Looking for a ballast for an RCA HDTV model is hd50lpw62ayx2 (50 in). Replaced the lamp itself and am getting a squealing noise and the picture goes on and off. The squealing continues for about 90 seconds after the tv is shut off.
  • 298 Answers
Posted on Mar 05, 2008
Hi I have a HD56W66 When turned on it has green light for about 5sec. and goes off with a squeal. sometimes the set comes on and stays. any answer? Tom
THe "Squeal" that you have mentioned is caused by a faulty ballast board(lamp driver). Its the board to which the two thick wires go from the lamp. Replacing the part would resolve your problem
Feb 03, 2011 | RCA HD56W66 56" HDTV
The tv picture goes out
Sounds like the ballast has gone out. Samsung recommends replacing the smps board(power supply board) when you replace the ballast because it is the smps that takes out the ballast. replacing just the ballast ,machine may work ok for a short time but will destroy the new ballast fairly quickly.
Dec 30, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
I have a samsung hlp 4663w, recently (the week after thanksgiving) the color wheel was squealing, so i replaced it also replaced lamp at the same time cause the picture was getting weak, all was working...
SHOULD HAVE REPLACED THE BALLAST WITH THE LAMP AT THE SAME TIME, YOU MIGHT GET LUCKY AND ONLY HAVE TO REPLACE THE BALLAST, DON;T TURN IT ON ANY MORE OR YOU WILL WASTE THE LAMP
How can i check my lamp ballast in a rca scenium 50w151 everyone tells me its my color wheel because i replaced my lamp and since then my tv wont even start up the light blinks then it stays on for a while...
are you sure when you replaced the lamp you seated it correctly, no really hapens all the time so dont feel bad. also another common error is the lanp door is not seated or closed and locked properly that is the most common problem that happens after a lamp is replaced, or the new lamp is bad never throw out your old one as somr dealers will give you what they call a core refund , they reuse the case around the old lamp. some can be worth as much as 50 to 60 bucks!!!
Larry Dillon
(AKA) (TECHMAN)
Sep 04, 2009 | RCA HDLP50W151 50" Rear Projection HDTV
Replace lamp on 50' rca dlp and still no working.
Before replacing the Ballast I would look at the power-supply and see if you notice any of the electrolytic capacitors tops being bubbled. It is not uncommon for the capacitors to go bad as the lamp draws more current as it ages and fails. If you do see capacity's bubbled, Replace them or have them replaced and the set will probably work fine afterwards.
Hope this helps,
Skyassoc
Jun 28, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
Rca lamp replacement, still no picture, power light still blinks.
Ballast Board #261629 Ballast is what turns Lamp on, Also Check your Lamp Fan if it is defective Lamp will not Light!
Jun 04, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
Dlp 50 inch
sounds like the DM3 isnt powering up the ballast to light the lamp or the ballast may be faulty. i would suggest trouble shooting the DM and ballast voltages.
May 28, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
HL-r6167w wont start up (HELP)
it sound like the color wheel is bad
Nov 26, 2007 | Samsung HL-R6167W 61" HDTV
No picture
Assuming that the replacement lamp is good, you could be looking at a bad ballast (lamp power supply) or the switch on the lamp door itself could be causing the issue. The light engine also could cause an issue like that. I would have a technician look at it as this is beyond consumer repair.
Nov 25, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
No picture or sound after replacing lamp
Possible bad color wheel...
Pull the lamp out & look inside where the lamp sends the light-
does the color wheel look defective? If so,replace it.
Or, the lamp ballast may be bad.After that,usually replace
complete engine.
Oct 19, 2007 | Samsung HL-R6167W 61" HDTV
Televison & Video Logo
348 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
