Question about Canon imageRUNNER C6800 Copier
Cannon image runner c6800 error code E000001-0003
Can anyone tell me if this is bad or not or what is going on?
  • gungho23 Mar 07, 2008
    Thanks, this saved us a bundle for a while unless the fuser is going out. Great help. Thanks canonman1. You Rock!
  • 86 Answers
Its a fuser error and it has to be reset in service mode
To get into service mode.....
Press *
Then 2 & 8 together
Then *
then choose COPIER
then choose FUNCTION
then choose CLEAR
then choose ERROR
then press OK
turn power off and on
if the problem comes back there is a problem with the fuser but in my experiance resetting has worked 99% of the time
Posted on Mar 07, 2008
  • philip davies Mar 07, 2008
    No Problem Gungho23
    Any other problems please contact me
Hello sir! i am hosur my cannon image runner 2200 machine eroor the code is E000602-003 how can solve tell me sir
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Hope the sites might help you.
Jan 08, 2016 | Cannon Office Equipment & Supplies
WHAT Cannon image runner 2525 ERROR CODE 000002
The main thermistor (TH1) has poor contact or open circuit. The thermal switch (TP1) has open circuit. The SSR is faulty. the DC controller is faulty.
The temperature of the fixing roller does not reach 100C with 2 min after it has exceeded 70C.
Apr 28, 2014 | Canon imageRUNNER C6800 Copier
Canon image runner error code E0000010-0010
cannon ir c6800 errode code E000000-0026 system not booting pls solution
Sep 28, 2011 | Canon imageRUNNER 5000 Copier
We have a canon C6800 copier. I am having an error code of E000014-0001. Anyone have any suggestions?
I'm not familiar with this model but the standard error of E014 is for fixing motor. Most likely the motor isn't bad but a bearing in he fixing assenmbly is damaged or frozen. Check there first
Jun 17, 2011 | Canon imageRUNNER C6800 Copier
Cannon image runner 2200 error code E000002-0000, how do I fix it?
E002/E000/E003/E261/E733 Error code: Due to AC line noise Error Code
Symptom E002/E000/E003/E261/E733: due to AC line noise. Description E002/E000/E003/E261/E733 occur due to AC line noise.
If the above error codes are frequently recorded in the error log, they might concern AC line noise. Cause When the machine tries to detect a Zero-cross signal of AC line, it will fail if a noise occurred around the zero-cross point. Since the fixing temperature is controlled based on the zero-cross signal, there is a possibility that the fixing temperature could not rise properly if a noise occurs several times. Field Remedy Replace the Switching Regulator PCB ***'y with a new one.
120V: FH3-2613
220V/240V: FH3-2614
The circuit has been modified to resist a noise. REMEDY Caution
 Press (* then 2 and 8 together then *)you are in service mode monitor:
To clear the error, execute the following in service mode: COPIER>FUNCTION>CLEAR>ERR.
GOOD LUCK MATE ......KINDLY RATE ME !!!! THANKS.
Sep 25, 2009 | Canon imageRUNNER 2200
How do you reset a cannon Image Funner 5570 down
I hate to say it but you have to replace the main motor. E010 is a bad main motor.
Sep 07, 2009 | Office Equipment & Supplies
Have a Cannon C6800 When i print 5-6 pages it
this error is from one of the color drum unit most probably yellow drum unit(needs replacements)
Jul 15, 2009 | Canon imageRUNNER C6800 Copier
Error code e000800-001
not the fan open the front door pull out number one unit check the assymbly behind the frame it will move when you move the handle if its bent tou will get that code when you close the door
Nov 08, 2008 | Canon imageRUNNER C6800 Copier
Cannon Copier image Runner 400/330 series error 051
E 051 problem is registration horizontal position gear is broken. this gear seem to paper pick up deck back side. remove paper pick up deck and see one small moter and see small gear is there u change it u r problem is solved
Mar 21, 2008 | Canon imageRUNNER 210S Copier
Canon imageRUNNER C6800 Copier Logo
2,612 people viewed this question
old marine
old marine
