Question about Gestetner DSm616 Printer
Gestetner DSM616 I have an error reading SC:544 Functional Problem, Turn main power on and off. I tried that, also unplugged, waited 20 seconds, and nothing. Any suggestions??
    New Friend:
  • 49 Answers
Try replacing the thermistor. Those rectangular plastic thing. If that doesnt work the thermometer has popped. Check for continuity beneath the hot roller there are these round things. When done with that clear the SC code in SP mode do what Dale told you to do. You have to clear these codes on the older models.
Posted on Aug 14, 2014
  • 87 Answers
Turn the machine on, and press clear modes, 1, 0 ,7, and press and hold the clear stop key. It will beep, and a menu will appear. Select copy SP (1), and then select data log (#7) scroll until you get to 7807 (sc/jam counter reset). select it, and press execute. exit all the way out, and recycle the power. If it comes to ready, it should be ok. If it happens again after that, there is a fuser problem of some sort.
Posted on Mar 08, 2008
  • Terry Mac
    Terry Mac Apr 17, 2012
    can u please explain in detail ??
  • Syed Muhammad Zahir Oct 11, 2012
    i need a scanner driver for gestetner dsm616 machine
544 code error machine
Fusing overheat error.Verify the fuser unit components and the connections.If OK try to reset : press the yellow key 107 Stopred key enter in SP mode open the front door and turn OFF the copier.Wait 10 seconds and turn ON.
Jan 10, 2014 | Gestetner DSm615 Digital Imaging System
Nashuatec dsm616 sc 544
more than likely to be paper wrapped round the hot roller - remove the fuser and split it - then clean the thermistors - should sort it
Oct 21, 2013 | Gestetner Office Equipment & Supplies
Errore code sc 541
Your problem is in the fusing unit.Check the thermistors and thermofuses.Reset the code :
Interrupt(yellow)key - 1 0 7 -press and hold STOP/CLEAR key more 4 seconds,enter in SP mode,open the front cover,turn OFF the main switch,wait 1 minutes,close the front cover,turn ON the copier.
Feb 02, 2013 | Gestetner DSc338 Copier
MY GESTETNER 3218 AFICIO FUNCTIONAL PROBLEM SC 320. HOW CAN I SOLVE THE PROBLEM
SC 320 - Polygon motor error.
The polygon motor does not reach its operating speed within 10 sec. after the polygon motor on signal,or the lock signal is not detected for more than 40 ms continuosly during operation.
Possible causes polygon motor defective,poor conection of the interface harness which connects the polygon motor driver and the IOCSS board, IOCSS bboard defective.
The SC can be reset by turning the main switch OFF and ON if the SC was caused by a sensor error.
To reset SC press yellow key 1 - 0 - 7 and STOP ( red ) key for 3 seconds,enter in the SP mode, enter SP 5-810 ( SC code reset) and select "1".Then hold down the Photo mode key and the # key at the same time for at least 3 seconds(this does not require the main switch to be turned off and on).
Aug 22, 2012 | Ricoh Aficio 250 Copier
Error sc:544
Hi
SC544 error means Fuser Overheat Error 1 (Hardware). This has happened due to Fuser Low Temperature which occurs due to Abnormal Hot Roller Fusing Lamp Lower Limit Temperature Detected. Try turning off & unplugging the copier for 10-20 minutes to check if error code resets. If it doesn
Oct 09, 2010 | Gestetner DSm615 Digital Imaging System
Error code SC 542 on my Gestetner Dsm622sp
Fusing unit problem.Verify the heater lamps,thermistor and thermofuse continuity.Enter in the SP mode turn OFF the main switch,unplugged the machine wait 10 sec.,plugged and turn ON the copier.
Sep 24, 2009 | Gestetner Office Equipment & Supplies
Machine shows a service code of sc 928
The SC - 928 is a Memory error problem.
The machine detects a discrepancy in
the write/read data during its write/read
test (done at power off/on and at
recovery from low power or night/off
mode). To try to reset this code -- Turn the MAIN power switch off, wait about 30 secs. then turn switch back On.
Possible causes:
• Memory defective
• BICU defective
• Poor connection between BICU and
memory
The cheapest repair would be to replace the memory. It is rare the the connections came apart unless some one was in the back of the machine for some reason.
Jan 20, 2009 | Gestetner DSm615 Digital Imaging System
Functional Problem on our Ricoh 1018D
Enter SP mode - Clear (yellow) key, 1 0 7 and hold and press stop (orange) key for 3 seconds.
Enter SP 5-810 (SC code reset) and
select “1”. Then switch off and on the machine.
If error still there, probably you have one of the following faulty;
Fusing thermostat open,
Fusing thermistor open or defective,
Fusing lamp open or
Power supply board defective.
Please, first check fusing lamp and thermostat for open circuit.
Good luck and please rate me, thanks.
Jan 17, 2009 | Ricoh Aficio 1018D Copier
Gestetner DSc332
Sometimes a job will get caught up in memory. If you've already tried to reset the job from the copier and from your computer, turn the copier off with the main (orange) power switch and unplug it from the network cable and the wall. Wait 30 seconds, then plug it back in and turn it on.
Sep 20, 2008 | Gestetner Copier
Gestetner DSm616 Printer Logo
920 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
