Question about Dell P793 17" CRT Monitor
My monitor give tow horizontal lines
My monitor gives two horizontal lines which very thick and black otherwise it work properly
  • 180 Answers
There should be a dry joint at the vert IC with five pin.
Resolder it, then it wold be ok.
Posted on Apr 19, 2008
  • 55 Answers
Your Display cable (inside your monitor) needs to be replaced.
I would look on ebay to try and find the part and then take it to a local tech to replace it for you as I would not recommend anyone take apart a monitor (LCD OR CRT) if you had never done so before.
OR, Buy a new monitor.
Posted on Mar 14, 2008
Getting black horizontal lines across the screen. It started off as an intermittent problem, now occurring more often. I changed the video card and the power supply tests fine and I changed the refresh...
I would test the cable, use it on a different monitor or try a different cable. That is the only other thing to check, otherwise it definitely is the monitor.
Apr 07, 2010 | NEC AccuSync 700 (White) 17 in.CRT...
ViewSonic monitor VS10780
i turn on after 30 sec turn off that happen all the time
Feb 19, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Frustration
It must be your video card not working properly. Check first if the monitor cable is firmly inserted in the video port before contemplating of changing your video card or buying a new monitor.
Aug 30, 2008 | HP Pavilion a1710n (RK573AA#ABA) PC...
Horizontal/Vertical Postion of Image on LCD Monitor
the controls for focus adjustment are on the flyback transformer, (that big black thing on the left hand side (usually) of the monitor with the thick red wire that goes to the CRT.) the flyback may have 1,2,3 or even 4 knobs on it. 3 of these would be labled SCREEN (bottom knob of flyback. handles brightness)
FOCUS 1 + FOCUS 2 (focus adjustments. these are what you need to play with) and the 4th knob (some old mitsubishi workstation monitors had these) i do not know, it wasnt labled and HV adjustment was on the deflection board
Apr 25, 2008 | Gateway FPD2275W LCD Monitor
Two horizontal lines
Please verify the same monitor with other computer, Else try changing the display card if you have a CRT monitor. If you have lcd try to workit on other PC, If you get the same result from other computer ; you need to change LCD of your monitor.
Mar 05, 2008 | Dell P793 17" CRT Monitor
Monitor some times gives shades with black
While 50 inch dlp samsung is on, 6 inch black line on left side of screen. This is the second time this has happened. The first time it happened then the lamp blew......do I need to replace the lamp again?
Feb 19, 2008 | Samsung DLP HL-P5663W 56" TV
Horisontal lines
make sure the cords are connected properly from both the computers end and the monitor
Feb 03, 2008 | BenQ FP931 (Silver, Black) (Black, Silver)...
Syncmaster 245B Monitor Shivering horizontal lines
Which type of video connector are you using? VGA or DVI?
If you are using VGA, the horizontal line could be due to interference, like from an electric motor (fan) near the video cable.
Other thing to try is to change the refresh rate. In Windows XP: Control panel --> Display Properties --> Settings tab --> Advanced button --> Monitor tab --> Screen refresh rate. The default ot 60Hz for LCD monitors. Bump it up to 75Hz. That could give a clue to the problem or maybe even fix it.
Jan 08, 2008 | Samsung SyncMaster 245BW Monitor
Dell P793 17" CRT Monitor Logo
125 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
