Question about Coby PMP-4330 Digital Media Player
CobyPMP-4330 I tried turning the unit on, and after the green on light went on, there is a flash of light (like a lighting bolt) on the whole screen, and then the screen goes blank. (All dark) I tried many times to turn it on and off hoping it would reset itself, but it keeps on doing the same thing. Is it possible for some reason the hardrive is defective or broken? (Just one footnote - right before this problem first started, I had inserted a memory card in the SD card slot, and it didn't respond, so I just turned it off and tried turning it back on-and it went blank. I don't know why this happend or if there is a connection with the card with this problem, but I know this should not have happened at all. I'm hoping maybe someone can suggest something to fix the problem, or is my "toy" now broken beond help. Thank you very much.
Try restoring the player by taking away all of the data from the unit and not puting it back into it. If there was any corruption in any of the data that was in the unit, by not puting it back in, the player might start with a "clean slate", without any previous corruption. The player just might go back to it's original condition.
Posted on Mar 06, 2008
No power output or display.green standby light flashes.
Sounds like either a blown mainpower fuse or the thermal fuse for the power transformer. If the protect circuit was kicking in, the display would light up, but then turn off with a red blinking light. the green light with no display means the transformer is not getting power.
Dec 31, 2013 | Denon Avr-1610: 5.1 Ch A/V Home Theater...
My kobo wont turn on
How to Fix Kobo eReader Locked up Frozen or Not Responding
1)Slide power switch to right and hold for 15 seconds and release
    2)Slide power switch to right again and hold till green/blue button near switch lights up.
Dec 05, 2017 | iPhone Apps
Try this, it worked for me
Turn off phone
Remove battery
Wait 10 seconds
Plug in charger
Insert battery
Turn on phone
Dec 12, 2017 | iPhone Apps
The game will freeze up, the whole screen turning green
Hi,of the multiple errors that can strike the PlayStation 3, you may one day have to fix the PS3 green light flashing problem. This issue is perhaps one of the most antagonizing for the average user. The unit appears to power up for about 3 seconds and then shuts down before the system has a chance to boot. When this happens you need to fix PS3 green light flashing problem in order to get your console working again.
Simple Ways To Repair PS3 Green Light Flashing At Home:
In order to fix PS3 green light flashing problem you're going to have to do some troubleshooting on your machine. The usual steps of unplugging everything and doing a hard reset apply. These are universal and advisable for any error on any console. If this doesn't work then you're going to have to go a bit deeper into your PlayStation.
Typically you get this error when something is not operating correctly inside the unit. This is different from a display or hardware errors, these still allow the console to be turned on. In the event you need to fix PS3 green light flashing problem chances are something is not working with your power supply.
If the PlayStation 3 detects a problem in the power supply or any other components that might cause severe damage it will not boot. If you want to fix PS3 green flashing light error you need to track down the faulty component and replace it. Do note that this is a safety feature designed to keep the console from overloading and requires some dis-assembly to fix. If you are uncomfortable disassembling your unit to fix PS3 green light flashing problem then you should send it in to get it fixed.
Learn how to fix green light error of PS3 with step by step instructions. We have actually prepared pictures and video guidance to fix all the ps3 problems in the best Ylod fix site.
Take care.
Oct 11, 2010 | Sony Playstation 3 (PS3) Console
Projector screen turns off after 10-20 seconds
Is the projector receiving a source signal? if not it will power itself down after whatever time you have it set to do so when no signal is present.
Just an idea?
Jan 03, 2010 | NEC NP-1000 Projector
Ds lite flashes on but fuses are ok
One or both your screens have blown.
Try removing the motherboard from the screens and attach the battery the green light should turn on and stay on.
Now attach the lower screen and turn on. If the screen is ok the screen and green light will flash and then turn off. (if the screen doesn't flash the bottom screen is you're problem and will have to be replaced)
If this happens the problem is then you're top screen which you will have to replace.
Jul 26, 2009 | Nintendo DS Lite Console
Power green light will flash then flash red when first turned on
Please intimate exact model of your Sony TV to find out reason of no power up.
Jul 09, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Black screen
Hey... friend,
It's seems your backlight inverter is burnt out...need to replaced a new inverter. Visit this site @ www.3rd-rocks.com There's a replacement parts for your FP988D LCD. Have a nice day!
Aug 05, 2008 | Fuji FP-988D 19" Flat Panel LCD Monitor
Flashing green light
1. Pls check and inspect the Lamp unit.
2. If Lamp unit is okay, Then the Problem is with
either with Ballast unit or the DMD Module.
Regards
Viren
May 31, 2008 | Sharp XR-10X Multimedia Projector
Coby PMP-4330 Digital Media Player Logo
125 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
