Tv problem i have a 1986 sears consol tv it has worked great untill lately when you are watching it the picture will go stactic for a few min. and then the pic will come back and it dose not matter what is hooked to it
    Scholar:
  • 135 Answers
Hi there!
Considering the age of the unit, my sugggestion would be to replace it. Dust normally collects inside on the components which in turn causes overheating. It could really be anything from loose joints on the main board to Line transformer or tube arcing over. Static interference from an external electrical source could also be the culprit. Check the mains for good connectivity. Good Luck,JUS004
Posted on Mar 05, 2008
SOURCE:
My Sony KF-WE50 tv turns itself off after a few seconds. Well exacly it goes black, no picture, no sound but the TV remains swithched on. The green light is flashing at the front as long as I turn the tv...
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for 5 mins, then try.
If you aren't tech savvy, this unit needs to go in for repair.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for different brand, but same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Mar 09, 2011 | Televison & Video
Picture comes in and out
you can fix this problem, your light bulb in the tv is on its last leg, and needs to be replaced, usually around $100-$200.
Sep 30, 2008 | RCA R52WH73 Projection Television
Sound no pic
Convergence ICs are STK392-110 you will need two of them they are available at the link I am posting and they give free instalation instructions with pics and free tech support so you can do the repair yourself.Heres the link.
http://servicemanuals.vstore.ca/
May 01, 2008 | Mitsubishi VS-50501 50" Rear Projection...
1986 25 inch Curtis Mathis console tv
I have a curtis mathis console tv with a 8track player, casset player record player and a am/fm stereo, mod number on the box is F607 style TC2 seril number 04787814 new in the box never opened. where can i find out its value?
Nov 18, 2007 | Curtis-Mathis CM27101S TV
Picture and Sound disappear after a few minutes
Practice visual acuity technique! Look for bad solder connects==none found?? suspect flyback xformer.
Sep 26, 2007 | RCA F36674ET 36" TV
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
