Question about Motorola XV1100 (1 Channel) 2-Way Radio
Motorola xv1100 speaker low
We have had this same problem with several different xv1100 radios.With the volume turned all the way up,you can barely hear the other person talking.We have just been replacing radios that experience this problem.Is there any way we can fix this ourselves?
  • Motorola Master
  • 1,654 Answers
The XTN radio is capable of both narrowband (12.5k) channel spacing and wideband (25k) channel spacing. If a radio is programmed to narrowband and another to wideband, one will transmit softly to the other, while the other transmits loudly back. If this were the cause of your problem, it is easy to resolve by reprogramming the radios to match one another. When in programming mode be certain when you get to the channel spacing step to choose the same word on each radio, either hi or lo.
If this does not solve your problem, you are experiencing another issue we commonly see in the repair facility. It is called low receive audio. This is repairable in most cases.
You might wonder what causes this problem. We most often see it when the end-user runs at full volume for long periods of time. Cut back the volume a little bit and you might save your radio from the repair shop.
Posted on Aug 23, 2008
  • 398 Answers
Not sure what could be causing it but I would like to get one on my work bench so that I could compair levels. I have two of there and this has not happened to me as of yet.
Posted on Apr 06, 2008
Volume at phone speaker very weak
Casecraig
Speakerphone volume and earpiece volume very low Can barely hear phone...
Mark
Motorola Support
Jan 04, 2013 | Motorola Mobility MOTO W755 Cellular Phone
Can u program an xv1100 to communicate wi th an xv2100
Yes. The difference between the two is wattage. XV1100 is one watt and XV2100 is two watts.
Here is a link to the user guide where you will find programming instructions beginning on page 18 http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/XTN_Series_User_Manual_E.pdf
The VHF frequency chart is on pg 25, and the code chart is on pages 27-28.
Best regards.
Aug 25, 2011 | Motorola XV1100 (1 Channel) 2-Way Radio
We have two radios with problems, one the volume is to low and wont respond to vol control and the other has a problem with the transmit button,sometimes it works fine other times not
On the radio with the low volume, it is possible you are having a low receive (Rx) issue, or you have a bad volume potentiometer. It would need to be seen by a radio technician to determine the exact cause and if it can be repaired. In most cases, the flat rate repair for this style of radio is around $69 ea.
Your second radio with the transmit button (PTT) issue likely has a failing push-to-talk internal button, or a broken spacer behind the rubber plug. These would be common failure parts on this type of radio and replaced during a repair.
Best regards.
May 10, 2011 | Motorola XV1100 (1 Channel) 2-Way Radio
I have the motorola xv1100 vhf i cant hear my other radio unless i hold down the monitor button for open Squelch .they transmit both fine.thanks rob
It is likely, the Interference Eliminator Code set differently between the radios. If you can hear after you press the monitor button, this indicates one of the radios has Code shut off (zero), and the other one has it set to a number. Here is a link to the user guide http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/XTN_Series_User_Manual_E.pdf Programming instructions begin on page 32.
Best regards.
Oct 11, 2010 | Motorola XV1100 (1 Channel) 2-Way Radio
Low volume on a pioneer ke-5757 radio can turn volume all the way up and barely hear , tried new speakers and everything
Make sure the fader control is in the middle position. Make sure the speakers are connected correctly.
Jul 03, 2010 | Car Audio & Video
Iphone 3G speakerphone and headset volume is too low
Whilst on a call in bluetooth mode change the volume. It needs to be for each different "speaker" you use
Feb 25, 2010 | Apple iPhone 3G
Will it work with a cb radio
No. CB's operate at the 27 MHz on 22 predetermined frequencies allowed for Citizen Band radios; and your Motorola XV1100 radio is a VHF 150-170 MHz radio with a set amount of built in frequencies to choose from, designed for business use.
Aug 20, 2009 | Motorola XV1100 (1 Channel) 2-Way Radio
How can I increase the volume of the radio
Check the grill in front of the speaker area for debris or plugged holes. Check the transmitting radio for debris blocking the mic hole. When turning volume up on the radio, do not max out the volume knob, back it off slightly for best sound. If these do not help, your radio is probably malfunctioning and needs replaced.
Jan 03, 2009 | Motorola Talkabout T5100 (14 Channels)...
Motorola walkie
With the radio turned off, hold in the PTT and the Monitor button at the same time. Continue to hold these in while turning the radio on. Wait for the radio to finish making sounds before releasing the PTT and monitor button. Then simply press the menu button to walk through programming each of the features. When you have reached the end of the user programmable features you will notice the radio has a different chirp to signal you are done. Then simply turn off the radio to leave programming mode.
Oct 26, 2008 | Motorola Walkie Talkie 2-Way Radio
75-822 cb that has extremely low audio output
Hello..if you can try to connect a external speaker or phones..if the volume is ok..than i think it is time to replace your internal speaker..pse tll me....good luck...Ron
Mar 14, 2008 | Midland 75-822 40-Channels Handheld CB...
Motorola XV1100 (1 Channel) 2-Way Radio Logo
296 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
