Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Need a Power Supply / Deflection Board for a RCA D52W20BYX1 TV
I am looking for a power supply / deflection board for a RCA D52W20BYX1 TV. I ordered an RCA 258762R from PartStore.com but it was not the exact same part. It was close, but I had no connections for BP011, BL501B and the BL500 connection had a notch in the wrong place.
I return the part and PartStore.com suggested RCA 264102R. I looked it up online and it looks nothing like the part I need.
Does anyone know what part # I need?
Thank you,
Heath.
  • Anonymous May 05, 2008
    DOES ANYONE KNOW WHERE I CAN GET A POWER SUPPLY/DEFLECTION BOARD AT IN BAKERSFIELD, CA OR WHERE I CAN ORDER ONE FROM?
  • 2,336 Answers
Check HERE and provide the vendor with the chassis number as well.
The model number helps but the chassis number is very important.
Good Luck.
Posted on Mar 05, 2008
  • RCA Master
  • 5,138 Answers
Try UED www.ued.com or call 1-800-648-6657
Posted on Dec 22, 2008
Screen lookes like colores separating
Here's all I find regarding bad convergence from the techrepairCD:
RCA ~ITC222 D52W20~Convergence bad~~~ITC222~Replace leaky DL032 on
deflection board~~~~~~
RCA~D52W20Y ATC221~Convergence goes out/bowed after on for a few
minutes~~~ATC221~Problem may be on the deflection board. Was unable to
pinpoint where in this case.~~~~~~
RCA~D52W20BYX1 ITC222~Convergence way off after replacing small signal
board~EEPROMS were transferred over to new board~~~IK210 was
defective..transfer the new EEPROM back over.~Remember on these
sets*when replacing the SSB* if there is a small P on corner of
screen*hold volume on remote for 8 seconds after it reaches minimum.~~~~~
RCA~D52W20BYX1 ITC222~Can not align blue convergence* bottom really
bowed* possibly either color after replacing SSB.(Or no auto
convergence.~(Service menu: turn power off for 30 seconds* press vol dn
and ch dn* simultaneously for 8 seconds* set turns on with service menu
options)~~ITC222~In service menu* select convergence. If sensor
calibration was performed when convergence was too far off* it will not
alighn.~Get crosshatch with straight lines* perform sensor calibration*
then attempt convergence alignment again. Be sure to store settings*
then do sensor calibration again.~You must get a green flash of the
screen after sensor cal and a check in the box. RED flash indicated
convergence settings are too far off~~~~
RCA~D52W20BYX1 ITC222~no convergence correction~~~ITC222~LP650
(259271) DP670 (259246) & RP632 (259564) 4.7 3W on convergence power
supply board~~~~~~
Oct 28, 2008 | RCA R52WM24 52" HDTV Projection Television
Does my tv have a built in tuner? its a 2003 model#D52W20 AND CAN I ORDER THE MANUAL FOR IT?
Yes ,this set has built in tuner,located on the SSB board next to the Deflection board.
Bottom 2 chassis onthe right is the deflection and on the left is the ssb board and right behind ssb board is the AC power supply board.
You can ship these boards for repair if you are unable to Fix it yourself.
PTS 1-800-844-7871
UED 1-800-648-6657
Retrevo.com For Manual
Encompass Parts might have service manual 1-800-638-3328
Jul 21, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
56 in rca model# R56WH78 having a problem turning the tv on and it actually staying on.. when i try to turn it on there is a solid green light for 3-4 seconds then it goes off.. no picture no sound ....
Replace the deflection/power supply board and return the convergence board. There are probably bad soldering connection points all over the bottom of that board with the fly back transformer. Slight soldering skill required.
Jun 17, 2011 | Televison & Video
I have an RCA D61W20 and it will not go on at all... Do I just have to change out power supply? How complicated is it? Can I get new power supply locally?
If the light blinks three times slowly it usually the deflection board. You can get a replacement deflection board from www.tvrepairworld.com which has installation instructions.
Nov 10, 2010 | RCA D61W20 61" Rear Projection Television
Replaced convergence board, fixed problem, and now want spare.
The usual order of probability I have found is:
Semiconductors
Electrolytic caps
Regular caps
resistors
inductors/trnasformers
Static testing OFTEN will not reveaal the failure.
Dec 31, 2009 | RCA D52W15 TV
Power button blkin ,almost like it tv is in standby mold.
This televison had problems with electrolytic filter capacitors in the secondary of its switched mode regulated power supply. Look on the power supply/deflection board and replace all capacitors with domed tops. These are usually in the 2200 microfarad range.
Dec 20, 2009 | RCA HD52W59 HDTV Projection Television
Colors r seperated n the top and bottom of picture r curved
HI:
This is a convergence power supply problem on your deflection board. There are 2 small bias fuses on the deflection board that has blown, usually this is caused by bad connections on the flyback transformer, it is also possible that the convergence power supply has failed also, but normally on this model open micro fuses on the deflection board is your prolem.
Please leave comment if more info is needed.
Lavell
Sep 28, 2009 | RCA HD52W59 HDTV Projection Television
RCA Model # R52WH74
ALL of you have a problem in power supply/deflection board 3 capacitors open located cp150 2200uf 16volt and two 220uf 35 volt, check them first then resolder around FBT other wise order new deflection board 125.00
Jul 02, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Deflection board
Your deflection power supply board is, looking from the back, on your left.
Jun 01, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
1,648 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
