Question about Refrigerators
Frigidaire freezing in refrigerator
Refrigerator freezing everything. I have replaced the thermostat and ordered door closers. What else could it be?
    President:
  • Refrigerators Master
  • 2,651 Answers
The damper door could be frozen in open position, supposed to open/close to regulate refig temp. if left open all food will freeze
Posted on Mar 06, 2008
Why the heat exchanger between the freezer section and the fridge section freezes up around the second element closer to the door and makes ice on the roof of the fridge section.
If your freezer is icing up it is the defrost mechanism consisting of the timer, heating element, and defrost thermostat.
When you unplug unit everything melts and it runs fine for a few days till it freezes up again.
Usually it is the heating element that just burns out and has to be replaced.
Sep 14, 2015 | GE Refrigerators
Frigidaire side by side freezes in the Refrigerator side
The temperature control thermostat, alson known as the colds control thermostat has gone bad and basically isn't converting electrical/temperature signal properly and needs to be replaced
May 16, 2012 | Frigidaire Refrigerators
My fridge is freezing everything I have the control board replaced and it didn't fix it what is causing the fridge to freeze
an overworked motor is normally the problem.
could also be a faulty thermostat.or even a leaky door seal.try the cheapest solution first.....
Jun 18, 2010 | Frigidaire FRS26H5AS Side by Side...
Everything is freezing in our refrigerator even
Your thermostat has failed and requires replacement. If the fridge is very old you could use a mains interupter device that has a temperature sensor that is placed in the fridge. There are several hobby kits for such devices usually used for converting old fridges for wine storage.
Sep 29, 2009 | Frigidaire Refrigerators
Refrigerator freezes everything even on low setting
Is it a single or double door? Assuming it is a double door. Normally the upper grade models have an auger motor that opens and closes electronically depending on temperature demand. This auger situated at the top LSD of the fridge normally freezes up due to various reasons. Most common is, product is placed to close to outlet which in turn creates a blow back effect and seizes the mechanism. Need to defrost fridge section for about 2 hours for ice to melt. Retry.
If it is a single door, your thermostat needs replacement. I'm taking it you have adjusted the settings higher(not so cold) but still not correct.
Sep 27, 2009 | Frigidaire FRS26R4A Side by Side...
Frigidaire is freezing everything!
Possible defrost timer or thermostat failure.
Jul 11, 2017 | Frigidaire FRS26H5AS Side by Side...
Frigidaire refrigerator freezes everything with setting on lowest
hello there,
try to check your thermostat setting adjust below gradually,
you set it up to coldest point that's why it's doesn't cycle on no auto shutt off and shut on,
if still not change for 12 hours still freezing up,replace thermostat by your technician,might defective.have a nice day
don't forget to rate me,thank's a lot.
May 05, 2009 | Frigidaire FRS26H5AS Side by Side...
Refrigerator
need model number cant help if we dont know what meodel it ios but if everything freezes repl the thermostat in refrigerator side
Aug 16, 2008 | Frigidaire FRS266ZDSB Side by Side...
Refrigerators Logo
214 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
