Question about Philips Televison & Video
I hava a DVD recorder (DVDR3305) Suddenly I find it will not finalise my disc. I have had no problem with it in the past. Any ideas?
Aparently if the disc is run to the end it automatically finalises itself
Posted on Mar 06, 2008
Can anyone with a RH1777 help me finalise my dvd blank disk with his/her recorder?
If you can't find someone with the same recorder you could try putting the DVD into a computer DVD drive. It might be possible to get the video files off the DVD. DVD files are called VOB. You can get free software that will play them. It might even rip the files from the disc for you. You can then transfer them to a DVD disc using the computer.
Jan 06, 2015 | LG RH1777 DVD Recorder
Model DMR-ES30VEB. I have had this recorder for a few years now but since I got a new Sony TV at christmas I am having problems recording. When I record a programme the DVD says it does not recognise the...
DVD-RW discs are ideal for temporary video recording and data backup, but they are not recommended for successful finalising, as there is no guarantee that the disc will work in another device.
Have you tried using DVD-R discs? these CAN be recorded in video mode AND finalised for compatible playback in other players. I assume the DMR-ES30V is a DVD/VCR combo unit - if so, the DVD recorder will not recognise RW discs; only DVD-RAM and DVD-R.
DVD-R discs are recommended for video recording and finalising in this model. (later model Panasonic DVD recorders allow RW disc recording).
Mar 26, 2011 | Panasonic DMR-ES30VEBS
HI, i try to copy a Hi8-Tape to DVD, t works but i can't play it on another DVD-Player. Whats the problem. Thank's.
Depending on the format of the DVDs you record, some may not be compatible for playback on other DVD players, even if you FINALISE the disc in this recorder before playing it anywhere else. Assuming you are using the correct DVD format (for example, DVD-R), did you finalise the disc in this recorder after transferring your tape? if not, that would be the reason why the DVD won't play in another machine (I am also assuming you have everything set up correctly to enable smooth transferring - picture, sound, etc.).
Most modern DVD players recognise various disc formats (+R/-R/-R DL etc) but all of these must be finalised in the appropriate drive prior to make playback anywhere else possible. There should be a menu option or similar on this model recorder which would allow you to finalise the recording - you should only do this if you are completely happy with what you recorded, and it turned out OK. Until you finalise the recorded disc it will not work anywhere else but the deck it was written in.
I hope there is no major issue with the deck in this unit which would prevent you from finalising your discs - and achieving some success with playback in other units. The last thing anyone would want is a batch of drink coasters.
Feb 11, 2011 | JVC DR-MX1 DVD Recorder/VCR
Re-recording on re-usable discs (automatically finalised)
Check the setup. You have "automatically finalize disk" selected.
Mar 15, 2010 | Televison & Video
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 | Motorcycles
When I record a dvd on my vr375 it will not play on my DSE dvd player .I am useing a Sony -RW DVD
before the disc will play on other players, you need to "finalise" the disc. Finalisation ensures compatibility with other devices. Go into the "Setup" menu, and look for "Disk Manager", there will be a finalise option. select the option, and after approx. 3mins the disc will play on other players.
Jul 18, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
When I record on DVD +RW disc from my other Tv and try to play it on my combie tv ,it will only play if my disc is finalised. so if I only record 30 mins and have to finalise ,I am wasting the disc. Why...
Some tv's are not capeable of reading Rewritable disks. By finalising the disk you are basically making it a non re-writable and thus allowing your other tv to read it.
Jul 16, 2009 | Televison & Video
How to finalise dvd recording
Press the menu button on your remote - go to finalize disc - follow instructions. Note that VR discs can be played with many if not most DVD-players without finalizing. In fact I have had problems finalizing and unfinalizing discs back and forth. If the disc manager displays only unfinalize disc, the disc is already finalized.
Feb 05, 2009 | Samsung DVDR120 DVD Recorder
I have a Sony RDR HX510, can you help me?
Have you finalised the dvd disc in the machine ? you must finalise all dvds before playing them in other machines.
Mar 18, 2007 | Sony DVD-NS530 DVD Player
Televison & Video Logo
94 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
