Question about Lexmark E234n Laser Printer
Lexmark E234n I have 6 lexmark e234n toner printer in my building that have the same problem. When a document is send to print the paper will not go all the way through it gets stuck before it gets to the rollers. Please help!
  • diamondeyes Mar 10, 2008
    Thanks for the advise but I did all that. Someone suggested cleaning the rollers with damp mop. I am going to try that out, will let you know if it works!
  • diamondeyes May 29, 2008
    Cleaning the rollers with a damp cloth worked great. The printer is working fine now!
Flip the rubber roller grips inside out and put them back on. This works great.
Posted on Mar 19, 2009
    Sergeant:
  • 406 Answers
Please see that any thing like paper pick roller or any sensor is broken else wrongly aligned for smooth flow.
Kindly be sure that you are using the right paper for your printer( Donot use used paper. Or Damp or curly paper)
If possible see that roller and sensers are fixed and Tightly fitted( Properly do not tight with Force)
Align the tray properly if nothing works Please update me I will provide further Solution).
Posted on Mar 05, 2008
Exclamation light lit what does it mean
Something is wrong. Check with your manual for an explanation of what the exclamation point signifies. Could be no paper, no toner, whatever.
Aug 27, 2015 | Lexmark E234n Laser Printer
Hello - my Lexmark E120 will print a test page, but won't print anything that I send to it. I just get an error message. There is a green light next to the 'lightbulb' on the printer. The...
The light next to the lightbulb on the printer Toner low/replace PC kit. The printer is ready to receive and process data. In addition, the toner in the toner cartridge is getting low.
Solution:
? Press continue button to clear message and continue processing job.
? Remove the toner cartridge. Gently shake the toner cartridge from side to side and front to back several times to redistribute the toner, and reinsert it. Repeat this procedure multiple times. If the print remains faded, replace the toner cartridge.
For further assistance, please contact Lexmark Technical Support
Sep 12, 2011 | Lexmark E120n Laser Printer
I have a Lexmark mode lX3550. What do I have to do to make it fax?
Make sure: • The printer is connected to a computer that is equipped with a fax modem. • The computer is connected to a working phone line. • Both the printer and the computer are turned on. • The Lexmark Fax Software is installed on your computer.
Sending a fax using the software You can scan a document to the computer and then fax it to someone using the software. 1 Load an original document facedown on the scanner glass. 2 From the desktop, double-click the Lexmark Imaging Studio icon. 3 From the left pane of the Welcome screen, click Fax. 4 Select the Document option. 5 Click Start. 6 Enter the recipient information, and then click Next. Note: A fax number can include up to 64 numbers, commas, periods, and/or these symbols: * # + - ( ). 7 Enter the cover page information, and then click Next. 8 If there are any additional documents that you want to send with your fax, add these now, and then click Next. 9 To send your fax: • Immediately-Select the Send now option. • At a scheduled time: a Select the "Delay sending until" option. b Set a time and date. 10 If you want a paper copy of your fax, select Print a copy of your fax. 11 Click Send.
Aug 11, 2011 | Lexmark X3550 All-In-One Printer
Paper jam on my lexmark e234n from try one all the time , even when i switch trays. why ! thank you :)
check the entire paper route as it goes through the printer, especially at the edges, sometimes the smallest scrap of paper can block the sensor so the printer thinks there is a jam
May 05, 2011 | Lexmark E234n Laser Printer
Will only print maybe one page of a 4 page document and sometimes wont print at all
Below are 3 possible solutions.
Unexpected page breaks occur
Cause Solution
Job has timed out.
Set the Print Timeout to a higher value:
Blank pages
Cause Solution
Toner is low.
Remove the toner cartridge from the printer. Shake the cartridge back and forth several times, and then reinstall it.
Install a new toner cartridge.
Toner cartridge is defective or empty.
Replace the toner cartridge.
Jobs do not print
Cause Solution
Printer is not ready to receive data.
Make sure Ready or Power Saver appears on the display before sending a job to print. Press to return the printer to the Ready state.
Specified output (exit) bin is full. Remove the stack of paper from the output (exit) bin, and then press .
Specified tray is empty. Load media in the tray.
Wrong printer software is installed.
Verify you are using the correct printer software with your printer.
If you are using a USB port, make sure you are running Windows 2000, Windows XP, Windows Server 2003, or Windows Vista and using Windows ME, Windows 2000, Windows XP, Windows Server 2003, or Windows Vista compatible printer
software.
Cause Solution
Internal print server is not set up properly or is not connected properly.
Verify that you have properly installed the print server and configured the printer for network printing. For more information about installing a network printer, click View User's Guide and Documentation on the Software and
Documentation CD. Copies of the printer software are also available on the Lexmark Web site at www.lexmark.com.
You are using the wrong USB or Ethernet cable, or the cable is not securely connected.
Make sure you are using a recommended cable.
Make sure the connection is secure.
For some reason Lexmark has not posted information for this model. If you need a manual you might try the C534 manual at: http://support.lexmark.com/index?locale=en&page=product&productCode=LEXMARK_C534&segment=SUPPORT&userlocale=EN_CA&frompage=null#2
Dec 10, 2010 | Lexmark C533DN InkJet Printer
My T650n is leaking toner on pages I am printing. Using Lexmark branded recycled by Lexmark toer cartridges and about 2/3 are having this leaking problem. It is getting expensive. Is this a well know issue...
toner cartridges do leak but not all of them. are you getting toner build up inside the printer cavity? can you see where it is leaking visually looking at the toner? toners usually leak around the drive gears. if your fuser is not running hot enough the printer will get incomplete fusing and the toner will build up on the fuser rollers then make blotches on the print jobs. take a flashlight and check the rollers on the fuser to see if they have any build up on them. when toners start to leak they usually leave toner on every page.
Jul 03, 2010 | Lexmark T650n Laser Printer
Printer is not working
Amigo antique are from the past.. sometimes its better to buy a new compatable model to your computer than try to be a Mcgiver..
Jun 29, 2010 | Lexmark E234n Laser Printer
Paper Jam Problems
go the control panel and go to the printer then open the printer that you are using!! you need to cancel all printing document and after you done this.......just restart your pc
Jun 30, 2009 | Lexmark X5470 All-In-One InkJet Printer
E234
You have a rubber roller where tray is outside!!! Just clean with moisture mop, not wet!!! clean it until you feel it's going hard!!!
That will do it!!
good luck!
Jan 23, 2008 | Lexmark E234n Laser Printer
Paper jams
Fan your paper.
Fan:
Meaning take the paper in your hand and wave it around or page thru the papers, This puts air between the paper to prevent jams.
Make sure you do not over due the paper in the tray. Try lighter paper weight.
Nov 13, 2007 | Lexmark E234 Laser Printer
Lexmark E234n Laser Printer Logo
152 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
