Question about RCA Televison & Video
RCA tv shutdown
TV shuts down just as picture & sound starts to appear
  • Noji May 26, 2008
    I have the same problem. After over a year (the warranty period, unfortunately) of working perfectly, the picture and sound come on when I power it up, then shuts down after a couple of seconds. What gives? During the time it's on, the screen is mostly blue, with heavy blue sync lines going across it.
    Noji Ratzlaff
    nojiratz@hotmail.com
jomaru
  • 337 Answers
SOURCE: in RCA T13208 13 in. TV/VCR Combo shut down after turn it on
The safety circuit is sensing a problem and is why it will not let the tv stay on,the cause could be a problem on the mechanics of the vcr,you need to get an estimate to see if it is worth the repair and might be able to keep using just the tv.
Posted on Sep 24, 2006
SOURCE: rca 32v524t chassis-atc010a
replaced,off/on vol,up and down,and channel up and down.
Posted on Jun 23, 2008
SOURCE: RCA L32WD12 32in. HGTV LCD Television
I had the same problem happen this afternoon, so I took it apart, and the source of the problem is the key controller panel (behind the buttons). It's held in place by 2 screws, if you take the case apart, which is literally only 15 or 20 screws, and then loosen the 2 screws holding the key controller panel on, and then use a small screwdriver to space it out from the button caps. Tighten the screws, and put it back together. Just be careful not to let it go too far to the other side, or you'll have a problem with the menu going on and off at random, which is just as annoying.
Posted on Aug 01, 2008
charcois
  • 763 Answers
SOURCE: Emerson EWC 1302 Tv/VCR combo shuts down
if all the solutions and still the problem occurs then you should see you repair service so that he can replace what cause the problems.
CHARCOIS
Posted on Sep 15, 2008
tlm931
  • 273 Answers
SOURCE: TV PIcture and Sound Shut Down
it would appear its shutting down in a protect mode
its possible its a convergence circuit problem or something on the deflection bd
but it most likley will require some assistance from a tech that is used to working on this type of set
if you noticed when it does come on that the colors are all off line then suspect convergence circuit trouble the the green leds tell you what source is still alive there is a chart in the cabinet that will correspond with each source voltage that can lead you to tracking it down if you know what to look for and have the tools to do so
Posted on Jan 21, 2009
My RCA model # HD52W59, power on and shuts down without coming on. Green come on then shuts down. No picture or sound.
The set is in shutdown because of a problem inside, this model has the three strikes and your out, it will try three times to come on and then latch down. It likely needs a shop repair of some kind.
Aug 27, 2012 | Televison & Video
I turn on my TV and 10 minutes later it turns off by itself. What is the problem
generally this model shut it self down if anything major. possible reason for a delayed shutdown is bad capacitors. or loose connections. does the picture display any abnormalites before shutdown. does it come right back on when you push power button. any sounds or smells? how long has this been doing this?
Oct 13, 2010 | RCA HD52W56 52" Rear Projection HDTV
Picture on TV shuts down but sound still on.
If this RCA TV has a Chassis number of ITC222 then you need to call a tech to swap out the deflection circuit board for a new or rebuilt board. This RCA Chassis is a TV Techs worst nightmare to repair.
Jul 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 32 in TV no picture no sound just a beeping noise TV power is on
Hello cote,
This indicates a problem in the power supply either the low voltage switching supply or the High voltage power supply. The sounds you hear is the shutdown circuit activating, I would not suggest that you try to repair this problem because of the dangers involved. I would suggest that you take it to a qualified TV repair shop. This problem should not cost you much, however it is the best choice for the problem you described.
I hope this helps,
Thank you,
Shuttle83
Mar 14, 2008 | RCA 32V524T TV
52 RCA DLP 1080P Television with NO picture and buttons flash
IF you would like help diagnosing your set. Go to the enclosed link. They have the service manual for your set and offer unlimited chat support for only 29.99. Just click on your sets manufacturer and you will see your model. Then click on the contact us link and provide your email address and they will email your manual and instructions on how to obtain your support. I am one of their techs. This manual contains step by step procedure for troubleshooting Your RCA DLP Light Engine
http://servicemanuals.vstore.ca/
Dec 30, 2007 | RCA HD61LPW175 61" Rear Projection HDTV
Power Surge?
Sound? audio from station.. or noise this set is going into shutdown. the processor is seeing a problem with its safety cuircits and shutdown the set it will try to restart the set 3 times and then lock it down. it can be many things. the processor has an error log.. technician can get in and read codes.
Nov 16, 2007 | RCA D52W19 52" Rear Projection Television
Blue screen of death
What you Have Is a Main RCA Failure you Have a Cathode to Grid Short In your Picture Tube,The Tube shorts and Tells the Miainboard to shut Down...Good Luck
Jul 13, 2007 | RCA TruFlat 27F520T 27" TV
RCA 52" will power on but shuts down immediatley
plz get the picture tube ic's basically when green light mostly appears on the tv it is said that there is a roblem in tv ic's
Feb 28, 2007 | RCA D52W19 52" Rear Projection Television
No picture or sound
It sounds more like a shut down circuit problem if you can feel static from the face of the picture tube after it tries to start up. There are several things that can trigger a shut down condition on TV's. For instance, if there is no vertical deflection signal present, the set may shutdown to prevent a permanent line being burnt across the front of the tube. If the power supply wasn't regulating the B+ voltage properly, it would shutdown to prevent damage in the horizontal sweep section. Or if the horizontal deflection circuit was defective and allowing the high voltage to climb too high (say above 33,000 volts) then the sensing circuit would trigger a shutdown event. If any of the above sounds like gibberish to you then you will need to take the set to a professional for repair.
Nov 24, 2006 | Sharp 36U-F810 36" TV
Televison & Video Logo
48 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
