Samsung Propel A767 Cell Phone Logo
Posted on Mar 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My A767 will not complete initializing. When I power it on, it shows the at&t letters and symbol and then the 3G bars but just recycles those screens...it won't complete the process. I have removed the SIM and the battery and left them out all night..no change.
Anonymous
Level 2:
  • Expert 283 Answers
  • Posted on Mar 06, 2010
Anonymous
Expert
Level 2:
Answers
283
Questions
0
Helped
65037
Points
526
This is a device issue. You will need to contact your service provider for replacement options!
tip
How do I troubleshoot a Symbol Barcode Scanner?
<p>Barcode Scanners Symbol read and translates the barcodes on merchandise. The scanner translates the bar code symbols on the label says the price of the item and merchandising information. Traders use the symbol bar code scanner to identify their merchandise. A programming error in reader bar code symbol will cause confusion and may lead to loss of money. Troubleshooting barcode scanner symbol allows you to identify bugs and find solutions to errors. <br /> <p><br /> <p>1. Remove the installed fonts from the reader bar code symbol. The sources of such capacity to disrupt the functioning of your bar code scanner. Press the "Menu" button on the scanner bed and press the "Select" option when the source is highlighted. Press the Delete button to remove the sources of the sample. <br /> <p><br /> <p>2. Close the bar code scanner Symbol with a source of energy. The scanner has a power cord can plug into an outlet. If the scanner runs on batteries, the battery is fully charged before using the scanner. <br /> <p><br /> <p>3. Move the scanner closer to the bar. The symbol bar code scanner cannot calibrate the bar if you wrong position. Place the scanner directly over the bar and wait for the scanner to read and transmit the code. <br /> <p><br /> <p>4. Wait until the bar code scanner symbol to complete the boot. The symbol bar code scanner is initialized when the USB cable is connected to the computer. Initialization requires a short period of time to complete the process. Let the bar code scanner symbol to be idle for 4-5 seconds before you first scan an object. <br />
on Jun 26, 2011 • Computers & Internet
When texting how to inter mix letters with numbers?
When you are on the letters virtual keyboard and want to enter a number or a symbol, tap on the box marked '123' or '123Sym'. That brings up the numbers+symbols virtual keyboard. After entering the number(s) or symbol(s), tap on the box marked 'ABC'. That will bring back the letters virtual keyboard.
How do you turn on the volume? Thank You.
1. Press the Fn key and while holding it down, press the F8 key momentarily to toggle muting of the speaker. An icon of the speaker appears at the bottom middle of the screen showing muting on or off.
2. After making sure the muting is off (no slash symbol on the speaker icon), press and hold Fn again.
3. With Fn pressed, press the key with the upward triangle and speaker symbol to increase volume which is shown at the bottom middle of the screen by the green lettering & vertical bars Volume ''''''''''''
4. With Fn pressed, press the key with the downward triangle and speaker symbol to decrease volume which is shown at the bottom middle of the screen by the green lettering & vertical bars Volume '''
1helpful
I do not have wireless at home. Received the 3g version of kindle for christmas. It worked all this time. Today, it will not connect. Sees all sorts of wireless connections which are all password...
You are mixing up two things: 3G and Wi-Fi.
3G is a mobile phone data service, supported by selected Kindle devices. Your Kindle 3 3G has a SIM card built inside, just like the fingernail-size chips you put into a mobile phone. Amazon set up contracts with phone service providers in many countries so you can use it to download books to your Kindle at no extra costs for you other than the higher price of Kindle 3 3G compared to the non-3G version. You do not need any extra hardware for this to work, and it will work in most places of the world. This is the guarantee you were promised.
Wi-Fi is a wireless communication standard all Kindle devices support. While most hotels, airports and some restaurants provide free Wi-Fi access for guests, you need your own WLAN router at your home, and pay for your own broadband internet service. The "all sorts of wireless connections which are all password protected" belong to your neighbors and they are password protected so that nobody can take a free ride on the service they pay for.
You can tell the connection status of your Kindle from symbols in in the status bar, at the top right of the screen:
  • If it shows "OFF", wireless connectivity is deactivated and you cannot access the internet from your Kindle, or download books.
  • If it shows "Wi-Fi", the Kindle is connected to a Wi-Fi network. The five bars right of the symbol represent the connection's signal strength, the more bars are black, the better.
  • If it shows "3G", you are connected via 3G mobile data service. The bars right of this symbol refer to mobile phone service signal strength, much like a mobile phone would show you.
If you do not have internet connection with wireless LAN at home, you need to set up your Kindle to use the 3G service. This is the default setting when the device is delivered to you, and I believe it worked until you or somebody else inadvertently changed the configuration.
Follow this step-by-step procedure:
  1. Switch on your Kindle.
  2. Press the "Home" button.
  3. Check the status bar. Does it show the "3G" symbol? If yes, how about signal strength? If you are somehow blocked from mobile phone antennas in your area, signal strength will be low and the Kindle will not have internet access. Move around and see if it becomes better.
  4. Does it show the "OFF" symbol? If yes, press the "Menu" button. A menu of commands should open. Use the four-way button just below "Menu" to underline the top-most option "Turn Wireless On" and press the center of the four-way. The menu list will close, and after a moment Kindle will try to connect to the internet.
  5. Does it show the "Wi-Fi" symbol? If yes, I assume you accidentally connected to a neighbor's Wi-Fi network and its firewall protected, or is too far away to use it. In this case, press the "Menu" button to open the command menu. Use the four-way button just below "Menu" to underline "Settings", second option from the bottom, and press the center of of the four-way. The settings menu will open. Use the four-way button to navigate down to "Wi-Fi Settings" (the text "view" must be underlined) and press the center of the four-way. The list of Wi-Fi networks open. Navigate down using the four-way to any network with the text "forget" on it and press the center of the four-way.
Please let me know if you encounter problems in following these instructions, and I'll try to assist you further.
My samsung captivate doesnt has it's 3g symbol onthe screen
It does not have the 3G symbol because you are at the moment not connected to a 3G supported cell phone tower, that is, you are out of covergae of any possible 3G access. When you are close or connected to a 3G tower, the symbol will show again. Its nothing to be worried about.
1helpful
Hello, i have an iphone 3g, 16gb. and the glass screen smashed. so i bought a new glass screen for the iphone and reconnected and it works, how the buttons dont coresspond with the area you touch. ex. i...
Chances are that like most touchpad screens it has to be "calibrated" similar to calibrating Palm Pilot screens.
Finding this procedure may be a problem, however it is likely in one of the setup screens. You MAY have to re-initialize the whole thing.
Phone indicates connection, but won't make or receive calI.
My phone does this as well. Just because it shows service doesnt mean it has service. If you are in an area that has spotty service trying going to a place you know to have perfect service and try again. If the problem persists call ATT and they should help you through the problem.
1helpful
Recycled camera, this. Showing a square symbol
Yes you need a new lcd camera screen this also happen to tvs luckily its a camera and wont cost you as much buy .
Aug 01, 2009 • Cameras
13helpful
3answers
Shows fully charged (plug icon), but isn't taking a charge. A;ready tried reboot/restore.
Get a can of air and blow it into the 30-pin connector and headphone jack to clear the phone of dust and build-up. This should clear up the problem. I learned this from an Apple Store Genius Bar associate.
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
