Question about JVC PD-42WX84 42 in. HD-Ready Plasma Television
JVC InteriArt LT-20E50SJ
It seems that I can listen to a programme, change channels but are unable to see a picture? what have I done?
  • Jeffrey Johnston
    Jeffrey Johnston May 11, 2010
    You have probably just used the wrong cable, connection, or setting.
    What source do you have connected to your TV?
3 Suggested Answers
SOURCE: JVC LT 32E479 UNABLE TO SWITCH ANY CHANNELS
go to menu select TV settings select add a channel  In the scan boxes  type 1 and 3 or what every you have your Satellite set to  Then hit start scan  The TV will come on reset to channel 3.
Posted on Mar 29, 2009
gopakumarg43
  • 75767 Answers
SOURCE: JVC LT-32DA20J lcd TV. Unable
Hello
Check the antenna connection at antenna socket of the TV for any loose. If there is any loose contact, the signals get into the tuner section of the TV will be very weak, resulting no colour to picture. If picture and sound is there, and there is only fault with colour, surely it will be due to weak signal strength. Try to reorient the outdoor antenna; if used. If cable is connected, contact the cable provider and ask him to measure the signal strength at the end of cable connected to to TV. OK.
Posted on Jul 26, 2011
No power, no picture
Check power cord; check the outlet you are using to make sure it really has power available to it. Does the power indicator light come on when you switch the set on? If not, then, as above, check for power and check for fuse port in back of set. But, if this is a 20 inch set it is not a RPTV, you are in the wrong category....... Cheers.
Aug 14, 2014 | JVC Televison & Video
JVC LT-24HD32J - "Database Empty" after a 12 mile move. How to fix?
If the television was unplugged for very long, it may have cleared its memory. Being unable to find any channels may indicate that the unit has defaulted to cable tv mode and may require some changes in the setup menu. In the menu, there should be a category for channels where you can change the type to "over the air" rather than cable. Additionally, since all television have now gone digital, most stations now broadcast at about half the power they used to. If you live close enough to get a signal above the required threshold, you get a great picture. If not, no picture at all.
Apr 30, 2014 | Televison & Video
Model #_LT52152, when turn on TV no sound, sometimes picture frozen and sometime cannot change channel. Help!
Sounds like a firmware corruption. Contact the authorized service centre for Mitsubishi. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 23, 2014 | Mitsubishi LT-52151 52 in. LCD HDTV
JVC tv stuck one channe
I would either call JVC to see if known issue or to inquire if set has a lockout feature that kills remote and all button features----other possible reason in main board with all micro functions has a problem.
Aug 27, 2012 | JVC LT-32P679 32 in. LCD TV
I have a JVC LT 26X575 that will not accept remote input for any function, but using the buttons on the TV allow the menu to be achieved and the sound to be raised or lowered. In TV mode it comes on on...
sounds like the remote batteries could be bad or the buttons on the remote need to be cleaned. some JVC TV remotes, I'm not familiar with this particular one though, can be cleaned using a clean pencil eraser. Be careful opening the remote because some parts can fall out or you can damage the connections to the LED emitter that sends the signal to the TV. Also the solder connections on that LED could be bad.
Jun 07, 2017 | JVC LT-32X575 32 in. HD-Ready LCD...
Jan 14, 2009 | JVC LT-32E479 LCD TV
JVC Interiart 27" TV
Hey there Andy l rekon ya busted yer remote so best git on down to the store an git yerself one a them universal remotes for xmas.
Nov 17, 2017 | JVC AV-27D302 27" TV
RECORDING PROBLEM
Connectivity problem. Without knowing your models and their available channels etc., it's very difficult to advise you exactly.
Broadly though ...... you need to get the input signal routing sorted.
Plug your aerial into the Freeview box. Make a connection from its RF out, (beside the aerial 'in' socket) to the aerial 'in' socket on the JVC. Run yet another co-axial connection from the JVC RF 'out' to the television.
Now - connect a scart lead between the JVC and the TV. Power off the freeview. Switch your TV to accept A/V - to show the JVC on screen. Read/go through the 'Set up' procedure on the JVC to scan in the available broadcast channels. When done - connect using a scart between the Freeview box and the JVC. This will be located on either the L1 or L2 channel selection.
IF as it seems you are using the freeview to watch all your programmes - and record in then you are simply watching and recording 'live' change the Freeview programme and the JVC gets that same one arriving in (and sending to the TV)
Unless you need to record Freeview only output - always record from the aerial input. You select via the television remote (and 'TV' selected) and the appropriate channel.
Complex to explain - hope it helps. The one thing to remember - is to make one set of changes at a time - check the result is okay, before moving to the next.
Jan 07, 2008 | JVC DRMH20 DVD Recorder
JVC PD-42WX84 42 in. HD-Ready Plasma Television Logo
393 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
