Question about Lands Phones
Problem withPanasonic phone
Panasonic phone KX-TCD725EM.
When I press the 'green phone' to make a call I don't get a dial tone but a beeb beeb beeb. When trying to check new calls by pressing down arrow I get 5 beebs. When I press int/hash to check new message I get the beeb beeb beeb described above.
  • ninune Dec 12, 2008
    Hi too all :)
    I have some kind of trouble with my phone, it can't see the cable, antenna is blinking all the time and can;t catch anything, no wave..i tried almoust everything i could from menu, but it does'n work. can ypu help me with this pls, maybe yo have any ideea..
    Thnank you anticipate :)
Unplug the power supply to the phone, wait 1 minute and plug it in again
Posted on Mar 06, 2008
I have a model KX-TG6445T PANASONIC 5 HANSET CORDLESS PHONE SYSTEM, THE PHON PHONE HAS NO DIAL TONE, AND SAYS PHONE IN USE. COMPUTER WORKS SO THINK IT IS A PHONE LINE AS THEY SHARE THE SAME LINE . HELP!
hi ... try this, change the cord in first.
if this don`t work: and make this test. whit another phone connected maybe in other place of the house(check first if you have dial tone ), plug the problematic phone, wait few minutes press talk on the other phone. if don't have dial tone the problem is the phone unit ,was impact by a lightning on the phone line.
few minutes after you connect the cord the line make a shortcut.
only an electronic technician can repair that, and sometimes is expensive.
Nov 30, 2013 | Panasonic Lands Phones
Two questions: We have Panasonic KX-T7630 model How do I change/delete numbers to the personal speed dial numbers. Second, one of our phones has two buttons on the right lit up in Red like there are no...
If you mean the 10 number stored in 00-09, from the phone, pick up the handset (or press intercom) and dial *30 00-09 9 plus the number and # You'll hear a confirming tone. That stores the number. To dial, you press Autodial *00-09 and it dials the number.
What's under the buttons? Press PROG and the button and it will show what's there. Probably a digital station that isn't there. Press 2 and STORE and you'll clear the button.
Carl
Sep 28, 2011 | Panasonic KX-T7630 Corded Phone
How do I program different ring tones for the KX T7220. THere are 6 to choose from I believe.
1 Press program key
2 Dial 99
3 Press line key or intercom key twice
4 Dial 1-8 for tone type
5 Phone will ring with new tone
6 Press store button(autodial)
7 Press program key to end
Dec 07, 2010 | Panasonic KX T7220 Corded Phone
Panasonic kx-TG2352 can not dial ,phone works for
Believe it or not, I accidentally discovered you have to really press hard on the numbers to dial !!! I guess this happened as one is used to a light touch working on a cell etc
Nov 30, 2009 | Panasonic KX-TG2352 Cordless Phone
Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
Our company has a Panasonic kx-t7731 main line has no dail tone.
On that phone, press PROGRAM the button and dial 01 STORE.
Press program again to exit programming.
It's not likely you'll be needing the Group Log In/Out button.
Carl
Mar 12, 2009 | Panasonic KX-TA824PK Phone
Semi Dead Panasonic KX-TGA100N with ''C533'' displayed.
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
Nov 11, 2008 | Panasonic KX TG1000N Cordless Phone
Panasonic cordless phone KX-TG6052
reset the dial mode if it is on tone and you have pulse it will not dial out.
Feb 08, 2008 | Panasonic KX-TG6052B Phone
Changing an ordinary phone to a PABX Phone
The KX-T7730 is a proprietary phone that needs to be connected to a Panasonic phone system. It sounds like you took the phone home and are trying to use the special features. These phones are "dumb terminals" everything is performed (and stored) at the control unit.
Sep 13, 2007 | Panasonic KX-T7730 Corded Phone
Lands Phones Logo
110 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
