Question about Sanyo DS35510 35" TV
Vertical line Sanyo DS35510 35" Has sound but their is only a bright vertical line in the middle of the screen. dproulx76@yahoo.com
    Scholar:
  • 135 Answers
Hi there!
This is called a frame collapse. The Amp that drives the vertical sync has failed. This could be from excesive voltage on the mains, Lightning in the area, if you had or simply general failure. May also be dry joints( or loose connections) in the vertical amp or scancoil terminals. Good Luck,JUS004
Posted on Mar 05, 2008
Why is there a white line across tv screen
T'Con board fault.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations.
Aug 13, 2014 | Sanyo DS32920 32" TV
I have a sanyo DS35580 and there is a blue line across the middle of the screen
You haven't stated whether there is screen or picture. If you see only a blue line across the screen with high brightness, vertical output Ic of your TV has burned out. Don't switch on the set further or increase its brightness, till the fault is retified. Otherwise there will a phosphur burn occur where the blue line is now, and it is internal, whcih cannot be retified anymore.
Oct 16, 2010 | Sanyo DS31520 31" TV
Old sony tv gets a bright line in the middle of the screen
Well if this is a tube type, it can be attributed to vertical section. Cold solder on vertical IC, the vertical gone bad or some components on the vertical is at fault.
If your not on electronics better to have it check by a repairer.
Hope this helps.
Jan 18, 2010 | RCA F32650 32" TV
TV: bright line across black screen for several hours.
vertical output ic needs to be resoldered. careful leaving that bright line displayed on the screen as this will cause a permanent phosphor burn into the tube. this can not be corrected once burned unless you replace the tube. mch
Mar 08, 2009 | JVC Televison & Video
Flickering multi-colored line in the middle of the screen.
You have a failure in the vertical deflection circuit. This could be either a bad vertical chip, the power supply that runs the chip or a bad capacitor in that circuit. This is usually a repair best left to a professional. There is a small possibility that it could be bad solder connections. If genlty tapping the unit temporarily solves the issue you can try and resolder the pins on the vertical chip LA7841 is the part number. There is also a resistor 1 ohm 1 watt. If that resistor is open you can assume the IC is bad
Oct 26, 2008 | Sanyo DS27800 27" TV
Bright,thin line, in the middle of the screen, then...
1. I turn on the monitor, I hear a 'cracklin' sound
Reply: In a CRT Monitor there is a component called EHT which generates High voltage which is connected to the anode of the CRT, If there is any leakage due to moisture can cause this crackiling sound, You need to clean this high tension wire or replace the EHT ( CAUTION : BE AWARE OF HIGH VOLTAGES )
2. The screen only shows a bright, thin line.
Reply: The vertical Drive section of the monitor is faulty.
Dec 21, 2007 | Hitachi SuperScan Elite 802 21" CRT...
Sanyo 25" Standard Tube Vertical Deflection Problem
you can proceed as follow to fix it.
  1. reduce brightness to minimum to avoid screen burn.
  2. check voltage on vertical uotput
  3. check yoke connector for loose.
  4. check v/yoke winding.
  5. check v/drive from signal processor to vertical output
now your problem how to find out whether drive is there or not it is very simple even you donot have scope.
you simply touch with screw driver or meter prob  at the poibt where vertical signal is input to vertical stage
if h/line is spreadindg or tries to spread then your output is ok &problem is in drive ckt.
for schematic try given site give model no &download it
http://www.eserviceinfo.com/index.php?what=search2
hope this will help
Oct 12, 2007 | Sanyo AVM-2557 TV
Mitsubishis TV Problem
have a Mitsubishi TV 1993. Model CS-35301. The problem is that there is a white line that is running through a blank screen. The sound is fine just no picture. Have you heard of "Vertical Collapse?" I would love to save the TV. Hi nothing to worry just minimise brightness to avoid screen burn. "Vertical Collapse?" means one bright hor.line in the middle of screen. this problem can be solved 1 check vertical yoke connector or wire loose 2 check supply to vertical section which normally comes from EHT transformer check components in vertical section or print loose regards thanks
Sep 10, 2007 | Televison & Video
Tv not working
this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Mar 08, 2007 | Sanyo DS31590 31" TV
Sanyo DS35510 35" TV Logo
105 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
