Question about Toshiba TP50H50 50" Rear Projection Television
My Toshiba shuts off automatically..a lot?
I've unplugged it several times, tried different outlets, and made sure the timer was not set to shut off, but it still keeps happening. I talked to Toshiba directly and all they told me was to unplug TV for 2 minutes-of course no luck there. I printed out Owner's Manual and did everything it said. Any suggestions...I would appreciate it because I really can't afford an new television at this point. Thanks for any input I can possibly get.
Http://www.casiasfamily.com/repairlog/tp50h15.html
see the link.
the problem are the convergence amps. Its a common problem for this model. Google the model # and you'll see several postings about the blinking light.
Posted on Mar 11, 2008
I shut down my toshiba copier 282 in the right way . It gives me the message shutting down in progress but it doesn't shut down automatically as before. It only shuts down with the on/off switch
AD+206
Auto Shut Off Mode timer
setting (Auto Shut Off
Mode/Sleep Mode)
ALL Refer to
content
<0-20>
SYS Timer to turn OFF the
power or to enter the
Sleep Mode automatically
when the equipment
has not been
used
0: 3min. 1: 5min.
2: 10min. 3: 15min.
4: 20min. 5: 25min.
6: 30min. 7: 40min.
8: 50min. 9: 60min.
10: 70min.
11: 80min.
12: 90min.
13: 100min.
14: 110min.
15: 120min.
16: 150min.
17: 180min.
18: 210min.
19: 240min.
20: Not used
check this or update firmwear
Sep 29, 2016 | Toshiba Office Equipment & Supplies
Why does my Electrolux epic 6000 sr shut off with suction?
If this Epic 6000 is shutting off when you either just turn it on or while vacuuming with it...it\'s one of several things...1. Change the bag if you\'ve been picking up a lot of "fine" dust such as drywall dust or carpet freshener powder. That\'s ******* them. 2. Being the machine is over 22 yrs. old, the suction control valve inside either needs to be replaced or just cleaned well. This is the usual cause of the vac shutting off especially if you\'ve tried the dial in several different settings. Hope that helps!
May 20, 2014 | Electrolux UltraLux 2000 Bagged Canister...
I have a powerbar with 8 outlets 4 always on 4 controled by a digital timer with 6 buttons, Top row Day, Hour, Min. Bottom row Clk, Mode, Prg. When i set the timers my lights dont shut off or correlate to...
1) Copy following link to identify timer and download manual:
http://waterheatertimer.org/GE-timers-and-manuals.html#striptimer
2) Check that battery is operable,
Move selector switch to ON position.
Check that each program has ON and OFF times set.
Check that each ON time has same days of operation as OFF time.
To delete programs, hold down MODE button and press Prog button.
Check outlet has correct polarity using circuit analyzer.
Try power strip on different outlet.
Check load rating of timer matches type of load being controlled.
This timer might not work for CFL inductive loads, try with ordinary light bulb.
Dec 28, 2012 | Globe Electric Hardware & Accessories
Westinghouse outdoor timer with 6 outlets instruction manual
1) Copy following link to help identify timer and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#outdoor
2) After viewing link above, add a comment with clear detail about timer
Dec 22, 2012 | Hardware & Accessories
My raindrip water timer model r672c works but will not shut off. can it be fixed
I'd buy a new timer of a different brand. I have tried several of these and there are fundamental problems. In my case. I set the frequency. OK. I set the time. OK. After about 10 seconds it shuts off and doesn't start again. Same problem with 2 units. It I'm tired of messing with it. I certainly wouldn't trust it if I had to be out of town for a few days. Look into the DIG EZ. I've had great luck with them.
Jul 02, 2011 | Raindrip R673CT Digital Water Timer
I have a Westek indoor digital timer, i have a nano tank with 2 lights (moonlight, daylight). I"ve tried setting the timer for 7 days with each light on at different times, it just won't work.Though...
http://waterheatertimer.org/Woods-timers-and-manuals.html#troubleshoot
http://waterheatertimer.org/Woods-timers-and-manuals.html#TE05W
You want to control each light with different programming?
Westek TE05 timer is single-channel timer, so different lights cannot be controlled by different programs.
You need a two-channel timer so each light can come on at different times.
http://waterheatertimer.org/GE-timers-and-manuals.html#zilla
Zilla timers are two-channel timers: yellow outlets for daytime, and blue outlets for nighttime.
Mar 28, 2011 | RTO Amertac TEO5W Decorative Indoor Weekly...
Have programmed this timer twice. Set for 7 days a week to come on at 8AM and shut off at 10PM. It only lasts on automatic for two days then shut offs. When checked it has jumped two hours and is in...
You posted under Woods 59403, which is also sold under different brands and numbers
Open following link to identify timer and download on-line manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#6-24
1) I test timers. Some arrive defective.
People write to fixya reporting glitches and problems with this timer.
However, fixya might show complaints because timer is popular. After all, if nobody bought certain brand car, there would be few complaints.
2) This timer resets after power outage, so if you have loose wire, then timer will reset.
3) Timer problems are also associated with interference, noise, or bad wiring. Buy cheap circuit analyzer at home center and test by plugging into outlet.
4) Try timer on different circuit, for example indoor circuit, and plug in different load.
5) Above information should narrow down if timer is defective, or if wiring or load are causing problem. Return defective timer to Home Depot, Lowes or Target and buy another.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 17, 2011 | Woods Outdoor 7 Day Digital Two Outlet...
Unit shuts off automatically after power on.
You have an internal short in the electrical line. your wall a/c [120 volts] goes inside and is converted [changed] to DC [ like a super battery] There are a lot of connections coming out of this POWER SUPPLY[super battery] to FEED other electrical circuit. ANY one of the circuits can demand more then power supply can give and will cause it to SHUT DOWN [turn off to protect itself]
unless u know what u are doing [" DANGER!! wILL rOBINSON, DANGER!!] you should not mess with it.
Jan 19, 2008 | Toshiba MD13M1 13 in. TV/DVD Combo
Toshiba TV Keeps shutting itself Off.
If you're NOT still under warranty you should at least open the TV and look for a blown fuse near where the power cable enters the set. A lot of times you can buy replacement fuses at a local electronic or hardware store and they're easy to replace. Check the fuse. If it is blown, it will be obvious and make sure that the set is unplugged before replacing it. If it blows again, or if it is not blown, your problem is probably in the 'X' volt regulator and you will need professional help with the repairs. You can also check the board where the components are mounted and resoled any that look bad. Brief power outages may cause the TV to turn off on its own. If you are using a surge protector, try connecting the set directly to the wall outlet. In your case it could caused by a blown fuse, a leaky diodes or a bad solder joint at the horizontal drive transformer. All can be replaced at a local electronic or hardware store and they're easy to replace If this does not correct the problem, you may need to have your TV serviced. good luck!
Jan 13, 2006 | Toshiba 36A43 36" TV
Toshiba TP50H50 50" Rear Projection Television Logo
105 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
