Question about HP PSC 1510 All-In-One InkJet Printer
HP PSC 1510 printer malfunction
The automatic paper feed fails to grab the paper most times so I continually get the error message. How I can I fix the paper feeder?
  • Anonymous Mar 19, 2014
    The automatic feeders on top of the printers are not accepting paper..
Open the rear cover and clean the roller with clean water. Worked for me.
Posted on Mar 08, 2008
My HP PSC 1610 paper feed is malfunctioning. When something is sent to printer the message states Out of Paper but there is paper. The rollers don't engage the paper.
Shut down your computer. Pull the plug from the printer to the computer.Wait two minutes. Start the computer and re insert the printer cables. It should recycle and work. f not re-post question.
Jan 07, 2013 | Office Equipment & Supplies
A sheet of paper had remain in the cylinder
  1. Remove the rear cleanout from the printer.
  2. Gently remove any jammed paper or bits of paper.
  3. Close the HP Paper Feed Cleaning Kit software on the computer.
  4. Load plain paper in the printer paper tray.
  5. Press the Power button to turn the printer off.
  6. Press the Power button to turn the printer on.
  7. Try printing again. If the printer still does not pick up paper or if a paper jam occurs again, service the printer.
Other solutions customers found helpful » HP Paper Feed Cleaning Kit -- Clean the Paper Feed Rollers with the HP Paper Feed Cleaning Kit in Windows XP and 2000 » HP Deskjet, Photosmart, and PSC All-in-Ones -- 'Out of Paper' Error Message and the Printer Does Not Pick Up or Feed Paper » HP PSC 1600 and 2350 All-in-One Series Printers -- 'Paper jam: Press OK to continue' Message Displays on the All-in-One
Dec 15, 2010 | HP PSC 1610 All-In-One InkJet Printer
Printer will not grab the paper HP PSC 1315 All in one inkjet
Try using a cloth (not a paper towel) with some water on it and clean the feed rollers. Also no alcohol.
Jan 21, 2010 | HP PSC 1315 All-In-One InkJet Printer
My printer has trouble grabbing the paper from the tray to print. I have to feed it one page at a time with my hand. very annoying.
The pickup rollers need cleaning or there is too much paper in the tray (paper lift spring not strong enough).
Clean the pickup rollers on the tray with Q-Tip / 70% alcohol ... or lens wipes (for glasses and monitor screens).
Use less paper in the tray for now.
Sep 29, 2009 | HP PSC 1510 All-In-One InkJet Printer
Paper jam indicator keeps coming on but nothing visable in machine, grabs a sheet and feeds it half way, and then error light comes on.
You might have a bit of paper stuck deep inside the printer. Read your printer's user guide manual. for how to remove paper that is jammed inside the printer. If you haven't got your printer's user guide manual, then just download a pdf version from your printer manufacturer's website.
Jul 04, 2009 | HP PSC 1510 All-In-One InkJet Printer
Mp780 - Paper attempts to feed and fails Message: Load paper
Your paper feed source is wrong .Go to the printers control panel and change the feed source.
If all you do is 8.5X11 you can go into the maintenance tab and choose it to automatically change paper trays by selectin auto continuous feed.Make sure paper is in both trays of the same type and size.You will hear the printer try and grab the paper three times then it will automatically switch to the next tray.
Jun 10, 2009 | Canon PIXMA MP780 All-In-One InkJet...
HP PSC 1510 All in One paper jams and wil not feed properly. the people at HP have been very helpful to me try this and see what you get
Jan 07, 2009 | HP PSC 1510 All-In-One InkJet Printer
Paper feed problems hp PSC 1510
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Oct 17, 2008 | HP PSC 1510 All-In-One InkJet Printer
Paper Feed
Here is an in depth document on Paper and carriage jams on your HP printer. there is a paragraph on how to clean the rollers, which may fix your problem.
Good luck,
Please remember to rate Techs who assist you for free :)
Sep 27, 2008 | HP PSC 1350 All-In-One Thermal Printer
Out of Paper. Load Paper Error
HP PSC 1600 and 2350 Series - Paper Jam or Paper Feed Problems"
When the all-in-one detects a paper jam, the following message appears: Paper jam: Press OK to continue . The computer might display the following message: There is a paper jam (or misfeed). Clear the jam and press the Enter, Resume or OK button on the HP PSC. This document will assist in correcting paper-feed problems such as paper jamming, print slanting, and multiple pages feeding into the all-in-one. s.gif Clearing paper jams
Jul 28, 2006 | HP PSC 2355 All-In-One InkJet Printer
HP PSC 1510 All-In-One InkJet Printer Logo
368 people viewed this question
Ben Johnson
