Question about Clarke Power Products Cast Iron Bench Grinder Stand with Removable Oil Pot
Bench Grinder blown fuse
I have a Clarke MetalWorker 6'' Bench Grinder and the circut blew, and I was wondering if it was fixable? Is it a matter of changing the 5amp fuse or is there more?
  • 3,600 Answers
Try the fuse first then try the red reset button under the base.
Posted on Mar 05, 2010
  • Bruce Hathcock Mar 09, 2010
    you may have lost the brushes if it has brush type armature you can remove the brushs and replace them for about $7.00
SOURCE:
Morning mom.....may i know my tracking number....im jiselle Patalinghug....
Tracking number for what?
If you want a tracking number for an order being shipped to you, please contact the vendor with whom you placed the order.
Oct 01, 2013 | Clarke Power Products Clarke Metal Worker...
Morning mom/sir have a good day ......can i ask for something...by the way im jiselle patalinghug....may i know my traking number....?
What should the clearance on the top and bottom be when using a bench grinder, in mm
The top guard should be set at 6mm and the bottom guard should be 2-3mm from the grinding wheel.
hope this helps,
Apr 05, 2011 | Clarke Power Products Cast Iron Bench...
Belt off centre, how do i adjust it
there should be a alen head screw on the pully shaft usuly on the drive end speay the shafe down with pentrating fluid and clean up with emery cloth losen and use a straight ege if posible run past both pullys to align them
Jul 01, 2010 | Clarke Power Products Clarke Metal Worker...
Need a bearing for clarke metalworker BT 1029-1 drillpress I
could be either BRG60203 or Brg60202, I suggest going to clarkeusa.com and looking at the breakdown. You can buy a bearing at any repair shop if you can get the ID number off the bearing, it doesn't have to come from Clarke. Let me know if you need more assistance
Feb 28, 2010 | Clarke Power Products Clarke 16-Speed...
I don't really have a problem, I bought a used Clarke Metalworker model BT1001A and I need a manual for it. Can I get one from you? If so, how much? Demi skypilot2@sisterlakescable.com
Most drill presses are very similar and simple. Here is the parts list for yours and here is a manual from Pioneer that shows several models. You should be able to follow the instructions for the Pioneer model that is similar to yours. Compare the parts lists if you encounter differences in the details.
Dec 08, 2009 | Clarke Power Products Clarke 16-Speed...
How do you wier up a bench grinder
I would suggest (just from you saying you dont know wireing that well) you should have someone else do it. But if you are determined white to white black to black(or red) make sure you are grounded and check amp to make sure you have the right breaker. I think you should get someone to help you as electrical fires are #1 on home fires .
I hope I helped
Oct 02, 2009 | Clarke Power Products Grinders
Where do I get parts for a clarke drill press model bt1029?
the part number I found is BT1029-0038 for the quill spring and you can contact them at 1-800-227-9603 and see about ordering the part. If I have helped you would you please rate this response accordingly and thank you.
Sep 24, 2009 | Clarke Power Products Clarke 16-Speed...
Bench Grinders Objects
our bench grinder can be used to keep your chisels, knives, gouges and other similar cutting tools sharp, which every woodworker knows is vitally important. Also, bench grinders are handy for sharpening lawn mower blades, drill bits, gardening shears and more. Additionally, a bench grinder can be used for honing and shaping metal objects when modifications are needed. For instance, perhaps you need to modify a door hinge to make it fit in a certain application. No tool is better for this task than a bench grinder.
Aug 27, 2008 | Dewalt 6" 5/8 Hp Heavy Duty Bench Grinder
Clarke Power Products Cast Iron Bench Grinder Stand with Removable Oil Pot Logo
230 people viewed this question
Top Clarke Grinders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Vernon Taylor
Tom Chichester
Are you a Clarke Grinder Expert? Answer questions, earn points and help others
