Question about Sony Cyber-shot DSC-W50 Digital Camera
Cyber Shot DSC W35-W55
Im having trouble taking pictures with my camera, it was working fine this weekend but now when I try turning it on to take pictures the lens keeps coming in and out and it says access then it stops and says turn power on and off again. I can access my pictures but thats about it. Please help as I need my camera for spring break! ahhh
  • 9 more comments
  • prakashdavid Mar 06, 2008
    Sir,
    The lens keeps coming in and out and it says access then it stops and says turn power on and off again. I can access my pictures but thats about it. Please help.
    regards
    prakash
    Sir,
    regards
    prakash
  • Anonymous Mar 22, 2008
    1. I switched it off and on again
    2. I took the battery out and charged it but the same prob exists.
    3. I took the memory out and started the cam again but it will still not work
  • Anonymous Apr 25, 2008
    My camera is a DSC-W55, when I change from 3M to 2M the imagens registered in the memory Stick Duo of 2 Gb I press the central round buttom and a after a seconds a blinkin message apears with a number like this "13.- -". and I turn off the camera. I can not take pictures when the memory stick is in it's place because the message is blinkin permanently, but if the memory is out I normal take pictures. I can see the pictures in the memory stick. What is the problem??. excuseme my inglish.
    ATT. Eduardo Manjón C.
  • tonyrefail Aug 30, 2008
    My camera comes on but is trying to access, then says Turn power off then on again, I can access my photos but cannot take any photos.
    Any help appreciated, is it really just a matter of cleaning the lens??
  • Loeki Sep 08, 2008
    BLEH, same thing happening here! The pictures were blurry, and the lens kept going in and out. Finally everything stopped and the black screen reads "access". I thought it was the battery and recharged, but nothing has changed. I miss my camera. =( After reading this, I tried cleaning the lens with a Q-Tip... nothing. I was recently at the beach with my camera. I suspect that sand is the culprit.
  • Anonymous Sep 27, 2008
    when i try to take a picture it keeps saying turn off and try again and keeps on doing that it wont let me take a picture and the thing wont go in to turn off
  • growthefutur Dec 06, 2008
    its the same thing it was working fine but now it just is a black screen that says access and I can look at my photos but when i go back to camera mode it blinks and says turn the power on and off again. please help i need the camera for work
  • jmessic Dec 10, 2008
    I am disappointed with my Sony Cyber-shot SDC-W50 Digital Camera.  It's less than 1 year old and the problems is as described by others.  This is a well know problem, which I was not aware of before purchasing - signs are focus issues followed by lens going in and out and progressing to a black screen reading turn on and off again.  From what I read it may be a stepper motor on the lens - what about a recall? Sony should fix this problem; my solution is not to buy another SONY camera.  They (Sony) could go the way of the US auto industry if they are not willing to fix a problem when its the result of defective equipment.  This failure is not random!   jmessic@purdue.edu
  • julie_mar435 Jan 06, 2009
    I have the same problem!! Ah!!! I can't even access my pics though- just says "access" and asks me to power off and on.
  • Beckaboo Jan 11, 2009
    I have a DSC-W50 and my camera was working perfectly fine earlier this week. The battery died and after I out it back in after the battery was done recharging, I turn it on and it just says access. I can retrieve my stored picture but the lens will not open and when I try to hit the capture button it starts beeping and tells me to turn off and then back on! This is very frustrating because nothing unusual has happened since i used it last.
  • 3 Answers
Sir,
regards
prakash
Posted on Mar 06, 2008
Ok i have a sony cyber shot camera and the scope doesnt wnat to come out i hear a clicking noise then it says to turn power on and off again
Posted on Dec 03, 2009
    Problem Solver:
  • 5 Answers
You can repair it your self. dont waste your money.
just remove the nuts from cover and remove 2 cables comming from the lens.then take the lens out and remove all the nuts attached to the lens.there are nuts in 3 colors red,silver and black.take out the motar and remove the lens cover carefully.
there are 2 springs in side.just fix them correctly and fix it again.
it has worked for me and save USD125. good luck if u need further help contact me on asheerwadh@gmail.com
Posted on Jul 22, 2008
My digital camera Sony DSC-W85 screen coming blank. Lens movement is proper. If I take the photo it is storeing blank. Earlier taken photo's are proper. Pls suggest the solution.
