Question about Dryers
Power/Switch & Heating Fault
Okay, so I am trying to kill two birds with one stone here.
1. The unit starts working when I set the timer even though the door is still open. Only powers off when the timer reaches zero. I have checked and nothing is stuck in the door lock mechanism. On removing the top cover, no wires appear to be dislodged either.
2. No heat, even though the unit has been running for a while. Elements at the back appear to be ok, although the card-type strip two of them (four in all) are wrapped around appear to be torn. No visible signs of burning/overheating to suggest the element/s are burnt through.
    Scholar:
  • 52 Answers
There is a switch inside or near your timer. Take off the top back panel and look for switch. If don't see one, it's inside the timer. Spray contact cleaner inside the timer. Keever
Posted on Mar 06, 2008
DHDSr46ee1ww has new heating element and switch but will not start.
Have you checked the motor kill switch? Its located by the motor.When the belt comes off the idler pulley actuates this killing power to the machine. Sometimes the switch goes bad over time and needs to be changed. The part number is wd21x10261 and runs around $12
May 18, 2012 | Dryers
Tip
Change the Function of Your Laptop's Power Button
<span> <p>1. Click Start</i>, type power</i>, and then click Power Options</i>.<br /> <p>2. In the lefthand sidebar, click Choose what the power buttons do</i>.<br /> <p>3. You should see two pull-down menus alongside When I press the power button</i>. One is for when the laptop's running on battery power, the other for when it's plugged in. Choose the setting you want for each scenario.<br /> <p>4. Click Save changes</i> and you're done.<br /> <p>As you may have noticed, this screen also lets you change the functions for the sleep button (if your laptop has one) and for what happens when you close the laptop's lid. So you can kill a couple button-birds with this particular settings stone.<br /></span>
on Apr 02, 2011 | Computers & Internet
Fan wont work on 1 2 3 4 but will on5 whats the probem
My recommendations is to replace blower motor and resistor. Its probably a resistor issue but since you are down there kill two birds with one stone.
Jan 31, 2011 | 2004 Chevrolet Silverado 1500 Crew Cab
Will not start, turns over but fails to start, seems as if it is not getting gas. Perhaps the fuel pump or sending unit is bad. gas guage does work now either.
can you hear the pump run?? if you can i would start by changing the fuel filter before i droped the tank... also did you check your relay for the fuel pump, under the hood?? the sending unit doesnt send the fuel to the engine, the sending unit is what operates your gauge... so, if your pump is junk and got to drop the tank, the sending unit is built in the pump, so kill 2 birds with one stone, and replace the fuel pump assembly, and everything will work.
hope this helps
Dec 06, 2010 | 1995 Jeep Grand Cherokee
Kenmore dryer runs but no heat. I have ohm checked the heating element, all thermostats and the thermal fuse. All ohm okay. I also checked voltage throughout the circuits from the main block to each...
Did you read ~220 volts AC across the two slanted blades of the power socket? The motor and controls usually run on 115 volts. When the timer is set to dry, press start, and look for ~220 volts at the heater element connections. (Don't let the heater reach full heat if it starts working!) You may have to short the door switch connections to get the unit to run. If you don't read 220 volts at the plug, check the output from each breaker of the dryer pair (should read 115 volts to neutral). Hope this helps!
Oct 09, 2010 | Dryers
My tv auomatic off after 1 mi
1]...Please check that the sleep timer function is not set;
2]...Some tv's have a count-down timer & switch off if there is no signal input, either from the tv aerial, or av input;
Please check that the aerial is plugged in to the correct socket on the rear of the tv; test the aerial in another tv, to make sure it is working ok.
3]...It could be a problem with the remote/teletext panel?
for example, switching unexpectedly to standby, or changing channels unexpectedly?
4]...It could be a power supply fault;
for example, switched mode power supplies (SMPS) can cause problems; this could also cause the set to switch to standby mode.
PLEASE NOTE:
If the unit still switches off after 1 minute, even after checking the tv aerial is functioning properly, & is connected to the tv unit aerial socket ok, & the source is set to the tv aerial, then this could be indicative of an internal fault.
TV sets contain extremely high & very dangerous voltages, even after the tv has been unplugged from the ac power socket, on the wall, which could kill you!
FOR THIS REASON, & FOR YOUR SAFETY PLEASE DO NOT attempt to open or repair the tv unit yourself, unless qualified to do so - please take it to the tv repair shop;
only qualified tv engineers should attempt to carry out tv repairs.
I hope this information was helpful for you.
Thanks,
Steve.
Oct 01, 2010 | Symphonic SC313D 13 in. TV/VCR Combo
I REPALCED THE TIMER CONTROL AND MY DRYER WILL
Always check to make sure you have power at the unit. If power is present and you replaced the timer control there is something else causing your unit not to fire up. I will assume your unit is an electric dryer. Before you check anything inside the dryer make sure your power cord is unplugged. Then check the door switch for continuity. If the door switch test okay then check the thermal fuse located on the blower assembly. Remove one lead and test for continuity, if okay then check the upper limit on the heating box. Again, this is a continuity check and again remove one of the leads before you check for continuity.
Sep 15, 2009 | Dryers
Starts then stops, continues, then eventually
Is it actually heating the water ?
If the heater has blown - it will be waiting to get up to temperature. No heat - it keeps waiting.
If it does get hot, it will be either the temp switch (it doesn't know it's hot) - or the timer module at fault.
Try Ebay for spare parts to save £££ before buying new from spares centres.
Aug 04, 2009 | Dishwashers
Our neff dishwasher has suddenly started to go wrong. When you switch it on a push a setting, it fills but does not wash. After about 10 mins it even drops the powder cube but still has not washed, it just...
If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Aug 02, 2009 | Dishwashers
Dryers Logo
46 people viewed this question
Top Dryers Experts
