Maybe you somehow detached the encoder strip when removing the paper.
First, before you put your hands inside the printer, unplug the power chord from your printer. This is important.
Then open up the lid and locate the horizontal metal bar. Right above this there should be a semi-transparent plastic strip attached in the right and left side of your printer. If you see this, try moving it with your finger. If its properly attached, it should bounce back to it's original position. If it's loose, try to attach it to the right/left side again. If you can't find it, it probably fell off and is jammed inside the printer somewhere.
If the encoder strip looks OK, your carrier might have jammed in the left side of your printer. Keep the power chord unplugged.
See if you can unjam the carrier by pulling it along the metal rod. If should be fairly easy to move back and forth, so you'll know if it's stuck. If you can't loosen it, your printer is probably damaged beyond repair. Check if you have warranty on it.
The light means that the printer has a paper jam.
To resolve this, Press Continue twice quickly to see the secondary error code. Press Continue to resume printing once all the jammed pages are cleared from the paper path.
For further assistance, please contact Lexmark Technical Support