Posted on May 18, 2008
I just had the same problem. I checked my lems as it went in and out and lo and behold there was a baby fingerprint. Cleaned using a q tip and it stopped immeadiatley and works fine now! Thank goodness!
Posted on May 17, 2008
  • 53 Answers
Before sending it away you may want to make sure your lens is clean. If it is dirty it will act as if the lens is out of focus. If that doesn't work and you want to repair it yourself. There is a guy in South Carolina who has lots of parts for all the Sony Cameras. I bought my LCD from him for $39.00 plus shipping and it works perfect. I put it in myself and saved a ton. If you buy the part from him he sends you pictures of him taking the camera apart so that you can repeat the process when you install it. I think his email is gerald.ray@aa-ark.com
Posted on Mar 13, 2008
    Scholar:
  • 51 Answers
Hi Prakash
To get a little techincal - the focus stepper motor on the lens assy is not working correctly.
You will need to contact your nearest Sony dealer for directions to a service centre.
They will charge you for replacing the complete lens though, which should be about half of what you paid for the camera.
Good luck
Posted on Mar 09, 2008
Fuse location
Are you sure your display is not working?
Did you try to view pictures you already made? in the viewing mode you can't switch off the screen. While taking pictures you can. For display mode look at page 16 of the manual.
It would be strange if there was a fuse for the display. It would be very strange if you could replace a fuse.
Link to manual Sony Cyber shot W35
Nov 15, 2013 | Sony Cyber-shot DSC-W55 Digital Camera
I need a cord to download my pictures to my computer. I have the DSC - W55 Cyber Shot
Having gone over a month without a response to my query, I assume my suggestion to use a card reader solved the problem.
Jun 28, 2011 | Sony Cyber-shot DSC-W35 Digital Camera
Lost disc
DSC-W35 / 55 is plug and play camera, hook it with computer through USB cable, Windows will recognize it automatically and will install required drivers.
You will see Mass Storage device icon in My Computer, click it to see pictures of camera. No need of software cd installation, Windows has inbuilt drivers for this camera.
Thanks.
Apr 02, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
When I turn on my Sony Cyber-shot DSC-W35 the screen is dark with the word "Access" on it, moments later it tells me to power it off adn on again, any ideas?
Its lens error in your DSC-W35 camera.
Lens mechanism is either stuck or not retract completely and system control sense this error. Please replace lens assembly to get it fixed because lens mechanism is not repairable.
Thanks.
Dec 20, 2009 | Sony Cyber-shot DSC-W35 Digital Camera
I lost my sony cybershot dscw35 camers's cd. where can i get the softwar and driver
You can download the camera driver software here:
http://sony.driversdown.com/sony-drivers/Sony-DSC-W35-Cyber-shot-Cameras-Picture-Motion-Browser-Driver-Version-2.0-for-Windows-XP-2000-Vista_73892.shtml
Nov 20, 2009 | Sony Cyber-shot DSC-W35 Digital Camera
No access
bit of googling...
sounds shady, but it works
BANG IT - hard, on left hand side (as you look to take snap) hell...it's already broken, can't hurt
boom, i can haz fotoz agayn :)
answer worked for many others  found here   w w w (dot) dphotojournal.com/sony-cyber-shot-dsc-w55-review-roundup-sample-photos/
Mar 26, 2009 | Sony Cyber-shot DSC-W35 Digital Camera
I CANNOT TAKE PICTURES WITH MY CYBER-SHOT DSC-W35... HELP!!!
Check Mode-Dial of camera. it has set on Movie mode. Select Auto mode to take snaps. this idea is for cysber-shot camera.
May 28, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Multiple pictures
Dear ACO107,
Please turn on Cyber-shot in camera mode and press Menu, select Mode, select Normal, OR got to Camera Mode Selection Button (top of camera near power button) and select Auto (Green Color) symbol. Problem would be solved.
May 26, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
892 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
