but the TV's output uses an optical audio cable. Is there an adapter of any sort that could convert the optical cable into the stereo...
You may be able to avoid messing with the optical output completely, if the TV has a headphone output, in which case, a phono-3.5mm jack adaptor will sort you out nicely.
If it has to be optical, I expect you can buy adaptors for this aswell, but I'd expect it to be more expensive.
Most local electronics stores will sell these. Radioshack is a good example. Also, you could look around on the internet.
Jan 25, 2010 | Sony LBT-ZX6 Shelf System
Need Adaptor connect DJ Tech Turntable to Sony Mini Hi Fi MHCRG495
The USB turntable is likely a USB data connection and not a USB audio connection, so you will need to take the audio output from your Mac G4 to your Sony Mini Hi Fi...
You will likely need a stereo mini-plug (3.5mm or 1/8-inch) to stereo RCA plug cable (red and white RCA plugs). This is often referred to as a "stereo Y-cable."
Apr 05, 2008 | Televison & Video
Sony fwd50px2/s
The monitor should have come with several cables and adapters. One adapter converts the stereo RCA plugs to a stereo 1/4 inch plug that connects next to the dvi outlet.
May 12, 2007 | Sony FWD50PX2/S 50 in. Plasma Television
Visonik V103BP Car Subwoofer Logo
Top Visonik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Joe Alexander
Joe Alexander
Jerry Umali
Are you a Visonik Car Audio and Video Expert? Answer questions, earn points and help others
