Question about Lexmark P4350 All-In-One InkJet Printer
Blank paper new(ish) cartridges
I put 2 refilled cartridges into my P4350 about a month ago and they worked fine. I haven't used it for about 2 weeks and now all the paper is coming out completely blank when I try to print. Any ideas?
    Master:
  • 518 Answers
They are clogged. Soak the print head in hot tap water for a few seconds, dry and re-insert. Then run the cleaning program. If this does not work, then you need new carts.
Geno
Posted on Mar 05, 2008
Will not print
get a new printer,you got 4 years out of it
May 19, 2015 | Kodak Office Equipment & Supplies
Prints blank pages
In this case it is either a faulty print head..or it is just a mater of changing the cartridges...Usually if the printer was not used for a long period of time ..(2 weeks or more) ...the cartridges goes dry and this will be the result...-blank printing ...The easy way to solve it ...is changing them with new and genuine ones...or ..if you use refilled ones..try to insert air with a syringe ..into them so that they will mix..and also ...fill them again and agitate ...In the moment when they will leave a good mark when pressed on a paper ..(1 cm ink mark ...about 2 mm wide)..it means they will work ..Also try to reset the ink counter when you put them back ...(it may be in error )
Aug 07, 2011 | Lexmark X75 All-In-One InkJet Printer
Grrr...! Okay, I had the 1400 for 2 years, loved
If you've only bought it 2 months ago it will still be under warranty.
Apr 22, 2010 | Epson Stylus 1400 InkJet Photo Printer
Has been setting 6 months , has new ink and paper
Ink jet printers are meant to be used regularly, at least once a week.
If it was used before you put it away for 6 months, the ink is dry on the jets.
First try the cleaning function. If you're lucky, after 2 or 3 tries it may work again, and the more you use it the better print quality will result.
Failing that, there are cleaning kits you can purchase.
They consist of a cleaning solution you can inject into a used-up cartridge.
Or better yet, you can take it to one of the places where they refill ink, and for a fee they'll get it going for you.
Apr 18, 2010 | Epson Stylus C88 InkJet Photo Printer
Prints nothing on paper. checked ink cartridges
please the your pc in add a printer and again install a printer driver
and you go control panelt and select the printer an dchous this printer
and restart your pc and try printing giveup page
Sep 14, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Printing problem
You will need to clean cartridges and printer head with cotton swab and rubbing alcohol. Some printers have a self-cleaning diagnostic setting on them.
After thourough cleaning, print test page and use alignment if necessary.
May 15, 2009 | HP LaserJet III Printer
Cannot recognize ink cartridge
I have about 6 canon printers with a 3in 1 using PG40 and CL41. I have never encountered the problem you have. I have looked into some other sites and noticed a number if CLI-8 cartridges being replaced by Canon. I think there are only 2 probable problem areas, he cartridge or the software you are using. I suggest you call up Canon and complain about this problem. Seems like you got the printer 6 months or so ago. You should able to get to do something like replace the printer or cartridges. I'm assuming that you don't refill or have your cartridges refilled so the contact points should not be messy w/ ink. You can try cleaning the contact points on the cartridges and printer. But I'd call Canon and explain to them the situation and see if they can solve your problem. Solve I'm implying is to replace your cartridges or printer. Let me know if this helps.
Jul 22, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Lexmark P4350 AIO incorrectly identifies cartridges, will not allow printing
Some times refilled cartridges works fine,and in Lexmark cartridges
they do not support refilled onces ,Try a new compatible cartridge it should print ..
Feb 12, 2008 | Lexmark P4350 All-In-One InkJet Printer
It will not print anything
The problem lies with the refilled cartridge. 1.) Try wiping the bottom of the cartridge with a moist paper tower, to clear up any dried ink. 2.) Put cartridge back in and use the "clean nozzle" feature on the fax machine. 3.) If these steps don't work, it is best to take the refilled cartridge back to the place and have them take a look. Sometimes it can be salvaged. WHY: The print-head (bottom part of the cartridge, retangular shaped, where the ink comes out) is blocked, thus the ink isn't able to come through. This is NOT any fault of the ink refilling service, but rather a wear and tear issue with the cartridges. Most refilled cartridges will work perfectly fine and save you a lot of money.
Aug 29, 2006 | Sharp UX B700 Plain Paper Inkjet Fax
Lexmark P4350 All-In-One InkJet Printer Logo
59 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
