Question about Philips 50PFP5332D 50 in. Plasma Television
Plasma sound problems
Sound is wicked as if there is a constant blowing noise all the time
  • 476 Answers
Sounds like the TV volume is set too high, with little or no audio input.
If the sound is coming from the speakers and you are using an external input such as a cable box you may need to turn up the volume output from the box, and turn the TV volume down.
Posted on Mar 07, 2008
Plasma turns on but makes crackling sound what is that noise?
Sounds like it may be static electricity. You may have accumulated some dust on the inside. If you have a compressor with an evaporater, you can blow it out.I do it on my computer 5-6 times a year. Electronics draw dust.
Mar 28, 2016 | Televison & Video
I am looking for the complete repair kit for a samsung 51 inch plasma tv model number PN51D490A1DXZA.
Samsung LCD / Plasma TV Capacitor Repair Kit ...
www.amazon.com > ... > Capacitors
Amazon.com, Inc.
Rating: 4.4 - ‎86 reviews
Samsung LCD / Plasma TV Capacitor Repair Kit, Replacement Parts: ... 1-220uf 25v; 4-2200uf 10v; 6-1000uf 25v; 6 Inch Solder and Solder Wick; Cleaning Swabs ... pump + Solder wire + Solder wick + CAPACITORS Replacement)-COMPLETE KIT ... In my case, the OEM capacitors did not look bad, but I replaced them all ...
Samsung PN51D530 Plasma TV Repair Kit, Capacitors ...
Amazon.com, Inc.Samsung PN51D530 Plasma TV Repair Kit, Capacitors Only, Not the Entire ... Save on the full line of Powerblanket heating solutions. ... and 8 inches of 0.1 inch (2.5 mm) copper de-solder wick are included in the kit. .... Made Easy · Look.com
EASY MOST COMMON TV REPAIR EVER!!! - YouTube
? 13:13
https://www.youtube.com/watch?v=SXqSg2A5b7I
Jan 6, 2012 - Uploaded by Tampatec
Must See TV FIX EASY COMMON Samsung TV Repair Repairing LNT LCD PLASMA TV FIX SERVICE VIDEO TUTORIAL ... if you go to get tv repair kit- http://tampatec.blogspot.com/ easy ways .... The YSus/Zsus boardlook to be ok but I'm wondering if I need to replace the YSUS board> Any thoughts?
Jan 05, 2016 | Samsung Televison & Video
Hi, a guy is selling a 50" p50hdtv20a for $150 but the only problem is that he says there is a problem with the sound, it constantly goes out and has to ccut the tv on and off about 5 or 6 times,...
Well, this is the kicker, Fuses don't go bad, a fuse is a piece of thin wire that either allows current through or it blows and stops the current. Fuses DO NOT give intermittent faults.
It was $2,500 new!
http://www.hdtvsolutions.com/vizio-p50.htm
https://www.pcmag.com/article2/0,2817,1936229,00.asp
However, it is a good deal, even if you need a new sound board, or possibly a new switch. Visio are a cheap brand, and it is plasma.
Offer him a $100, settle at $125, not sure if I would go to the full $150 on a Visio Plasma.
Oct 22, 2017 | Vizio P50HDTV20A 50 in. Plasma HDTV
Crackling Noise on Samsung PS42B451 Plasma TV
I have got the same problem as well and havent been able to find where it is coming from
Mar 10, 2010 | Samsung PS42P2S 42 in. Plasma Television
Iphone 3g making strange noises during conversation
Has AT&T replaced the SIM card? Sounds like it might be an issue with the SIM.
Apr 06, 2009 | Apple iPhone 3G
Plasma tv makes loud static noise screen goes blank and shuts off
Take the back off and try to isolate where the sound is coming from.
Nov 24, 2017 | Philips 42PF7320A 42 in. Plasma HDTV
Unit constantly makes a clicking noise.
Electronic filters use static dicharges to filter the air. Unfortunately the make that clicking noise when they discharge. LG calls it a plasma filter. Clean both the regular and the plasma filter to see if that helps.
Dec 30, 2008 | LG LS-L1210CL Mini Split Air Conditioner
Power light blinking 2 times
2 blinks means the unit is having problem with 12 volt supply.
while power on you can check 12DC on power supply before shutdown.if the voltage is constant before shut down I would recommend to replace D board.
Sep 16, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Change the wick
You must be very careful and follow the instructions exactly on these wicks. The pins must be inserted into the holes on the wick holder. It is also easy to install the wick holder upside down. Look for a small up arrow on the side.
You must soak your wick for at least 30 minutes, preferably 1 hour. I know it's tempting to light it right away, especially when you are freezing, but you must wait. Wicks work by using capillary action. The fuel must have time to soak in properly.
All wicks are NOT created equal. Buy good ones, under no circumstances should you buy the ones that Walmart sells. They **** and you will be changing it in a day or two. Home depot sells a decent one, but for the really good ones visit Miles Stair wick shop. He also has some good info to deal with condensation and moisture problems.
Also note these heaters will not work if they are dirty. They must be absolutely clean of all dirt and debris, every single part. Especially the parts that come in contact with the wick.
Regular maintenance, good wicks and good fuel will keep these heaters working.
Oct 13, 2007 | Corona 23-DK Compact Heater
Philips 50PFP5332D 50 in. Plasma Television Logo
64 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
